I came to the conclusion that the Drewtronics probe is not ideal. I bought one of the inexpensive touch off tools instead. I needed to make a probe tip for it and it came out nice, two slightly different versions to try.
Hardinge CHNC4 Retrofit
Re: Hardinge CHNC4 Retrofit Probe update
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
Still have some areas that need work but the machine is running and making parts
1 user liked this post
Right on! thanks for reporting back with the video of the smooth turret action!
For the probe tips, it should not stop at the end of the thread, it should stop at the shoulder.
Maybe shorten the thread and turn a relief cut.
To probe all possible nose vectors I have made a probe arm to mount the probe vertical.
viewtopic.php?t=10429
I like the idea of the probe arm, changing collets/workholding is a small pain on the CHNC. I'll have to read up about setting it up with an ALLIN1DC. I assume you set all tools at the probe then set Z0 and X at the part.
If you do not have precise ZRI home, set part X with T0101 each time after homing..
Set X and Z ref for the tool arm once if the mounting is repeatable.
Probe all tools
Set Z for the current part
Make parts
Probe all tools
Make parts
