Page 3 of 5
Re: Shopbot PRT
Posted: Wed Aug 26, 2020 7:26 pm
by mousecnc
Thanks for the reply I had to put this back on hold for now but I did get the heart beat back by only having the e stop hooked up and power
Re: Shopbot PRT
Posted: Sun Aug 30, 2020 4:18 pm
by mousecnc
This is how I have my gecko hooked up I am getting a heart beat and the gecko is powered up and sending power to the stepper but can't get the stepper to move
Re: Shopbot PRT
Posted: Sun Aug 30, 2020 4:43 pm
by Gary Campbell
Look at the new schematics for the gecko's. You should be connected to the DB25 header
Re: Shopbot PRT
Posted: Sun Aug 30, 2020 6:47 pm
by mousecnc
When I looked at the gecko drive info in the wizard it said screw terminal
Re: Shopbot PRT
Posted: Sun Aug 30, 2020 7:21 pm
Picture is blurry, WHICH model Gecko drive is it.
Recently, it was decided that 5v logic drives SHOULD be connected to the DB25, NOT the headers.
Maybe the schematic you are looking at has not been updated. Which schematic number are you referring to?
Re: Shopbot PRT
Posted: Sun Aug 30, 2020 7:25 pm
by Richards
The screw terminals sink 24v. If you're using the Gecko 203v, it needs a 2.5v to 5v source signal. It's common is ground. In other words, you would have to do a lot of engineering to get ia 203v to work with the screw terminals.
Re: Shopbot PRT
Posted: Sun Aug 30, 2020 8:14 pm
by mousecnc
OkK where s a good place to get a breakout board. I was just going on the wizard info
Re: Shopbot PRT
Posted: Sun Aug 30, 2020 8:30 pm
Amazon. Search DB25 male breakout board
Re: Shopbot PRT
Posted: Mon Aug 31, 2020 1:17 pm
by mousecnc
Couple of questions does the screw terminals and DB25 both send a signal at the same time or do they have to be assigned in the wizard. also Is there a way to check is there is a signal going out
Re: Shopbot PRT
Posted: Mon Aug 31, 2020 1:25 pm
mousecnc wrote: ↑Mon Aug 31, 2020 1:17 pm
Same time. Hook up a stepper driver and motor to test
Do go into the Wizard DB25 Signal Mapping and make sure it is set to DB25 port
