Page 3 of 3
Re: X axis motor trips while running a job
Posted: Wed May 25, 2022 12:18 am
by Gary Campbell
Sorry, I forgot about the mini fit connectors as I seldom use them
Posted: Tue May 31, 2022 11:40 am
by blksmth
Everything on hold till I get the new C86ACCP to see if that is the problem.
Posted: Fri Jun 03, 2022 10:53 pm
by hennessey
In all of these tests, was it the same *cable* that resulted in lack of negative motion? I know you said that you tested other motors on the x axis port of the c86 and they all exhibited this behavior.
Id be looking at wiring first for sure. My machine did something similar on first or 2nd boot up and turned out i had totally boofed one of the molex connector pin outs.
Posted: Fri Jun 03, 2022 11:02 pm
by Gary Campbell
Over the years I've had 2 cables that have had the 2 interior pairs swapped, but those motors would not enable
Posted: Fri Jun 03, 2022 11:50 pm
by hennessey
Gary Campbell wrote: ↑Fri Jun 03, 2022 11:02 pm
I believe i had the black and white wires swapped (inner 2 cables bottom row of connector)
EDIT*
correction, the white and brown wires were swapped which was what made my clearpath only want to turn one way
Posted: Tue Jun 07, 2022 10:23 pm
by blksmth
Just got the new C86ACCP (that I ordered 5-19-22) wired it up and every thing works as it always had. Was a malfunction in the C86ACCp board. Caused me a lot of headache but I learned some more. One thing I know for sure I wish Centroid would make a similar board and sell to those who are using the Clear Path motors. It would almost be a plug and play system then. No need for a third party gizmo. Centroid and Clear Path are top notch. just my 2 cent worth. Oh by the way I am glad I didn't have a customers high dollar piece of wood down when things went haywire
Posted: Wed Jun 08, 2022 12:41 pm
thanks for reporting back!
Posted: Wed Jun 08, 2022 7:04 pm
by ShawnM
blksmth wrote: ↑Tue Jun 07, 2022 10:23 pm
Where have I heard this before?
