Page 3 of 4
Re: lathe spindle question
Posted: Fri May 02, 2025 1:31 pm
by suntravel
midy wrote: Fri May 02, 2025 9:54 am Thanks Tom, im taklking about page 8 has this statement:
3.) For Acorn/AcornSix/Hickory systems or if you do not plan on compiling the PLC with Notepad++,
then skip to Step 12.
Does that mean if you have acorn you skip to step 12? Thats how it seems to read to me?
This means if you want to compile a PLC ( this is what you want ) do not skip, follow the TB on all steps, easy peasy.
This really is the easy part, understanding the PLC logic is another thing, something why I have grey hairs now :mrgreen:
Posted: Sun May 04, 2025 9:29 am
by midy
Well I think i'm nearly there, just one last speed bump I hope. NP++ says it can't find the file but the files are in the cncm folder?
Posted: Sun May 04, 2025 10:40 am
by suntravel
Wrong filename for a lathe, you want to compile acorn_lathe_plc.src
Posted: Sun May 04, 2025 10:42 am
by midy
No. I am doing the mill aswell. This is correct.
This the mill cncm directory
Posted: Sun May 04, 2025 4:45 pm
by suntravel
Do you have the compile.cmd in the cncm folder?
Posted: Mon May 05, 2025 11:42 am
by midy
I do yes. I did as instructions said and compile mill.txt in the cncm folder and changed it's name to compile.cmd. I assumed you overwrite the existing compile.cmd file?
Posted: Mon May 05, 2025 12:28 pm
by suntravel
compile.cmd is installed automatic when installing CNC12, but you can also use the file in the NP++Zip and just rename like in the TB.
Pls. post a fresh report.
Posted: Fri May 09, 2025 9:21 am
by midy
thanks for looking, i still have not figured how to compile?
Posted: Fri May 09, 2025 9:32 am
by suntravel
Report is from the mill and no compile.cmd in the cncm folder.
The error in Np++ is telling you it can not find this file, because it is not there....
Posted: Fri May 09, 2025 10:31 am
by midy
Ive just realized that i need to do the latest update, so will come back to this on a fresh cnc12 install
