Adding a 20% feeds button to VCP
Re: Adding a 20% feeds button to VCP
Gary Campbell wrote: Fri Jul 15, 2022 8:09 am
. :lol: I am working on Keith right now. I think he is close to caving in.
What can I do to help? I am usually pretty good at convincing a businessman to spend programming dollars to implement a free service that may reduce sales of one of the more popular accessories. :lol:
Choose the easy way and convince his wife that he needs a WMPG to get faster out of the shop to spend more time with her ;)
Black Forest
Post by Black Forest »
suntravel wrote: Fri Jul 15, 2022 8:56 am
You got that ass backwards Uwe. She would pay extra if I spent less time with her! :D
Slow Joe with some funny redlight is done.
Copy the files from the ZIP into your \cncm\resources\VCP\Buttons\aux13 folder
Edit acorn_mill_....skin.vcp
 <button row="10" column="1">cycle_cancel</button>
  <button row="10" column="2">single_block</button>
  <button row="10" column="3">tool_check</button>
  <button row="10" column="4">feed_hold</button>
  <button row="10" column="5">aux13</button>
  <button row="10" column="6">cycle_start</button>
or place the aux13 where you want.
Edit the acorn_mill_plc.src
place these lines
; Aux13 to SlowJoe----UWE
IF SkinAux13_M THEN KBOverride_W = 20
IF SkinAux13_M || KBOverride_W == 20 THEN (Aux13LED)
Here: (to find the right place)
;--Feedrate Override Section
; Feedrate override works as follows:
; 1. The PLC reads the 8 bit value of the FeedrateKnob_W directly (0-255)
; 2. The PLC scales this value to a 0-200 value (0-200%) by dividing by
;    the knob value by 127.5 and then multiplying the result by 100
; 3. If keyboard jogging is enabled, the PLC
;    determines whether the operator is using the keyboard override or
;    the FeedrateKnob_W to override the feedrate by watching which was changed
;    most recently.  The most recently changed value is saved as
;    "FinalFeedOverride_W"
; 4. Parameter 39 in (From the "params" screen in CNC12 software) stores
;    a value which the PLC program must use to limit the amount
;    of override applied to the programmed feedrate. This value is specified
;    as a percentage.
; 5. The PLC limits the override percentage by reading parameter 39 and, if
;    the feedrate override percentage as read from the knob is greater than
;    parameter 39, it sets the FinalFeedOverride_W value to the value of
;    parameter 39.
; 6. Once the override percentage has been determined and limited (if needed)
;    The PLC send this value up to the CNC12 software by setting
;    SV_PLC_FEEDRATE_KNOB = FinalFeedOverride_W
; 7. CNC12 reads SV_PLC_FEEDRATE_KNOB, factors in its own override based
;    on parameter 78 (see operators manual for more info on parm 78) and then
;    returns an override value to the PLC in the system variable
;    SV_PC_FEEDRATE_PERCENTAGE
; 8. The PLC reads SV_PC_FEEDRATE_PERCENTAGE and (typically) echoes the system
;    variable to SV_PLC_FEEDRATE_OVERRIDE which the MPU11 uses as the final
;    determination of the feedrate override percentage.
; NOTE: BTW = Bit To Word
; BTW reads the specified number of bits (if none is specified it defaults to 8)
; starting from a bit location and writes them to a word with the starting bit
; location being written to the LSB of the word used.  Below, BTW reads the bit
; values from JpFeedOrKnobBit0 to JpFeedOrKnobBit7 and writes them into to the
; word "FeedrateKnob_W" which sets FeedrateKnob_W to a value of 0-255
IF OnAtPowerUp_M THEN KbOverride_W = 100, FinalFeedOverride_W = 100, SET UsingVirtualOverride_M
; 2. Scale this value to a 0-200 value (0-200%)
IF True THEN SkinFeedOverTimer = 200
IF SkinFeedOverMinus_M THEN (SkinFeedOverMinusPD), SET SkinFeedOverTimer
IF SkinFeedOverPlus_M THEN (SkinFeedOverPlusPD), SET SkinFeedOverTimer
IF !SkinFeedOverPlus_M && !SkinFeedOverMinus_M THEN RST SkinFeedOverTimer
IF !WaitingForSleepTimer_M && ((KbIncFeedOver_M || SkinFeedOverPlusPD) || (SkinFeedOverTimer && SkinFeedOverPlus_M))
  THEN KbOverride_W = KbOverride_W + 1,
       RST UsingFeedrateKnob_M,
       SET WaitingForSleepTimer_M,
       SleepTimer = 30, SET SleepTimer
IF !WaitingForSleepTimer_M && ((KbDecFeedOver_M || SkinFeedOverMinusPD) || (SkinFeedOverTimer && SkinFeedOverMinus_M))
  THEN KbOverride_W = KbOverride_W - 1,
IF SleepTimer THEN RST WaitingForSleepTimer_M, RST SleepTimer
; MPGMacro3_M Feed Override 20% MPGMacro4_M Feed Override 100% -UWE
IF MPGMacro3_M THEN KBOverride_W = 20
IF MPGMacro4_M THEN KBOverride_W = 100
Compile and play :mrgreen:
aux13.zip
(4.76 KiB) Downloaded 23 times
Black Forest
I am watching and trying to find videos on how to implement what you given me. I really really don't want to trash my system!
Spartan117
Post by Spartan117 »
Just make a copy of your cncm folder before and maybe a fresh report.
The you should be able to restore anything if needed
German-speaking, so please be patient with my english-skills :)
If your NP++ is setup like in the TB294, ad the lines and hit F6 to compile.
Restart the CNC and go on.
