Atc mfunc.6 could use some help (Resolved)
Re: Atc mfunc.6 could use some help
No bug. You have something set incorrectly. Once the estop (input)is triggered all outputs will toggle off
Thanks for the replyGary Campbell wrote: ↑Fri Apr 02, 2021 11:18 pm No bug. You have something set incorrectly. Once the estop (input)is triggered all outputs will toggle off
I assumed it was my macro because they are the only outputs that don’t shut off I will go and check my settings
Don't forget that a proper estop has 2 circuits. One that physically removes power from certain components and another that triggers an input set as estop. That input, when triggered, will activate an "all stop" event. No motion, no outputs
Ok got to work on it today, here is what i think is going on. My macro was written for cnc12 4.5 , I upgraded to 4.6 and did a restore report to get all my settings back . Well 4.6 doesn't have the generic outputs i used in my macro so I assume there is something not compatible now, thats just a guess , I am no programmer . I have 3 options i think .Gary Campbell wrote: ↑Sat Apr 03, 2021 11:06 am Don't forget that a proper estop has 2 circuits. One that physically removes power from certain components and another that triggers an input set as estop. That input, when triggered, will activate an "all stop" event. No motion, no outputs
ONE go back to 4.5 hope that works and never upgrade .
TWO , hard wire the estop function using a contactor / latching relay that turns off power to all those outputs and then Wright a macro (say macro57) that deactivates those outputs then turns power back on to those atc outputs . The down side to that is I would have to remember press that macro ever time an estop is pressed. I guess I could have an input set when the power is removed from those outputs that would cause a message come on the screen when the m6 macro comes up to remind me to press that macro.
THREE hire centroid to fix my mess , if they do that ?
Going back to 4.5 didn't fix the estop issue about turning off those 4 outputs,. So you will need to design a relay circuit with one latching relay and a regular relay to prevent pressing the estop twice from turning it back on and causing a crash
The drawbar works with a latching relay , its the only way I could think of to keep the collet from drawing up into the spindel and ruining it . For manual tool changes you need to design a logic relay to prevent accidental tool release as the spindle is turning.
Ok here are my macros . If any one sees any thing thats should not be done pls let me know I like my fingers firmly attached to my palm. Maybe this will help some one. Use at your own risk.
Macros 10 and 11 are for a tool numbers not in the carousel
Macros 51 and 52 are carousel in and out
Macro 53 is a warning to reset the atc after estop if one forgets to do it . You must do centroids reset procedure plus press m56 button.
Macro 56 is for resetting the atc after an estop you must do centroids reset procedure
Macro 6 is the tool changer
- mfunc53.mac
- (1.32 KiB) Downloaded 78 times
- mfunc6.mac
- (24.58 KiB) Downloaded 85 times
- mfunc56.mac
- (1.04 KiB) Downloaded 81 times
- mfunc52.mac
- (869 Bytes) Downloaded 75 times
- mfunc51.mac
- (692 Bytes) Downloaded 78 times
- mfunc11.mac
- (1.31 KiB) Downloaded 73 times
- mfunc10.mac
- (1.8 KiB) Downloaded 81 times
- report_F045DA76BCBE-1108181316_2021-04-12_18-42-02.zip
- (1.1 MiB) Downloaded 72 times
What you saying Winston?WINSTON wrote: ↑Mon Apr 12, 2021 6:54 pm Going back to 4.5 didn't fix the estop issue about turning off those 4 outputs,. So you will need to design a relay circuit with one latching relay and a regular relay to prevent pressing the estop twice from turning it back on and causing a crash
You made this statement: "So you will need to design a relay circuit with one latching relay and a regular relay to prevent pressing the estop twice from turning it back on and causing a crash"
What exactly do you mean/expect?
When an Estop/fault occurs, all outputs are turned off, they are not active. Are you saying you have outputs active?
I'm not sure what you are asking or what help you need.
When you set up your ATC, did you start with the ATC PLC's posted here? viewtopic.php?f=63&t=1340
If it were me, I would get screen shots of all the current wizard pages, create a fresh report, copy the current CNCM directory to a USB drive, rename the current CNCM directory CNCM 4.x, install a fresh copy of CNC12 4.64, then use the appropriate ATC file referenced above to setup the ATC following the included instructions. If I was still having trouble, I would create a FRESH REPORT and reach out to Centroid for paid support.
You'll get through it. CNC12 has not problem controlling an Umbrella changer.
Yes those 4 outputs stay on just those 4 outputsmartyscncgarage wrote: ↑Tue Apr 13, 2021 10:40 amWhat you saying Winston?WINSTON wrote: ↑Mon Apr 12, 2021 6:54 pm Going back to 4.5 didn't fix the estop issue about turning off those 4 outputs,. So you will need to design a relay circuit with one latching relay and a regular relay to prevent pressing the estop twice from turning it back on and causing a crash
In both4.5 and 4.6
Re: Atc mfunc.6 could use some help (Resolved)
You say "those 4 outputs stay on just those 4 outputs" WHICH output numbers? and what are they assigned to?
Outputs are physical outputs on Acorn.
Please open the diagnostic screen. Do a video and show the outputs. Second line down is the output line, far left starts with Output 1
Show the Diagnostic screen with CNC12 on line
Then press the Estop
See if all the OUTPUT Virtual LED states change to all red as they should.
Outputs 111 112 113 114 115 sorry thats 5 not 4 the vids below ones 4.5 the others 4.6 outmartyscncgarage wrote: ↑Tue Apr 13, 2021 3:08 pm You say "those 4 outputs stay on just those 4 outputs" WHICH output numbers? and what are they assigned to?
111 is the pulse signal to the gearmotor
112 reverses the gear motor polarity
113 is carousel in and out
114 is to blow chips off the tool
115 is the drawbar
Boy, you sure move fast in your video....
Please post a FRESH report. Lastest version of software. Previous versions no longer supported.
Did you do any PLC modifications to those outputs?
