Page 3 of 3
Re: Motors not turning
Posted: Tue Oct 06, 2020 10:17 am
by mousecnc
Not only the little green fuses but the pull up resistor blow out. The pull up is bigger and I think it may be soldered in not sure though. The green lights will light but no movement if the pull up is blown.
Posted: Wed Oct 07, 2020 9:48 pm
by Harry-O
Mousecnc yes your right but i'm running full 7 amp no resiter needed. I've done that on all setups never had a problem, i'm useing much lager motors 900 oz/in and larger. been buzy working on other project . After reading over manual the db25 uses diferential wireing ,the G203v use only step direction and com . To get things running I quess I'm going to screw terminal wired dicect without use of PDMX134 Board. I'll use sck that Centroid uses.
Posted: Thu Oct 08, 2020 1:58 pm
by mousecnc
Call Gecko and get a RMA to have your drives checked out and repaired. I sent 5 in and they replaced the pullup resistor and returned them to me. They only charged me just $13 shipping with free repair.
Posted: Fri Oct 04, 2024 9:41 am
by DigitalMechanic
I have the same (rather similar) setup with the PMDX-134. I'm running Gecko 201X drivers and I'm still wiring everything up... Would love to see your progress mousecnc... I'm still configuring and snaking wires all over the place.
-DigitalMechanic
Posted: Fri Oct 04, 2024 9:46 am
DigitalMechanic wrote: Fri Oct 04, 2024 9:41 am I have the same (rather similar) setup with the PMDX-134. I'm running Gecko 201X drivers and I'm still wiring everything up... Would love to see your progress mousecnc... I'm still configuring and snaking wires all over the place.
-DigitalMechanic
First, you responded to a very old post.
Switch over to Acorn instead of using the PMDX-134 and move away from Mach.
Don't use the PMDX board with Acorn.
