Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
RJS100
Re: Fusion 360 Mill Post Processor for CNC12 with additional Features (New Community Version 1.0)
Post by RJS100 »
Thanks Uwe.
midy
Post by midy »
Whereabouts is the download link for the latest version?
RJS100
Post by RJS100 »
On the first two pages of this post there are a few links to recent versions. I am not sure which is the absolute latest. Here is one I downloaded just a few weeks ago: https://www.dropbox.com/scl/fi/aj2g9orb ... 0vfqg&dl=0
Here is one as noted:
Latest Community Version as of January 9th 2025:
download/file.php?id=31019
It is a bit confusing as later in the post, there is a comment that one was removed.
Richard
swissi
Post by swissi »
RJS100 wrote: Tue Feb 11, 2025 1:46 am On the first two pages of this post there are a few links to recent versions. I am not sure which is the absolute latest. Here is one I downloaded just a few weeks ago: https://www.dropbox.com/scl/fi/aj2g9orb ... 0vfqg&dl=0
Richard
I believe midy was asking where the download is for the PP version that has the fix for the peck tapping that Uwe said he's going to try to fix.
I haven't seen that fixed version yet so the Community Version 1.0 is still the latest at the moment.
-swissi
I did not fix multiple Peck Tapping right now, that is more work with my skill level than I thought :mrgreen:
Workaround is to copy the tapping for each hole at the moment.
But I have built a feature to write sequence numbers only on each section in a line before the section comment
That is handy if you want to start at a section with run/search in CNC12.
centroid.zip
(20.29 KiB) Downloaded 51 times
Next Mod
Allow all file names not only numbers.
There is no testing for unusable names, so be careful ;)
centroidForum.zip
(20.03 KiB) Downloaded 31 times
OG1
CNC Control System Serial Number: 544538046067-0616237327
Post by OG1 »
Forgive me for the dumb question. I setup WCS 2 and 3 and locked them to two jigs I have. In Fusion I told it to send to 2 and 3 using and forgot to test and it crashed using WCS1. I did learn if I manually assign WSC 2 for the 2nd op and WCS 3 for the last it works.
Does the post processor not assign WCS or did I do it wrong?
Thanks so very much!
What PP do you use?
I works ok with the last one I have posted
G55 and a second run with G56
; --- File:      test.nc
; --- Comment:  (Testing Stuff)
(T1 D=3. CR=0. - ZMIN=-10. - right hand tap)
G90 G94 G17
G21
G28 G91 Z0.
G90
N10
(PeckTapping 1)
T1 M6
S500 M3
G17 G90 G94
G55
M7
G0 X-27.5 Y15.
G43 Z15. H1
G0 Z5.
G84 G99 X-27.5 Y15. Z-3. R5. Q0.5
X-27.5 Y15. Z-6.
X-27.5 Y15. Z-9.
X-27.5 Y15. Z-10. G98
G80
Z15.
N15
(PeckTapping 2)
G0 X1.5 Y15.
Z15.
Z5.
G84 G99 X1.5 Y15. Z-3. R5. Q0.5
X1.5 Y15. Z-6.
X1.5 Y15. Z-9.
X1.5 Y15. Z-10. G98
G80
Z15.
G28 G91 Z0.
G90
N20
(PeckTapping 1)
G56
G0 X-27.5 Y15.
G43 Z15. H1
G0 Z5.
X-27.5 Y15. Z-6.
X-27.5 Y15. Z-9.
G80
Z15.
N25
(PeckTapping 2)
G0 X1.5 Y15.
Z15.
Z5.
X1.5 Y15. Z-6.
X1.5 Y15. Z-9.
X1.5 Y15. Z-10. G98
G80
Z15.
M9
G28 G91 Z0.
G90
G28 G91 X0. Y0.
G90
M30
UWe
Now with the current update, there is a Dark Mode in fusion, yeah now doing CAD/CAM without sunglasses :mrgreen:
occustoms
Post by occustoms »
Ok so the new community version here doesn't work for simultaneous but the original version works perfectly. Dont know what yall changed. ill post what it does with New community version.
