Re: Encoder Differential Error
Posted: Mon Jul 13, 2020 10:59 pm
What I come up with:
Solder drain wire to DB9 shellThey are actually in the center, one switch for X and one for Y, Centered more or less.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:26 pmIf you have one switch you need to fix it in the CNC12 software configuration. You didn't answer which end of the axis the switch is on so I can't help you there. You will have to either jump the unused limit switch input to COM or use the appropriate limit switch defeat on AIO DCjeingham wrote: ↑Mon Jul 13, 2020 10:24 pm
<SNIP>
Yes, got it, one tripper and software limits, I was sort of aware that would need to be the case.
X switch is in the middle pretty much, Y too. Trips are at either end of the range of travel relative to the single switch.
Will contemplate second switch.
John
Thank you Marty, I should have done some kind of spread sheet myself. Will run it all to ground tomorrow and let you know how it goes.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:59 pm What I come up with:
I would move it to one end or the other. BUt it could be used this way, you would have negative and positive values for your soft limits depending on the travel distance either side of the tripper.jeingham wrote: ↑Tue Jul 14, 2020 12:21 pmThey are actually in the center, one switch for X and one for Y, Centered more or less.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:26 pmIf you have one switch you need to fix it in the CNC12 software configuration. You didn't answer which end of the axis the switch is on so I can't help you there. You will have to either jump the unused limit switch input to COM or use the appropriate limit switch defeat on AIO DCjeingham wrote: ↑Mon Jul 13, 2020 10:24 pm
<SNIP>
John
I use spreadsheets and save them.jeingham wrote: ↑Tue Jul 14, 2020 12:25 pmThank you Marty, I should have done some kind of spread sheet myself. Will run it all to ground tomorrow and let you know how it goes.martyscncgarage wrote: ↑Mon Jul 13, 2020 10:59 pm What I come up with:
John
- Swapping A with /A;jeingham wrote:Gotta check tomorrow but it appears that I have the A and /A AND B and /B wire pairs inverted.
