Moving X and A together(Thread)JUST CRAWLS
Re: Moving X and A together(Thread)JUST CRAWLS
The software features that use Parameters 116 and 117 will work with any type of machine, but they are mostly used on bed mills.
On a knee mill, you will have to find and set new values every time you move the knee or the ram.
Parameter 116 is the Y axis value on the machine-coordinates DRO (Alt-D) when the spindle centerline is lined up over the rotary axis centerline. You have to find a new value for it every time you move the ram.
Parameter 117 is the Z axis value on the machine-coordinates DRO when the tip of your reference tool has been moved down to the rotary axis centerline. You have to find a new value for it every time you move the knee.
cncot
CNC Control System Serial Number: console 104030 SysId 0008DC111213-1202202505
Post by cncot »
Do you think my speeds you found will lead to troubles later? Other than just Jobs running slower?
Warm Regards, Mike
I recommend setting the Y and Z DeltaVmax values back up to 3.0 in/min (same as X) so that you can cut G2 and G3 arcs.
