OPCON and USB-BOB
BDubs
Re: OPCON 15374
Post by BDubs »
That's just it though...I'm not getting a com port number in the device manager...therefore - I can't set the parameter.
Wondering if I got a beat one or what...
Brady Watson | IBILD Solutions | Production Consultant | HiDef 3D Laser Scanning | Vectric Custom Video Training | IBILD.com
Sword
Re: OPCON 15374
Post by Sword »
Guessing you have tried some other ports and another PC maybe, just to see if it shows up.
Scott
BDubs
Re: OPCON 15374
Post by BDubs »
I think we're suckin diesel now... For whatever reason, only the Reset device showed up and nothing under USB devices. Now I got it showing up as a USB Serial Device on com 11...popped in the parameter and it's lit up.
Thanks for the moral support... I can't explain how it mysteriously showed up after like 7 tries, but persistence pays off I guess 😁
centroid467
Re: OPCON 15374
Post by centroid467 »
BDubs wrote: Mon Feb 19, 2024 3:22 pm I think we're suckin diesel now... For whatever reason, only the Reset device showed up and nothing under USB devices. Now I got it showing up as a USB Serial Device on com 11...popped in the parameter and it's lit up.
Glad it started showing up! If you want, I can send you the latest firmware and instructions for updating but it should already be at the latest.
In either case, please keep us updated on any further issues you may run into.
chronolite
CNC Control System Serial Number: 7804739E42DF-0925192491
Re: OPCON 15374
Post by chronolite »
Just to add to this, in the real world, PLC operators and indicators are almost certainly 24v. 5v is cool at home, and we all know raw LEDs use much lower voltages, but if there are going to be outputs and inputs, they need to handle 24v. I understand this causes issues with USB, so this means external power supplies, buck-boosts, relays, optoisolators, whatever it takes;
Industrial IO is mature, thoroughly tested, and has evolved for over 70 years. IEC-61131 was first adopted in 1993 and has become the defacto standard dictating 24v.
Re: OPCON 15374
these products suit that requirement.
https://shopcentroidcnc.com/shop/cnc-ex ... nsion-kit/
https://shopcentroidcnc.com/shop/cnc-ex ... -acornsix/
https://shopcentroidcnc.com/shop/cnc-ex ... ion-board/
opcon and usbbob are a diy low cost way to get hard operator console buttons
chronolite
Re: OPCON 15374
Oh duh, that's a great point. Awesome.
Do you think this code change will eventually allow a (m400 pendant) wired MPG and a wireless MPG to coexist?
Re: OPCON 15374
chronolite wrote: Wed Feb 21, 2024 1:57 pm Oh duh, that's a great point. Awesome.
i never had both a wired and wireless mpg connected to a m400 but,i think you can do that right now (and even have the VCP thrown into the mix).
chronolite
Re: OPCON 15374
Yeah for some reason it doesn't work, both sales and tech suppt confirmed this. I'm not talking about any ol mpg, I mean the pendant that comes with the m400 can't be used with the WMPG. If this isn't the case, I would really really like to implement both.
Re: OPCON 15374
i'm told they will work together.
Locked
