CNC CONTROL SUGGESTIONS
Juan Mtz
Re: CNC CONTROL SUGGESTIONS
Post by Juan Mtz »
Thank you very much for your comments,
I was checking the manual configuration for servodrive Yaskawa in this web site but I do not find configuration information for close loop system.
It seems the procedure that shows in the manual is for open loop system .
Do you have procedure that shows that option? Also incremental enconder will be used for this purpose.
Do you see any issue if we use that options?
Thank you.
1.) the CNC4PC boards are used with the Yaskawa in hybrid closed loop mode with Acorn.
2.) the Centroid Yaskawa cables are used with Oak and provide full closed loop operation with Yaskawa. found on this page
https://shopcentroidcnc.com/oak-cnc-controller/
Yaskawa setup full closed loop mode for use with Oak
https://www.centroidcnc.com/dealersuppo ... ds/267.pdf
Juan Mtz
Post by Juan Mtz »
Thank you very mucho,
I would like to know How can i do for customize the cnc console?
I undertand that when there is a Virtual controller there are more options for customize but in my case will be a phisical console where some buttons will not used as example spindle buttons speed.
how can I customize?
I attached the link where you can see there is not spindle. for cutting glass used a cutter wheel.
Warning: Poster, Album not found for https://photos.app.goo.gl/pTsfcjaHKuBiNJve9. Please check the URL by editing the post and try again.
Regards!
Gary Campbell
Post by Gary Campbell »
Yours is a pretty straightforward tangential cutter application. As long as you have a CAM program that can output the C axis positions, I see no obstacles. There are numerous options for customization with the Centroid system. Both virtual (onscreen) and physical buttons.
Here's one I did a few years back with another controller:
Juan Mtz wrote: Sat Mar 09, 2024 2:53 am Thank you very mucho,
Regards!
hello. yes you can edit the VCP and remove the spindle buttons and/or create your own physical buttons for an purpose.
vcp manual is here. https://www.centroidcnc.com/centroid_di ... manual.pdf
Juan Mtz
Post by Juan Mtz »
Thank you very much for your comments but, I was seeing the manual and is talking about Phisically I mean when there is console with buttons phisically NOt virtuall buttons.
See image as reference console CNC=
Is posible to change the name of the buttons or du something to customize the panel CNC?
Thank you.
You can request custom graphics for the 12 Aux keys; for the keys in the coolant row; and for the axis jog buttons.
To the best of my knowledge, Centroid is not able to provide custom graphics for the keys in the spindle-control section; nor for the cycle-control keys in the bottom row, nor the jog-increment keys in the middle.
most users that want to fully customize the interface will use a 1920x1080 monitor and build there own console so they can make use of the VCP which is completely user editable and customizable. see examples of custom VCP operator control panels here.
https://centroidcncforum.com/viewtopic.php?f=60&t=5089
custom consoles
