Page 3 of 4
Re: The Centroid CNC PC Tuner v1.0 has been released.
Posted: Thu Jan 04, 2024 11:50 pm
by Sword
Win 10 has always had the same setting as well. Could PC Tuner be changing something in group policy that has some other dependencies tied to it?
Posted: Fri Jan 05, 2024 3:29 pm
yes, PC Tuner sets Hibernate to Never/Off which SHOULD also disable the "Fast Startup" feature we don't want. I checked it on a few computers and that does seem to be working. PC with batteries (laptops) may take more turning off of settings. (yet another reason we don't recommend using laptops:-))
Posted: Fri Jan 05, 2024 4:00 pm
by suntravel
I have tested the tuner on 2 PCs and 1 Laptop with WIN10 and 1 Laptop with WIN11. Works ok for me.
It did not make any of these unusable, and even if it did, I could restore the backup made right before the testing.
Most problems are 1-2 feet in front of the computer 🤣
Posted: Fri Jan 05, 2024 5:34 pm
v1.2.2 is now available.
https://www.centroidcnc.com/centroid_di ... _1.2.2.zip
opens full screen
improved messaging
removed auto set of file types for Notepad ++ (we may revisit this feature in future)
Posted: Fri Jan 05, 2024 5:38 pm
by ShawnM
suntravel wrote: ↑Fri Jan 05, 2024 4:00 pm Most problems are 1-2 feet in front of the computer 🤣
even a monkey can do it.jpg (24.96 KiB) Viewed 20075 times
Re: The Centroid CNC PC Tuner v1.3.0 has been released.
Posted: Wed Apr 10, 2024 2:58 pm
******* update 4-10-24 *********v1.3.0 is now available.
fixed notepadd++ installation for Windows 11 changes
found on
Posted: Sat Jun 01, 2024 9:41 am
by Spartan117
I just upgraded from an older and working installation 4.86 to 5.10.
Then i have been notified by CNC12 to have ethernet-communication-errors... Didn't have errors with 4.86, but hey, PCs don't lie, so downloaded PC-Tuner-App, startet it, clicked on "Run all ... checks" and...
the PC-Tuner-App is closing itself while testing CPU-speed^^
I clicked on "Prepare Win for Centroid CNC use" anyway, and every everything got a green checkmark there after short time.
Clicked on "Run all checks" again, but again the App crashes/closes itself while performing the first test (CPU-Speed).
I attached the sys-info
I did follow the windows setup manual of 4.86 when i had installed 4.86, just to mention that.
Oh, and that PC is not online. Just a working horse with no WLAN or LAN-Connection to the internet, only standard LAN to Acorn.
Posted: Sat Jun 01, 2024 10:19 am
by suntravel
For PC tuner PC must have internet connection and it must be set up to US Keyboard, Number and Date format..
Posted: Sat Jun 01, 2024 10:45 am
by Spartan117
suntravel wrote: ↑Sat Jun 01, 2024 10:19 am For PC tuner PC must have internet connection and it must be set up to US Keyboard, Number and Date format..
And that causes the app to crash when testing CPU-Performance, without any error-message? :shock:
In my thinking, no machine-control should have an internet-connection, it is made only for locally controlling my machine and nothing else.
More than ever when every antivirus and firewall has to be disabled...?
Posted: Sat Jun 01, 2024 11:12 am
by suntravel
Windows defender is working ok with CNC12, but I also allow LAN only for updates or if I use CAM to post gcode...
