In the API, is there an equivalent to setting a part position with a numerical input?
Perhaps an oversight from me on using SetWorkPieceOrigin, since it only zeros the WCS, it doesn't seem to accept a part position value input?
I have an ultrasonic sensor that will detect X distance to the part along the track. So for each job segment, I will have an updated distance measurement in X (e.g. + 1.72 mm), and I want to set this as the new part position.Remotely trigger jobs using the API?
Re: Remotely trigger jobs using the API?
- Web Developer
Currently there is no method or function for setting a part position using the API, we will try to add this functionality for the next release.johannes wrote: ↑Thu Dec 12, 2024 1:41 pm In the API, is there an equivalent to setting a part position with a numerical input?
However, you can use Job.RunCommand to call G92 and pass it your axis values. (Note: G92 sets the currently active WCS to the specified values)
public bool SetAbsolutePosition(double? X = null, double? Y = null, double? Z = null)
string cmdText = "G92";
if(X.HasValue)
cmdText += $" X{X.Value}";
if (Y.HasValue)
cmdText += $" Y{Y.Value}";
if (Z.HasValue)
cmdText += $" Z{Z.Value}";
var cncJob = new Job (m_pipe);
if (cncJob.RunCommand(cmdText, GetCNC12WorkingDirectory(), false) == ReturnCode.SUCCESS)
return true;
return false;
SetAbsolutePosition(1.72,null,null);
cncJob.RunCommand("#2501 = 1.72; WCS #1 X val set to 1.72", GetCNC12WorkingDirectory(), false)
I went for this, it was clean and simple and worked fine. Thanks for sharing! This is exactly what I was looking for.Centroid_Jacob wrote: ↑Thu Dec 12, 2024 2:41 pm
Alternatively, you can use a similar approach and use RunCommand to set the system variables to the value if you need to change other WCS locations.
