Re: Spindlebenchtest
Posted: Sat Apr 04, 2020 3:33 pm
Report:
Reported Generated: Sat Apr 4 15:27:49 2020
MPU11 serial number: 925192286
Version:
CNC12-D Mill v4.14
Machine Timers info
Power On : 000013.678
Job in Progress : 000000.000
Spindle Running : 000000.000
Since : 03/14/2020
Operating System info:
Edition : Windows 10 Enterprise (10.0)
Version : 1909
OS Build : 18363.720
Memory info:
Total physical memory : 17048702976
Available physical memory : 14942408704
Processor info:
Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz
Number of cores : 2
Number of logical processors : 4
Display Size: Width 1920 Height 1080
Installed Software:
Mill software installed
Mill Demo not installed
Lathe software not installed
Lathe Demo not installed
Configuration file
CNC12 Jogboard v. 4.140 setup file for MPU11 serial number 925192286
DRO display units: Inches
Machine units: Inches
Max spindle (high range): 3000.0
Min spindle (high range): 0.0
Machine home at pwrup: Jog
PLC type: Standard
Jog Panel type Jogboard
Jog panel required: No
Remote Drive & Directory:
Fourth axis level offset 0
Fifth axis level offset 0
Axis Slow Jog Fast Jog (-) Fast Jog (+) Slow Jog Probe Fast Jog (-) Probe Fast Jog (+) Probe Max Rate Deadstart Delta Vmax
(in/min) (in/min) (in/min) (in/min) (in/min) (in/min) (in/min) (in/min) (in/min)
1 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
2 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
3 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
4 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
5 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
6 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
7 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
8 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
Axis Label Motor Encoder Lash Comp. Limit Home Dir Screw
revs/in counts/rev. (inches) - + - + Rev Comp
1 X 5.0000000000000000 8000 0.0000 1 2 1 2 N N
2 Y 5.0000000000000000 8000 0.0000 3 4 3 4 N N
3 Z 5.0000000000000000 8000 0.0000 5 6 5 6 N N
4 N 5.0000000000000000 8000 0.0000 0 0 7 7 N N
5 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
6 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
7 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
8 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
Axis Kp Ki Kd Limit Kg Kv1 Ka Accel
X 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
Y 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
Z 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
N 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
Job file
Last job file: c:\cncm\ncfiles\spindlebenchtest.cnc
Part count: 0 Edge Finder Diameter: 0.0000
PID Collection Axis: 1 Density: 1 Extension:
Move Commands: 1
2
3
4
5
WCS: #1 X axis Y axis Z axis N axis N axis N axis N axis N axis
G52 Shift Distance: 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
Home State: Not set Not set Not set Not set Not set Not set Not set Not set
Tool Reference: Not set Not set Not set Not set Not set Not set Not set Not set
Digitize Grid Radial Grid Radial
Filename: Multi Patch: No
Replay Feedrate: 3.0000 3.0000 Pattern: Zig Zag Zig Zag
Envelope: X 1.0000 S 0.00 Step: X 0.0100 0.0100
Y 1.0000 E 90.00 Y 0.0100
R 1.0000
Z Depth: 1.0000 1.0000 Z Step: 0.1000 0.0100
Grid First Axis: 0 Radial containment: Full Clearance Ht: 0.0100
No Job Progress Recorded. Program Stack Level (PSL) = -1
Perform 'Forced' Tool Change: Yes
Tool in spindle: 255
ATC Error code: 0
Saved user variable values:
#150 = 0.0000
#151 = 0.0000
#152 = 0.0000
#153 = 0.0000
#154 = 0.0000
#155 = 0.0000
#156 = 0.0000
#157 = 0.0000
#158 = 0.0000
#159 = 0.0000
Machine Parameters
00 -11.00000| 20 72.00000| 40 0.00010| 60 0.00000| 80 0.00000
01 0.00000| 21 0.02000| 41 20.00000| 61 0.50000| 81 -1.00000
02 0.00000| 22 0.02000| 42 0.00000| 62 90.00000| 82 0.00000
03 0.00000| 23 0.02000| 43 0.00000| 63 1.50000| 83 0.05000
04 5.00000| 24 0.02000| 44 0.00000| 64 0.00000| 84 3.00000
05 0.00000| 25 0.68000| 45 0.00000| 65 1.00000| 85 0.00000
06 0.00000| 26 0.68000| 46 0.00000| 66 1.00000| 86 0.00000
07 0.00000| 27 0.68000| 47 0.00000| 67 1.00000| 87 24.00000
08 2.00000| 28 0.68000| 48 0.10000| 68 0.00000| 88 24.00000
09 0.00000| 29 150.00000| 49 0.00000| 69 1.00000| 89 24.00000
10 0.00000| 30 180.00000| 50 0.00000| 70 0.00100| 90 24.00000
11 50769.00000| 31 0.00000| 51 0.00000| 71 0.00000| 91 0.00000
12 0.00000| 32 25.00000| 52 0.00000| 72 0.00000| 92 0.00000
13 0.05000| 33 1.00000| 53 0.00000| 73 0.05000| 93 0.00000
14 10.00000| 34 8000.00000| 54 0.00000| 74 4.00000| 94 0.00000
15 1.00000| 35 0.00000| 55 0.00000| 75 0.00000| 95 2.00000
16 10.00000| 36 0.00000| 56 4.00000| 76 0.00000| 96 2.00000
17 0.00000| 37 10.00000| 57 0.00000| 77 0.00000| 97 2.00000
18 50771.00000| 38 0.00000| 58 0.00000| 78 0.00000| 98 2.00000
19 2.00000| 39 120.00000| 59 0.00000| 79 70.00000| 99 1.00000
100 0.00000| 120 0.10000| 140 4.00000| 160 0.00000| 180 0.00000
101 0.10000| 121 0.00200| 141 10000.00000| 161 0.00000| 181 19.20000
102 3.00000| 122 0.00020| 142 1000.00000| 162 0.00000| 182 801.00000
103 50.00000| 123 0.00000| 143 11.00000| 163 0.00000| 183 0.00000
104 0.00000| 124 0.00000| 144 0.00000| 164 0.00000| 184 10.00000
105 0.00000| 125 0.00000| 145 0.00000| 165 0.00000| 185 0.00000
106 0.00000| 126 0.00000| 146 0.00000| 166 0.00000| 186 0.00000
107 0.00000| 127 0.00000| 147 10.00000| 167 0.00000| 187 16000.00000
108 1.00000| 128 0.00000| 148 0.00000| 168 0.00000| 188 0.00000
109 1.00000| 129 0.00000| 149 1.00000| 169 0.00000| 189 0.00000
110 0.00000| 130 0.00000| 150 2.00000| 170 5.00000| 190 0.00000
111 0.00000| 131 0.00000| 151 0.00000| 171 0.00000| 191 0.00000
112 0.00000| 132 0.02000| 152 0.00000| 172 0.00000| 192 0.00000
113 0.00000| 133 0.02000| 153 0.00000| 173 0.00000| 193 0.00000
114 0.00000| 134 0.02000| 154 1.00000| 174 0.00000| 194 0.00000
115 0.00000| 135 0.02000| 155 0.00000| 175 0.00000| 195 0.00000
116 0.00000| 136 0.00000| 156 2.00000| 176 0.00000| 196 0.00000
117 0.00000| 137 0.00000| 157 2.00000| 177 0.00000| 197 0.00000
118 0.00000| 138 0.00000| 158 2.00000| 178 0.00000| 198 0.00000
119 0.00000| 139 0.00000| 159 2.00000| 179 3015.00000| 199 0.00000
200 0.00000| 220 0.00000| 240 0.10000| 260 -1.00000| 280 0.00000
201 0.00000| 221 5.00000| 241 20.00000| 261 0.00000| 281 0.00000
202 0.00000| 222 0.00500| 242 0.00000| 262 0.00000| 282 0.00000
203 0.00000| 223 400.00000| 243 0.00000| 263 0.00000| 283 0.00000
204 0.00000| 224 0.00000| 244 0.00000| 264 0.00000| 284 50.00000
205 0.00000| 225 4.00000| 245 0.00000| 265 0.00000| 285 50.00000
206 0.00000| 226 1.00000| 246 0.00000| 266 0.00000| 286 50.00000
207 0.00000| 227 95.00000| 247 0.00000| 267 0.00000| 287 50.00000
208 0.12500| 228 0.00000| 248 0.00000| 268 0.00000| 288 50.00000
209 0.12500| 229 0.00000| 249 0.00000| 269 0.00000| 289 50.00000
210 0.12500| 230 1.00000| 250 0.00000| 270 0.00000| 290 50.00000
211 0.12500| 231 1.00000| 251 0.00000| 271 0.00000| 291 50.00000
212 0.12500| 232 0.00000| 252 24.00000| 272 0.00000| 292 0.00000
213 0.12500| 233 0.00000| 253 24.00000| 273 0.00000| 293 0.00000
214 0.12500| 234 0.00000| 254 24.00000| 274 0.00000| 294 0.00000
215 0.12500| 235 0.00000| 255 24.00000| 275 0.00000| 295 0.00000
216 0.00000| 236 0.68000| 256 0.00000| 276 0.00000| 296 0.00000
217 0.00000| 237 0.68000| 257 0.00000| 277 0.00000| 297 0.00000
218 0.00000| 238 0.68000| 258 0.00000| 278 0.00000| 298 0.00000
219 1.00000| 239 0.68000| 259 0.00000| 279 0.00000| 299 0.00000
300 1.00000| 320 0.00000| 340 0.00000| 360 0.00000| 380 0.00000
301 2.00000| 321 0.00000| 341 0.00000| 361 0.00000| 381 54.00000
302 3.00000| 322 0.00000| 342 0.00000| 362 0.00000| 382 55.00000
303 0.00000| 323 127.00000| 343 0.00000| 363 0.00000| 383 0.00000
304 0.00000| 324 0.00000| 344 0.00000| 364 0.00000| 384 0.00000
305 0.00000| 325 0.00000| 345 0.00000| 365 0.00000| 385 0.00000
306 0.00000| 326 0.00000| 346 0.00000| 366 2.00000| 386 0.00000
307 0.00000| 327 0.00000| 347 0.00000| 367 2.00000| 387 0.00000
308 1.00000| 328 0.00000| 348 0.00000| 368 4.00000| 388 0.00000
309 2.00000| 329 0.00000| 349 100.00000| 369 75.00000| 389 0.00000
310 3.00000| 330 0.00000| 350 400.00000| 370 0.00000| 390 0.00000
311 4.00000| 331 0.00000| 351 0.00000| 371 0.00000| 391 0.00000
312 5.00000| 332 0.00000| 352 100.00000| 372 0.00000| 392 0.00000
313 6.00000| 333 0.00000| 353 400.00000| 373 0.00000| 393 0.10000
314 0.00000| 334 0.00000| 354 0.00000| 374 0.00000| 394 0.10000
315 0.00000| 335 0.00000| 355 100.00000| 375 0.00000| 395 30.00000
316 0.00000| 336 0.00000| 356 400.00000| 376 0.00000| 396 30.00000
317 0.00000| 337 0.00000| 357 0.00000| 377 0.00000| 397 0.25000
318 0.00000| 338 0.00000| 358 0.00000| 378 0.00000| 398 0.00000
319 0.00000| 339 0.00000| 359 0.00000| 379 0.00000| 399 0.50000
400 0.00000| 420 0.00000| 440 0.00000| 460 0.00000| 480 0.00000
401 0.00000| 421 0.00000| 441 0.00000| 461 0.00000| 481 0.00000
402 0.00000| 422 0.00000| 442 0.00000| 462 0.00000| 482 0.00000
403 0.00000| 423 0.00000| 443 0.00000| 463 0.00000| 483 0.00000
404 0.00000| 424 0.00000| 444 0.00000| 464 0.00000| 484 0.00000
405 0.00000| 425 0.00000| 445 0.00000| 465 0.00000| 485 0.00000
406 0.00000| 426 0.00000| 446 0.00000| 466 0.00000| 486 0.00000
407 0.00000| 427 0.00000| 447 0.00000| 467 0.00000| 487 0.00000
408 0.00000| 428 0.00000| 448 0.00000| 468 0.00000| 488 0.00000
409 0.00000| 429 0.00000| 449 0.00000| 469 0.00000| 489 0.00000
410 0.00000| 430 0.00000| 450 0.00000| 470 0.00000| 490 0.00000
411 0.00000| 431 0.00000| 451 0.00000| 471 0.00000| 491 0.00000
412 0.00000| 432 0.00000| 452 0.00000| 472 0.00000| 492 0.00000
413 0.00000| 433 0.00000| 453 0.00000| 473 0.00000| 493 0.00000
414 0.00000| 434 0.00000| 454 0.00000| 474 0.00000| 494 0.00000
415 0.00000| 435 0.00000| 455 0.00000| 475 0.00000| 495 0.00000
416 0.00000| 436 0.00000| 456 0.00000| 476 0.00000| 496 0.00000
417 0.00000| 437 0.00000| 457 0.00000| 477 0.00000| 497 0.00000
418 0.00000| 438 0.00000| 458 0.00000| 478 0.00000| 498 0.00000
419 0.00000| 439 0.00000| 459 0.00000| 479 0.00000| 499 0.00000
500 0.00000| 520 0.00000| 540 0.00000| 560 0.00000| 580 0.00000
501 0.00000| 521 0.00000| 541 0.00000| 561 0.00000| 581 0.00000
502 0.00000| 522 0.00000| 542 0.00000| 562 0.00000| 582 0.00000
503 0.00000| 523 0.00000| 543 0.00000| 563 0.00000| 583 0.00000
504 0.00000| 524 0.00000| 544 0.00000| 564 0.00000| 584 0.00000
505 0.00000| 525 0.00000| 545 0.00000| 565 0.00000| 585 0.00000
506 0.00000| 526 0.00000| 546 0.00000| 566 0.00000| 586 0.00000
507 0.00000| 527 0.00000| 547 0.00000| 567 0.00000| 587 0.00000
508 0.00000| 528 0.00000| 548 0.00000| 568 0.00000| 588 0.00000
509 0.00000| 529 0.00000| 549 0.00000| 569 0.00000| 589 0.00000
510 0.00000| 530 0.00000| 550 0.00000| 570 0.00000| 590 0.00000
511 0.00000| 531 0.00000| 551 0.00000| 571 0.00000| 591 0.00000
512 0.00000| 532 0.00000| 552 0.00000| 572 0.00000| 592 0.00000
513 0.00000| 533 0.00000| 553 0.00000| 573 0.00000| 593 0.00000
514 0.00000| 534 0.00000| 554 0.00000| 574 0.00000| 594 0.00000
515 0.00000| 535 0.00000| 555 0.00000| 575 0.00000| 595 0.00000
516 0.00000| 536 0.00000| 556 0.00000| 576 0.00000| 596 0.00000
517 0.00000| 537 0.00000| 557 0.00000| 577 0.00000| 597 0.00000
518 0.00000| 538 0.00000| 558 0.00000| 578 0.00000| 598 0.00000
519 0.00000| 539 0.00000| 559 0.00000| 579 0.00000| 599 0.00000
600 0.00000| 620 0.00000| 640 0.00000| 660 0.00000| 680 0.00000
601 0.00000| 621 0.00000| 641 0.00000| 661 0.00000| 681 0.00000
602 0.00000| 622 0.00000| 642 0.00000| 662 0.00000| 682 0.00000
603 0.00000| 623 0.00000| 643 0.00000| 663 0.00000| 683 0.00000
604 0.00000| 624 0.00000| 644 0.00000| 664 0.00000| 684 0.00000
605 0.00000| 625 0.00000| 645 0.00000| 665 0.00000| 685 0.00000
606 0.00000| 626 0.00000| 646 0.00000| 666 0.00000| 686 0.00000
607 0.00000| 627 0.00000| 647 0.00000| 667 0.00000| 687 0.00000
608 0.00000| 628 0.00000| 648 0.00000| 668 0.00000| 688 0.00000
609 0.00000| 629 0.00000| 649 0.00000| 669 0.00000| 689 0.00000
610 0.00000| 630 0.00000| 650 0.00000| 670 0.00000| 690 0.00000
611 0.00000| 631 0.00000| 651 0.00000| 671 0.00000| 691 0.00000
612 0.00000| 632 0.00000| 652 0.00000| 672 0.00000| 692 0.00000
613 0.00000| 633 0.00000| 653 0.00000| 673 0.00000| 693 0.00000
614 0.00000| 634 0.00000| 654 0.00000| 674 0.00000| 694 0.00000
615 0.00000| 635 0.00000| 655 0.00000| 675 0.00000| 695 0.00000
616 0.00000| 636 0.00000| 656 0.00000| 676 0.00000| 696 0.00000
617 0.00000| 637 0.00000| 657 0.00000| 677 0.00000| 697 0.00000
618 0.00000| 638 0.00000| 658 0.00000| 678 0.00000| 698 0.00000
619 0.00000| 639 0.00000| 659 0.00000| 679 0.00000| 699 0.00000
700 0.00000| 720 0.00000| 740 0.00000| 760 0.00000| 780 0.00000
701 0.00000| 721 0.00000| 741 0.00000| 761 0.00000| 781 0.00000
702 0.00000| 722 0.00000| 742 0.00000| 762 0.00000| 782 0.00000
703 0.00000| 723 0.00000| 743 0.00000| 763 0.00000| 783 0.00000
704 0.00000| 724 0.00000| 744 0.00000| 764 0.00000| 784 0.00000
705 0.00000| 725 0.00000| 745 0.00000| 765 0.00000| 785 0.00000
706 0.00000| 726 0.00000| 746 0.00000| 766 0.00000| 786 0.00000
707 0.00000| 727 0.00000| 747 0.00000| 767 0.00000| 787 0.00000
708 0.00000| 728 0.00000| 748 0.00000| 768 0.00000| 788 0.00000
709 0.00000| 729 0.00000| 749 0.00000| 769 0.00000| 789 0.00000
710 0.00000| 730 0.00000| 750 0.00000| 770 0.00000| 790 0.00000
711 0.00000| 731 0.00000| 751 0.00000| 771 0.00000| 791 0.00000
712 0.00000| 732 0.00000| 752 0.00000| 772 0.00000| 792 0.00000
713 0.00000| 733 0.00000| 753 0.00000| 773 0.00000| 793 0.00000
714 0.00000| 734 0.00000| 754 0.00000| 774 0.00000| 794 0.00000
715 0.00000| 735 0.00000| 755 0.00000| 775 0.00000| 795 0.00000
716 0.00000| 736 0.00000| 756 0.00000| 776 0.00000| 796 0.00000
717 0.00000| 737 0.00000| 757 0.00000| 777 0.00000| 797 0.00000
718 0.00000| 738 0.00000| 758 0.00000| 778 0.00000| 798 0.00000
719 0.00000| 739 0.00000| 759 0.00000| 779 0.00000| 799 0.00000
800 0.00000| 820 0.00000| 840 0.00000| 860 0.00000| 880 0.00000
801 0.00000| 821 0.00000| 841 0.00000| 861 0.00000| 881 0.00000
802 0.00000| 822 0.00000| 842 0.00000| 862 0.00000| 882 0.00000
803 0.00000| 823 0.00000| 843 0.00000| 863 0.00000| 883 0.00000
804 0.00000| 824 0.00000| 844 0.00000| 864 0.00000| 884 0.00000
805 0.00000| 825 0.00000| 845 0.00000| 865 0.00000| 885 0.00000
806 0.00000| 826 0.00000| 846 0.00000| 866 0.00000| 886 0.00000
807 0.00000| 827 0.00000| 847 0.00000| 867 0.00000| 887 0.00000
808 0.00000| 828 0.00000| 848 0.00000| 868 0.00000| 888 0.00000
809 0.00000| 829 0.00000| 849 0.00000| 869 0.00000| 889 0.00000
810 0.00000| 830 0.00000| 850 0.00000| 870 0.00000| 890 0.00000
811 0.00000| 831 0.00000| 851 0.00000| 871 0.00000| 891 0.00000
812 0.00000| 832 0.00000| 852 0.00000| 872 0.00000| 892 0.00000
813 0.00000| 833 0.00000| 853 0.00000| 873 0.00000| 893 0.00000
814 0.00000| 834 0.00000| 854 0.00000| 874 0.00000| 894 0.00000
815 0.00000| 835 0.00000| 855 0.00000| 875 0.00000| 895 0.00000
816 0.00000| 836 0.00000| 856 0.00000| 876 0.00000| 896 0.00000
817 0.00000| 837 0.00000| 857 0.00000| 877 0.00000| 897 0.00000
818 0.00000| 838 0.00000| 858 0.00000| 878 0.00000| 898 0.00000
819 0.00000| 839 0.00000| 859 0.00000| 879 0.00000| 899 0.00000
900 0.00000| 920 0.00000| 940 0.00000| 960 0.00000| 980 0.00000
901 0.00000| 921 0.00000| 941 0.00000| 961 0.00000| 981 0.00000
902 0.00000| 922 0.00000| 942 0.00000| 962 0.00000| 982 0.00000
903 0.00000| 923 0.00000| 943 0.00000| 963 0.00000| 983 0.00000
904 0.00000| 924 0.00000| 944 0.00000| 964 0.00000| 984 0.00000
905 0.00000| 925 0.00000| 945 0.00000| 965 0.00000| 985 0.00000
906 0.00000| 926 0.00000| 946 0.00000| 966 0.00000| 986 0.00000
907 0.00000| 927 0.00000| 947 0.00000| 967 0.00000| 987 0.00000
908 0.00000| 928 0.00000| 948 0.00000| 968 0.00000| 988 0.00000
909 0.00000| 929 0.00000| 949 0.00000| 969 0.00000| 989 0.00000
910 0.00000| 930 0.00000| 950 0.00000| 970 0.00000| 990 0.00000
911 2046.00000| 931 0.00000| 951 0.00000| 971 0.00000| 991 0.00000
912 15.00000| 932 0.00000| 952 0.00000| 972 0.00000| 992 0.00000
913 0.00000| 933 0.00000| 953 0.00000| 973 0.00000| 993 0.00000
914 0.00000| 934 0.00000| 954 0.00000| 974 0.00000| 994 0.00000
915 0.00000| 935 0.00000| 955 0.00000| 975 0.00000| 995 0.00000
916 0.00000| 936 0.00000| 956 0.00000| 976 0.00000| 996 0.00000
917 0.00000| 937 0.00000| 957 0.00000| 977 0.00000| 997 0.00000
918 0.00000| 938 0.00000| 958 0.00000| 978 0.00000| 998 0.00000
919 0.00000| 939 0.00000| 959 0.00000| 979 0.00000| 999 0.00000
Machine Parameters
P0 = -11.00000 - E-Stop PLC Bit Number
P1 = 0.00000 - Y Jog Key Orientation
P2 = 0.00000 - G-Code Interpretation Control
P3 = 0.00000 - Modal Tool and Height Offset Control
P4 = 5.00000 - File Load Options
P5 = 0.00000 - Suppress Machine Home Setup
P6 = 0.00000 - Auto Tool Changer Installed
P7 = 0.00000 - Display Colors
P8 = 2.00000 - Available Coolant System(s)
P9 = 0.00000 - DISPLAY LANGUAGE 0=ENG 1=SPA 2=FRC 3=ROC 4=PRC 5=DEU 6=SWE 7=FIN 8=POR 9=POL 10=ELL
P10 = 0.00000 - Macro M-Function Control. Display M and G codes in M function macros ADD 1. Step through M function macros in Block Mode ADD 2. Decel on M105 and M106 ADD 4. Do NOT Move to Z home on M6 ADD 8.
P11 = 50769.00000 - Touch Probe PLC Input
P12 = 0.00000 - Touch Probe Tool Number
P13 = 0.05000 - Probing Recovery Distance
P14 = 10.00000 - Fast Probing Rate
P15 = 1.00000 - Slow Probing Rate
P16 = 10.00000 - Probing Search Distance
P17 = 0.00000 - Tool Detector Reference Number
P18 = 50771.00000 - PLC Input Spindle Inhibitor
P19 = 2.00000 - MPG Modes: Add 4 Enable Z axis MPG
P20 = 72.00000 - Ambient Temperature
P21 = 0.02000 - X Axis Heating Coefficient
P22 = 0.02000 - Y Axis Heating Coefficient
P23 = 0.02000 - Z Axis Heating Coefficient
P24 = 0.02000 - 4th Axis Heating Coefficient
P25 = 0.68000 - X Axis Cooling Coefficient
P26 = 0.68000 - Y Axis Cooling Coefficient
P27 = 0.68000 - Z Axis Cooling Coefficient
P28 = 0.68000 - 4th Axis Cooling Coefficient
P29 = 150.00000 - Overheat Warning Temperature
P30 = 180.00000 - Job Cancellation Temperature
P31 = 0.00000 - Legacy SPIN232 COM Port
P32 = 25.00000 -
P33 = 1.00000 - Spindle Motor Gear Ratio
P34 = 8000.00000 - Spindle Encoder Counts/Revolution
P35 = 0.00000 - Spindle Axis 1-8, 0 = disabled
P36 = 0.00000 - Rigid Tapping Enable/Disable
P37 = 10.00000 - Spindle Deceleration Time
P38 = 0.00000 - Multi-Axis Maximum Feedrate
P39 = 120.00000 - Feedrate Override Percentage Limit
P40 = 0.00010 - Basic Jog Increment
P41 = 20.00000 - Rotary Axis Jog Increment
P42 = 0.00000 - Configuration Password
P43 = 0.00000 - Auto Tool Measurement: Add 1 to Subtract height of TT-1, Add 2 to use TT1 input for setting Z ref Add 4 to get a warning connect TT-1 cable during batch tool measurement
P44 = 0.00000 - TT1 plc input
P45 = 0.00000 - WCS Lockout
P46 = 0.00000 - Active G-Codes Display 0: Always 1: MDI Only 2: Never
P47 = 0.00000 - Not used
P48 = 0.10000 - 'Rapid to' clearance amount for playback of Grid Digitizing output data
P49 = 0.00000 - Small Arc Feedrate Limiting - Lower Limits
P50 = 0.00000 - Small Arc Feedrate Limiting - Upper Limits
P51 = 0.00000 - Small Arc Feedrate Limiting Mode
P52 = 0.00000 - Reserved: Do Not Modify
P53 = 0.00000 - Reserved: Do Not Modify
P54 = 0.00000 - Not Used
P55 = 0.00000 - Not Used
P56 = 4.00000 - Override Properties: 2=Programmed Feedrate, 4=Meters On, 8=Inverse Time in Seconds
P57 = 0.00000 - Axis Bitmap for Generic Meter
P58 = 0.00000 - Not Used
P59 = 0.00000 - Not Used
P60 = 0.00000 - Not Used
P61 = 0.50000 - High Power Stall Time Limit
P62 = 90.00000 - High Power Stall PID Threshold
P63 = 1.50000 - High Power Idle PID Multiplier
P64 = 0.00000 - 4th/5th Axis Pairing
P65 = 1.00000 - Low Range Spindle Gear Ratio
P66 = 1.00000 - Medium-Low Range Spindle Gear Ratio
P67 = 1.00000 - Medium-High Range Spindle Gear Ratio
P68 = 0.00000 - Minimum Rigid Tapping Spindle Speed
P69 = 1.00000 - Duration for Minimum Spindle Speed
P70 = 0.00100 - Offset Library Inc/Decrement Amount
P71 = 0.00000 - Part Setup Detector Height
P72 = 0.00000 - M120-M123 options: suppress labels=1, insert commas=2, suppress spaces=4
P73 = 0.05000 - G73 Canned Cycle Parameter
P74 = 4.00000 - G74 Canned Cycle Parameter
P75 = 0.00000 - Axis Summing Display Control
P76 = 0.00000 - Manual Input Unrestricted Distance
P77 = 0.00000 - Manual Input Movement Tolerance
P78 = 0.00000 - Display of Spindle Speed: add 1 Override feedrate if spindle boggs down add 2 Wait for spindle at speed add 4 NOTE: All 3 functions require spindle encoder feedback.
P79 = 70.00000 - Paired Axes Resync Delay Time
P80 = 0.00000 - Voltage Brake Message Frequency
P81 = -1.00000 - G81 Canned Cycle Parameter
P82 = 0.00000 - Spindle Drift Adjustment
P83 = 0.05000 - G83 Canned Cycle Parameter
P84 = 3.00000 - G84 Canned Cycle Parameter
P85 = 0.00000 - Door closed interlock
P86 = 0.00000 - Vector Optimization
P87 = 24.00000 - X Axis Autotune Accel Time and Ka
P88 = 24.00000 - Y Axis Autotune Accel Time and Ka
P89 = 24.00000 - Z Axis Autotune Accel Time and Ka
P90 = 24.00000 - 4th Axis Autotune Accel Time and Ka
P91 = 0.00000 - X AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P92 = 0.00000 - Y AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P93 = 0.00000 - Z AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Suppress dir check during tool check ADD 4, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P94 = 0.00000 - 4th AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, 4th axis responds like Z axis ADD 64, Tilt rotary axis ADD 256 Hide axis display ADD 512
P95 = 2.00000 - X Axis Autotune Move Distance
P96 = 2.00000 - Y Axis Autotune Move Distance
P97 = 2.00000 - Z Axis Autotune Move Distance
P98 = 2.00000 - 4th Axis Autotune Move Distance
P99 = 1.00000 - Lookahead Number of Events
P100 = 0.00000 - Intercon comment generation: 0 = FALSE,1 = TRUE
P101 = 0.10000 - Intercon clearance amount
P102 = 3.00000 - Intercon spindle coolant delay
P103 = 50.00000 - Intercon corner feedrate override
P104 = 0.00000 - Intercon modal line parameters: 0 = FALSE,1 = TRUE
P105 = 0.00000 - Intercon modal arc parameters: 0 = FALSE,1 = TRUE
P106 = 0.00000 - Intercon modal drilling cycle parameters: 0 = FALSE,1 = TRUE
P107 = 0.00000 - Not Used
P108 = 1.00000 - Not Used
P109 = 1.00000 - Not Used
P110 = 0.00000 - Not Used
P111 = 0.00000 - Not Used
P112 = 0.00000 - Not Used
P113 = 0.00000 - Not Used
P114 = 0.00000 - Not Used
P115 = 0.00000 - Intercon help: 0 = OFF, 1 = ON
P116 = 0.00000 - A axis Y coordinate
P117 = 0.00000 - A axis Z coordinate
P118 = 0.00000 - B axis X coordinate
P119 = 0.00000 - B axis Z coordinate
P120 = 0.10000 - Probe stuck clearance amount
P121 = 0.00200 - Grid digitizing prediction minimum Z pullback
P122 = 0.00020 - Grid digitizing deadband move distance
P123 = 0.00000 - Radial digitizing clearance move
P124 = 0.00000 - PLC input for jogging
P125 = 0.00000 - PLC input for jogging
P126 = 0.00000 - PLC input for jogging
P127 = 0.00000 - PLC input for jogging
P128 = 0.00000 - Not Used
P129 = 0.00000 - Not Used
P130 = 0.00000 - Z axis on/off selection
P131 = 0.00000 - Fourth axis on/off selection
P132 = 0.02000 - 5th Axis Heating Coefficient
P133 = 0.02000 - 6th Axis Heating Coefficient
P134 = 0.02000 - 7th Axis Heating Coefficient
P135 = 0.02000 - 8th Axis Heating Coefficient
P136 = 0.00000 - G76 Fine Bore Retract Angle (0-359) 0 = Y+, 90 = X-, 180 = Y-, 270 = X+
P137 = 0.00000 - Load Meter Filter Size
P138 = 0.00000 - DRO Encoder Deadband Count
P139 = 0.00000 - Special Dwell between moves
P140 = 4.00000 - Message log priority level
P141 = 10000.00000 - Maximum message log lines
P142 = 1000.00000 - Message log trim amount
P143 = 11.00000 - DRO properties: 1=load meters, 2=meter outline, 4=5 dig DRO prec, 8=Mini DRO on
P144 = 0.00000 - Comparison Roundoff: 0=none, 1-9=significant digits after decimal.
P145 = 0.00000 - Branching properties: 1=fast branch enabled
P146 = 0.00000 - Feed hold threshold for feedrate override
P147 = 10.00000 - Number of items to keep in Operator Message Window
P148 = 0.00000 - Miscellaneous Jogging Options. Enable Fast Jog before Home Set ADD 1. Prohibit Keyboard Jogging ADD 2.
P149 = 1.00000 - Spindle Speed wait percent (0.5 - 1.0)
P150 = 2.00000 - Run-Time Graphics: Add 1, Show CSR in backplot: Add 2, Disable backplot machine geometry: Add 4, Enable display of Skew Correction in backplot: Add 8, Enable display of PC-based Backlash correction or Screw Comp in backplot: Add 16
P151 = 0.00000 - Probe Repeatability Tolerance
P152 = 0.00000 - Not Used
P153 = 0.00000 - Probe Protection 0: Off 1: On
P154 = 1.00000 - Touch Screen Options
P155 = 0.00000 - Probe Settings : Standard Probe = 0, DSP Probe = 1, DP7 Probe = 2
P156 = 2.00000 - 5th Axis Autotune Move Distance
P157 = 2.00000 - 6th Axis Autotune Move Distance
P158 = 2.00000 - 7th Axis Autotune Move Distance
P159 = 2.00000 - 8th Axis Autotune Move Distance
P160 = 0.00000 - Enhanced ATC: 0 = Off, 1 = Nonrandom, 2 = Random
P161 = 0.00000 - ATC Maximum Tool Bins
P162 = 0.00000 - Intercon M6 Initial M-Code
P163 = 0.00000 - Not Used
P164 = 0.00000 - ATC feature bit
P165 = 0.00000 - Acceleration / Deceleration Options
P166 = 0.00000 - 5th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P167 = 0.00000 - 6th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P168 = 0.00000 - 7th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P169 = 0.00000 - 8th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P170 = 5.00000 - PLC Parameter LP0
P171 = 0.00000 - PLC Parameter LP1
P172 = 0.00000 - PLC Parameter LP2
P173 = 0.00000 - PLC Parameter LP3
P174 = 0.00000 - PLC Parameter LP4
P175 = 0.00000 - PLC Parameter LP5
P176 = 0.00000 - PLC Parameter LP6
P177 = 0.00000 - PLC Parameter LP7
P178 = 0.00000 - PLC Parameter LP8
P179 = 3015.00000 - PLC Parameter LP9
P180 = 0.00000 - Serial Comm - COM port (1-4)
P181 = 19.20000 - Serial Comm - Baud rate (Kbps)
P182 = 801.00000 - Serial Comm - Data, Parity, Stop
P183 = 0.00000 - Serial Comm - Flow control
P184 = 10.00000 - Serial Comm - Timeout (in seconds)
P185 = 0.00000 - Serial Comm - Options
P186 = 0.00000 - Probe stuck retry disable
P187 = 16000.00000 - Hard Stop Limit for Homing
P188 = 0.00000 - Aux 1 Key Function
P189 = 0.00000 - Aux 2 Key Function
P190 = 0.00000 - Aux 3 Key Function
P191 = 0.00000 - Aux 4 Key Function
P192 = 0.00000 - Aux 5 Key Function
P193 = 0.00000 - Aux 6 Key Function
P194 = 0.00000 - Aux 7 Key Function
P195 = 0.00000 - Aux 8 Key Function
P196 = 0.00000 - Aux 9 Key Function
P197 = 0.00000 - Aux 10 Key Function
P198 = 0.00000 - Aux 11 Key Function
P199 = 0.00000 - Aux 12 Key Function
P200 = 0.00000 - Axis 1 (X) Tach volts per 1000 rpm
P201 = 0.00000 - Axis 2 (Y) Tach volts per 1000 rpm
P202 = 0.00000 - Axis 3 (Z) Tach volts per 1000 rpm
P203 = 0.00000 - Axis 4 (N) Tach volts per 1000 rpm
P204 = 0.00000 - Axis 5 (N) Tach volts per 1000 rpm
P205 = 0.00000 - Axis 6 (N) Tach volts per 1000 rpm
P206 = 0.00000 - Axis 7 (N) Tach volts per 1000 rpm
P207 = 0.00000 - Axis 8 (N) Tach volts per 1000 rpm
P208 = 0.12500 - Axis 1 (X) Lash/Screw Comp Acceleration Coefficient
P209 = 0.12500 - Axis 2 (Y) Lash/Screw Comp Acceleration Coefficient
P210 = 0.12500 - Axis 3 (Z) Lash/Screw Comp Acceleration Coefficient
P211 = 0.12500 - Axis 4 (N) Lash/Screw Comp Acceleration Coefficient
P212 = 0.12500 - Axis 5 (N) Lash/Screw Comp Acceleration Coefficient
P213 = 0.12500 - Axis 6 (N) Lash/Screw Comp Acceleration Coefficient
P214 = 0.12500 - Axis 7 (N) Lash/Screw Comp Acceleration Coefficient
P215 = 0.12500 - Axis 8 (N) Lash/Screw Comp Acceleration Coefficient
P216 = 0.00000 - PC-based backlash on/off: 1=PC-based, 0=MPU backlash
P217 = 0.00000 - PC-based Screw comp on/off: 1=PC-based, 0=MPU based
P218 = 0.00000 - USB MPG Options. ADD 1 = Axis 1 enabled. ADD 2 = Axis 2 enabled. ADD 4 = Axis 3 enabled. ADD 8 = Axis 4 enabled.
P219 = 1.00000 - Virtual Control Panel Options
P220 = 0.00000 - Smoothing mode on/off 1=on 0=off
P221 = 5.00000 - Smoothing Amount to round corners and smooth geometry (NBpts) Rounded corners can be cut faster, but check tolerances (see next)
P222 = 0.00500 - Smoothing Step size (STEP) Rounding Error is roughly (Parameter 221 * Parameter 222) / 3
P223 = 400.00000 - Smoothing vectors per second -- leave this at 800 (Umax)
P224 = 0.00000 - Smoothing Centripetal options: 0 = All axes and NO checking for excess accel -1 = Linear axes only and NO checking for excess accel -2 = All axes WITH checking for excess accel -3 = Linear axes only WITH checking for excess accel
P225 = 4.00000 - Unused
P226 = 1.00000 - Smoothing Filter half-width for feature detection (W) Increase this value to smooth over small glitches in your gcode programs
P227 = 95.00000 - Smoothing Minimum angle for feature detection (Min_Angle) Machine will round corners that are wider than this angle
P228 = 0.00000 - Smoothing S-Curve Filter Multiplier (S Curve) Set this to 0 to turn off S-Curve, 1 for full S-Curve, Between 0 and 1 for partial
P229 = 0.00000 - Smoothing Movements Drawn in Backplot Set this to 1 to use Smoothing for Backplotting (slows it down considerably)
P230 = 1.00000 - Smoothing Curve Feedrate Multiplier Increase this value to make your machine run faster (but bang more) -- 1 is normal
P231 = 1.00000 - Smoothing Acceleration Multiplier Increase this value to make your machine accelerate faster than normal -- 1 is normal
P232 = 0.00000 - Not Used
P233 = 0.00000 - Not Used
P234 = 0.00000 - Not Used
P235 = 0.00000 - Not Used
P236 = 0.68000 - 5th Axis Cooling Coefficient
P237 = 0.68000 - 6th Axis Cooling Coefficient
P238 = 0.68000 - 7th Axis Cooling Coefficient
P239 = 0.68000 - 8th Axis Cooling Coefficient
P240 = 0.10000 - Accel/Decel distance for Rigid Tapping
P241 = 20.00000 - Accel/Decel rotational step size (in degrees) for Rigid Tapping
P242 = 0.00000 - Not Used
P243 = 0.00000 - Not Used
P244 = 0.00000 - Not Used
P245 = 0.00000 - Not Used
P246 = 0.00000 - Not Used
P247 = 0.00000 - Not Used
P248 = 0.00000 - Not Used
P249 = 0.00000 - Not Used
P250 = 0.00000 - Not Used
P251 = 0.00000 - Not Used
P252 = 24.00000 - 5th Axis Autotune Accel Time and Ka
P253 = 24.00000 - 6th Axis Autotune Accel Time and Ka
P254 = 24.00000 - 7th Axis Autotune Accel Time and Ka
P255 = 24.00000 - 8th Axis Autotune Accel Time and Ka
P256 = 0.00000 - Drive Mode: 0 = Torque (Autotune Enabled) 1 = Velocity (Autotune Disabled) 2 = Precision (Auto Delay Enabled, Enables the Precision Mode Delay Parameters)
P257 = 0.00000 - Tool Touchoff Detect
P258 = 0.00000 - Velocity/Torque Mode override in Precision mode. Setting an axis bit allows that axis to run as if it were in velocity or torque mode, but prone to servo mismatch errors.
P259 = 0.00000 - Manual Axis Bits
P260 = -1.00000 - Accelerated Graphics Backplot... 1 = On, -1 = Off
P261 = 0.00000 - Precision Mode Standoff Tolerance Percentage
P262 = 0.00000 - Precision Mode Standoff Delay Time (seconds)
P263 = 0.00000 - Not Used
P264 = 0.00000 - Not Used
P265 = 0.00000 - Rotary A Axis Scale Encoder Home Position - DO NOT MODIFY EXCEPT TO SET TO ZERO FOR RECALIBRATION
P266 = 0.00000 - Rotary A Axis Scale Encoder Sign Extension - DO NO MODIFY
P267 = 0.00000 - Not Used
P268 = 0.00000 - Not Used
P269 = 0.00000 - Not Used
P270 = 0.00000 - Skew Correction: X Skew offset from Trusted/Intended X
P271 = 0.00000 - Skew Correction: Trusted/Intended Y
P272 = 0.00000 - Not Used
P273 = 0.00000 - Not Used
P274 = 0.00000 - Not Used
P275 = 0.00000 - Not Used
P276 = 0.00000 - Not Used
P277 = 0.00000 - Not Used
P278 = 0.00000 - Spindle Speed Display Precision
P279 = 0.00000 - Not Used
P280 = 0.00000 - Not Used
P281 = 0.00000 - Not Used
P282 = 0.00000 - Not Used
P283 = 0.00000 - Not Used
P284 = 50.00000 - ACDC Drive 1 Brake Resistor Wattage
P285 = 50.00000 - ACDC Drive 2 Brake Resistor Wattage
P286 = 50.00000 - ACDC Drive 3 Brake Resistor Wattage
P287 = 50.00000 - ACDC Drive 4 Brake Resistor Wattage
P288 = 50.00000 - ACDC Drive 5 Brake Resistor Wattage
P289 = 50.00000 - ACDC Drive 6 Brake Resistor Wattage
P290 = 50.00000 - ACDC Drive 7 Brake Resistor Wattage
P291 = 50.00000 - ACDC Drive 8 Brake Resistor Wattage
P292 = 0.00000 - Not Used
P293 = 0.00000 - Not Used
P294 = 0.00000 - Not Used
P295 = 0.00000 - Not Used
P296 = 0.00000 - Not Used
P297 = 0.00000 - Not Used
P298 = 0.00000 - Not Used
Version:
CNC12-D Mill v4.14
Machine Timers info
Since : 03/14/2020
Version : 1909
Memory info:
Processor info:
Number of cores : 2
Installed Software:
Configuration file
PLC type: Standard
Job file
Move Commands: 1
2
3
4
5
R 1.0000
ATC Error code: 0
#150 = 0.0000
#151 = 0.0000
#152 = 0.0000
#153 = 0.0000
#154 = 0.0000
#155 = 0.0000
#156 = 0.0000
#157 = 0.0000
#158 = 0.0000
#159 = 0.0000
Machine Parameters
Machine Parameters
P32 = 25.00000 -
