452 Ethernet Communication Error, CNCPC to Controller - Help! <resolved, "Man, everything is working great. ">
Dangerfox.com
CNC Control System Serial Number: 0035FF9127E6-0305214455
Re: 452 Ethernet Communication Error, CNCPC to Controller - Help! (FIXED)
Post by Dangerfox.com »
UPDATE:
Original issue of Error 452 ethernet communication issue was fixed by upgrading the software to V5.1. I've been running the cnc all day and haven't had a single error.
Thank you to everyone who assisted in this process.
Dangerfox.com wrote: Tue Jul 02, 2024 5:04 pm UPDATE:
Wow, I go outside to work on my "honey-do" list in the yard and I come back and your machine is fixed, that's great.
Dangerfox.com
ShawnM wrote: Tue Jul 02, 2024 8:51 pm
Man, everything is working great. Thank you for your help. I really appreciate it.
Dangerfox.com wrote: Tue Jul 02, 2024 11:08 pm
No problem, glad we could all help.
Dangerfox.com
ShawnM wrote: Wed Jul 03, 2024 12:55 pm
One more question...
I am getting inconsistencies with my cut depths on tool #1 which is my 3/8 compression profile cutter. I will touch it off multiple times in a row and it varies neg and pos .02. I can get it to stay the same or close after a few touch offs but then I have cut issues.
I just ran a file, two separate but identical profile cuts, first one cutting inside and second one cutting outside. The inside cut perfect 2 passes goal dept is .686. Second outside tool path cut .04 into the spoilboard and I can't figure out what's happening. The last 3 sheets of plywood I've run have all be different.
I've attached a new report and screenshots. The thing I am concerned with is the "Tool Measurement Reference Method". Should I set it to ZHome =Zref or reference tool?
Thanks for your help again.
Wizard Docs V5.1 710.pdf
(1.42 MiB) Not downloaded yet
report_0035FF9127E6-0305214455_2024-07-10_15-45-59.zip
(1000.28 KiB) Not downloaded yet
Re: 452 Ethernet Communication Error, CNCPC to Controller - Help! <resolved, "Man, everything is working great. ">
I use Z home on my routers as the reference. This is only accurate if you have accurate and repeatable homing.
What kind of tool touch off do you have? Is it a good quality one? What is your "slow" touch off rate set to?
Dangerfox.com
ShawnM wrote: Wed Jul 10, 2024 5:44 pm I use Z home on my routers as the reference. This is only accurate if you have accurate and repeatable homing.
OK, thats what I have mine set to as well.
Touch off is a HNC, I paid a few hundred dollars for is a couple years ago, but I've never had this problem in the past on V4.
Slow rate is 50 IPM.
