CNC12 v5.24 RC5 is now available for testing
H.C
CNC Control System Serial Number: 0008DC111213-0116230085
Re: CNC12 v5.24 RC4 is now available for testing
Post by H.C »
For some apparent reason, the link doesn't work for me. When I click on it a window will flash but nothing happens. :?
Blocked by Chrome : go to download history in browser to unblock it. (565MB)
Edit: nope @the end it still getting blocked :(
H.C wrote: Fri Jan 24, 2025 4:51 pm
yeah for some reason the eye of sauron doesn't like the zip file i posted, i'm am re uploading a rezipped file now to see if that makes a difference.
what about the filemail download link i posted does that one work for you?
RC5 pending, imminent.
H.C
Post by H.C »
https://centroid-support.filemail.com/d/dhxczrcqmtiujmz
yep: that one works, will test the probing stuff tomorrow.
H.C wrote: Fri Jan 24, 2025 5:07 pm
right on, thanks.
RogDC
Post by RogDC »
No issues downloading either link on FireFox.
thanks, renamed, rezipped and reuploaded and now the download link is working for me on chrome and edge.
new link address:
Boatwrights Workshop
CNC Control System Serial Number: E062347948F9-0324225805
Post by Boatwrights Workshop »
cnckeith wrote: Fri Jan 24, 2025 5:29 pm thanks, renamed, rezipped and reuploaded and now the download link is working for me on chrome and edge.
new link address:
https://www.centroidcnc.com/centroid_di ... taller.zip
No issue on the shop computer. It is download, now for testing.Thanks
Blue Elephant 1318-4th axis Rotary, 6hp Spindle with Richauto B58 DSP controller converted to Centroid Acorn, Shopbot Desktop 2418 with 1.25hp HSD Spindle
Epilog Helix 50 watt C02 laser 18"x 24" work area
Graphtec FC8000-30" Vinyl cutter/Plotter
Software: Vectric Aspire 12.0v; Rhinoceros 8 with RhinoCAM 2018; Deskproto 8.0v; Autodesk Artcam Premium 2018; CorelDraw 2020; FlexiSign Pro 10.5v
H.C
Post by H.C »
installed, looking around, no F9 (digitize) button. Ultimate+ license.
Edit: ok it's back when fired up this morning.
It is running on my mill now with AcornSix in metric.
Home Feedrates are now for all axes with metric values
In the Jog screen 4th axis is with imperial values in Deadstart and Delta V max
In the new scale max Diff column values are all 0.1 from imperial setup. For metrics on linear axes this will produce a scale position error.
A value of 1 is ok on my machine
I have now the TTO Detect and triggered on their own inputs as suggested.
If I select 4, tool measurement will bring out error 916 after second slow touch off (both probe and TTO plugged in)
If I have only TTO plugged in, so no Probe Detect active, it is still asking TTO or Probe
That is one Keystroke more than necessary, slowing down the workflow.
If only one device is detected, no need to ask IMHO especially if one option is not valid .
report_0008DC111213-1113240211_2025-01-25_09-38-33.zip
(1.27 MiB) Downloaded 9 times
