Alln1DC Bridgeport series 2 interact 2
Snap-On Phil
Re: Alln1DC Bridgeport series 2 interact 2
Post by Snap-On Phil »
Thank you, I’ll check those first thing this morning, what should the settings be on those 2, please
When you say "touch the panel", have you previously selected manual on the auto/man spindle control before trying to start/stop the spindle via the operator's panel?
Snap-On Phil
yes, that's what I was saying
Snap-On Phil
ok, so I tried parameter 00.20 set to 2 and parameter 00.21 set to 1. and it is working from the computer spindle controls now. thank you. i guess not to see if the program runs it on its own.
Snap-On Phil
I’m just making sure I didn’t bump these. The ADC gain switches on edge of board. Is this the correct way they are supposed to be flipped ? Getting ready to put cover back on.
Snap-On Phil
So I’m setting my machine backlash, after I’m done doing that should I run the systest again ?
Unless your needed backlash compensation amounts are ridiculously high, that will not have any effect on the System Test results.
See page 116 of the Allin1DC install manual PDF:
http://www.centroidcnc.com/downloads/ce ... manual.pdf
for ADC DIP switch settings.
You probably want it set for 0 to 10V, which is where your appears to be.
Snap-On Phil
Thank you. I have the DP3 probe, it’s working, where can I find more information on helping setup tolerances, backlash, or anything else using it.
