Guide on how to measure Tool Heights and set WCS Z0 on a Router or Mill with none-fixed Tool Holders most efficiently
Maker1970
Re: Guide on how to measure Tool Heights and set WCS Z0 on a Router or Mill with none-fixed Tool Holders most efficientl
Post by Maker1970 »
cncsnw wrote: Sat Jan 23, 2021 5:57 pmTry -50006.
Thank, I just got it. I had my input set as tt detect. I just switched it to probe triggered and it works great.
Maker1970
"You lie to your friends, and I'll lie to mine. Let's not lie to each other"
Bigtimeb
Post by Bigtimeb »
I am running a small mill. I have a fixed TT set up on G30. Tool changes work well. I have always used a 3D probe to find my corner position, then install a tool and manually set my Z, then recorded my Z using the Probeapp to get the first Z offset and run the beginning of the program without changing the Z height. Once a call for another tool, I can choose “subsequent tool change” to record a new offset. This is so convenient not having to keep track of a tool library.
My question is, can I use my 3D probe to find the X and Y as well as the initial Z height of my stock, then load a tool and record the new offset being the difference between the 3D probe and the Fixed TT? This would eliminate me having to set the Z offset with my eye or a feeler gauge.
I hope that makes sense. TIA
