Spindlebenchtest
Beagle Beagle
CNC Control System Serial Number: A900779
Re: Spindlebenchtest
Post by Beagle Beagle »
Report:
Reported Generated: Sat Apr 4 15:27:49 2020
MPU11 serial number: 925192286
Version:
CNC12-D Mill v4.14
Machine Timers info
Power On : 000013.678
Job in Progress : 000000.000
Spindle Running : 000000.000
Since : 03/14/2020
Operating System info:
Edition : Windows 10 Enterprise (10.0)
Version : 1909
OS Build : 18363.720
Memory info:
Total physical memory : 17048702976
Available physical memory : 14942408704
Processor info:
Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz
Number of cores : 2
Number of logical processors : 4
Display Size: Width 1920 Height 1080
Installed Software:
Mill software installed
Mill Demo not installed
Lathe software not installed
Lathe Demo not installed
Configuration file
CNC12 Jogboard v. 4.140 setup file for MPU11 serial number 925192286
DRO display units: Inches
Machine units: Inches
Max spindle (high range): 3000.0
Min spindle (high range): 0.0
Machine home at pwrup: Jog
PLC type: Standard
Jog Panel type Jogboard
Jog panel required: No
Remote Drive & Directory:
Fourth axis level offset 0
Fifth axis level offset 0
Axis Slow Jog Fast Jog (-) Fast Jog (+) Slow Jog Probe Fast Jog (-) Probe Fast Jog (+) Probe Max Rate Deadstart Delta Vmax
(in/min) (in/min) (in/min) (in/min) (in/min) (in/min) (in/min) (in/min) (in/min)
1 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
2 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
3 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
4 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
5 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
6 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
7 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
8 25.0000 100.0000 100.0000 25.0000 100.0000 100.0000 300.0000 3.0000 3.0000
Axis Label Motor Encoder Lash Comp. Limit Home Dir Screw
revs/in counts/rev. (inches) - + - + Rev Comp
1 X 5.0000000000000000 8000 0.0000 1 2 1 2 N N
2 Y 5.0000000000000000 8000 0.0000 3 4 3 4 N N
3 Z 5.0000000000000000 8000 0.0000 5 6 5 6 N N
4 N 5.0000000000000000 8000 0.0000 0 0 7 7 N N
5 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
6 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
7 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
8 N 5.0000000000000000 8000 0.0000 0 0 0 0 N N
Axis Kp Ki Kd Limit Kg Kv1 Ka Accel
X 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
Y 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
Z 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
N 1.0000 0.004000 3.0000 32000 0.0000 0.0000 0.0000 0.5000
Job file
Last job file: c:\cncm\ncfiles\spindlebenchtest.cnc
Part count: 0 Edge Finder Diameter: 0.0000
PID Collection Axis: 1 Density: 1 Extension:
Move Commands: 1
2
3
4
5
WCS: #1 X axis Y axis Z axis N axis N axis N axis N axis N axis
G52 Shift Distance: 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
Home State: Not set Not set Not set Not set Not set Not set Not set Not set
Tool Reference: Not set Not set Not set Not set Not set Not set Not set Not set
Digitize Grid Radial Grid Radial
Filename: Multi Patch: No
Replay Feedrate: 3.0000 3.0000 Pattern: Zig Zag Zig Zag
Envelope: X 1.0000 S 0.00 Step: X 0.0100 0.0100
Y 1.0000 E 90.00 Y 0.0100
R 1.0000
Z Depth: 1.0000 1.0000 Z Step: 0.1000 0.0100
Grid First Axis: 0 Radial containment: Full Clearance Ht: 0.0100
No Job Progress Recorded. Program Stack Level (PSL) = -1
Perform 'Forced' Tool Change: Yes
Tool in spindle: 255
ATC Error code: 0
Saved user variable values:
#150 = 0.0000
#151 = 0.0000
#152 = 0.0000
#153 = 0.0000
#154 = 0.0000
#155 = 0.0000
#156 = 0.0000
#157 = 0.0000
#158 = 0.0000
#159 = 0.0000
Machine Parameters
00 -11.00000| 20 72.00000| 40 0.00010| 60 0.00000| 80 0.00000
01 0.00000| 21 0.02000| 41 20.00000| 61 0.50000| 81 -1.00000
02 0.00000| 22 0.02000| 42 0.00000| 62 90.00000| 82 0.00000
03 0.00000| 23 0.02000| 43 0.00000| 63 1.50000| 83 0.05000
04 5.00000| 24 0.02000| 44 0.00000| 64 0.00000| 84 3.00000
05 0.00000| 25 0.68000| 45 0.00000| 65 1.00000| 85 0.00000
06 0.00000| 26 0.68000| 46 0.00000| 66 1.00000| 86 0.00000
07 0.00000| 27 0.68000| 47 0.00000| 67 1.00000| 87 24.00000
08 2.00000| 28 0.68000| 48 0.10000| 68 0.00000| 88 24.00000
09 0.00000| 29 150.00000| 49 0.00000| 69 1.00000| 89 24.00000
10 0.00000| 30 180.00000| 50 0.00000| 70 0.00100| 90 24.00000
11 50769.00000| 31 0.00000| 51 0.00000| 71 0.00000| 91 0.00000
12 0.00000| 32 25.00000| 52 0.00000| 72 0.00000| 92 0.00000
13 0.05000| 33 1.00000| 53 0.00000| 73 0.05000| 93 0.00000
14 10.00000| 34 8000.00000| 54 0.00000| 74 4.00000| 94 0.00000
15 1.00000| 35 0.00000| 55 0.00000| 75 0.00000| 95 2.00000
16 10.00000| 36 0.00000| 56 4.00000| 76 0.00000| 96 2.00000
17 0.00000| 37 10.00000| 57 0.00000| 77 0.00000| 97 2.00000
18 50771.00000| 38 0.00000| 58 0.00000| 78 0.00000| 98 2.00000
19 2.00000| 39 120.00000| 59 0.00000| 79 70.00000| 99 1.00000
100 0.00000| 120 0.10000| 140 4.00000| 160 0.00000| 180 0.00000
101 0.10000| 121 0.00200| 141 10000.00000| 161 0.00000| 181 19.20000
102 3.00000| 122 0.00020| 142 1000.00000| 162 0.00000| 182 801.00000
103 50.00000| 123 0.00000| 143 11.00000| 163 0.00000| 183 0.00000
104 0.00000| 124 0.00000| 144 0.00000| 164 0.00000| 184 10.00000
105 0.00000| 125 0.00000| 145 0.00000| 165 0.00000| 185 0.00000
106 0.00000| 126 0.00000| 146 0.00000| 166 0.00000| 186 0.00000
107 0.00000| 127 0.00000| 147 10.00000| 167 0.00000| 187 16000.00000
108 1.00000| 128 0.00000| 148 0.00000| 168 0.00000| 188 0.00000
109 1.00000| 129 0.00000| 149 1.00000| 169 0.00000| 189 0.00000
110 0.00000| 130 0.00000| 150 2.00000| 170 5.00000| 190 0.00000
111 0.00000| 131 0.00000| 151 0.00000| 171 0.00000| 191 0.00000
112 0.00000| 132 0.02000| 152 0.00000| 172 0.00000| 192 0.00000
113 0.00000| 133 0.02000| 153 0.00000| 173 0.00000| 193 0.00000
114 0.00000| 134 0.02000| 154 1.00000| 174 0.00000| 194 0.00000
115 0.00000| 135 0.02000| 155 0.00000| 175 0.00000| 195 0.00000
116 0.00000| 136 0.00000| 156 2.00000| 176 0.00000| 196 0.00000
117 0.00000| 137 0.00000| 157 2.00000| 177 0.00000| 197 0.00000
118 0.00000| 138 0.00000| 158 2.00000| 178 0.00000| 198 0.00000
119 0.00000| 139 0.00000| 159 2.00000| 179 3015.00000| 199 0.00000
200 0.00000| 220 0.00000| 240 0.10000| 260 -1.00000| 280 0.00000
201 0.00000| 221 5.00000| 241 20.00000| 261 0.00000| 281 0.00000
202 0.00000| 222 0.00500| 242 0.00000| 262 0.00000| 282 0.00000
203 0.00000| 223 400.00000| 243 0.00000| 263 0.00000| 283 0.00000
204 0.00000| 224 0.00000| 244 0.00000| 264 0.00000| 284 50.00000
205 0.00000| 225 4.00000| 245 0.00000| 265 0.00000| 285 50.00000
206 0.00000| 226 1.00000| 246 0.00000| 266 0.00000| 286 50.00000
207 0.00000| 227 95.00000| 247 0.00000| 267 0.00000| 287 50.00000
208 0.12500| 228 0.00000| 248 0.00000| 268 0.00000| 288 50.00000
209 0.12500| 229 0.00000| 249 0.00000| 269 0.00000| 289 50.00000
210 0.12500| 230 1.00000| 250 0.00000| 270 0.00000| 290 50.00000
211 0.12500| 231 1.00000| 251 0.00000| 271 0.00000| 291 50.00000
212 0.12500| 232 0.00000| 252 24.00000| 272 0.00000| 292 0.00000
213 0.12500| 233 0.00000| 253 24.00000| 273 0.00000| 293 0.00000
214 0.12500| 234 0.00000| 254 24.00000| 274 0.00000| 294 0.00000
215 0.12500| 235 0.00000| 255 24.00000| 275 0.00000| 295 0.00000
216 0.00000| 236 0.68000| 256 0.00000| 276 0.00000| 296 0.00000
217 0.00000| 237 0.68000| 257 0.00000| 277 0.00000| 297 0.00000
218 0.00000| 238 0.68000| 258 0.00000| 278 0.00000| 298 0.00000
219 1.00000| 239 0.68000| 259 0.00000| 279 0.00000| 299 0.00000
300 1.00000| 320 0.00000| 340 0.00000| 360 0.00000| 380 0.00000
301 2.00000| 321 0.00000| 341 0.00000| 361 0.00000| 381 54.00000
302 3.00000| 322 0.00000| 342 0.00000| 362 0.00000| 382 55.00000
303 0.00000| 323 127.00000| 343 0.00000| 363 0.00000| 383 0.00000
304 0.00000| 324 0.00000| 344 0.00000| 364 0.00000| 384 0.00000
305 0.00000| 325 0.00000| 345 0.00000| 365 0.00000| 385 0.00000
306 0.00000| 326 0.00000| 346 0.00000| 366 2.00000| 386 0.00000
307 0.00000| 327 0.00000| 347 0.00000| 367 2.00000| 387 0.00000
308 1.00000| 328 0.00000| 348 0.00000| 368 4.00000| 388 0.00000
309 2.00000| 329 0.00000| 349 100.00000| 369 75.00000| 389 0.00000
310 3.00000| 330 0.00000| 350 400.00000| 370 0.00000| 390 0.00000
311 4.00000| 331 0.00000| 351 0.00000| 371 0.00000| 391 0.00000
312 5.00000| 332 0.00000| 352 100.00000| 372 0.00000| 392 0.00000
313 6.00000| 333 0.00000| 353 400.00000| 373 0.00000| 393 0.10000
314 0.00000| 334 0.00000| 354 0.00000| 374 0.00000| 394 0.10000
315 0.00000| 335 0.00000| 355 100.00000| 375 0.00000| 395 30.00000
316 0.00000| 336 0.00000| 356 400.00000| 376 0.00000| 396 30.00000
317 0.00000| 337 0.00000| 357 0.00000| 377 0.00000| 397 0.25000
318 0.00000| 338 0.00000| 358 0.00000| 378 0.00000| 398 0.00000
319 0.00000| 339 0.00000| 359 0.00000| 379 0.00000| 399 0.50000
400 0.00000| 420 0.00000| 440 0.00000| 460 0.00000| 480 0.00000
401 0.00000| 421 0.00000| 441 0.00000| 461 0.00000| 481 0.00000
402 0.00000| 422 0.00000| 442 0.00000| 462 0.00000| 482 0.00000
403 0.00000| 423 0.00000| 443 0.00000| 463 0.00000| 483 0.00000
404 0.00000| 424 0.00000| 444 0.00000| 464 0.00000| 484 0.00000
405 0.00000| 425 0.00000| 445 0.00000| 465 0.00000| 485 0.00000
406 0.00000| 426 0.00000| 446 0.00000| 466 0.00000| 486 0.00000
407 0.00000| 427 0.00000| 447 0.00000| 467 0.00000| 487 0.00000
408 0.00000| 428 0.00000| 448 0.00000| 468 0.00000| 488 0.00000
409 0.00000| 429 0.00000| 449 0.00000| 469 0.00000| 489 0.00000
410 0.00000| 430 0.00000| 450 0.00000| 470 0.00000| 490 0.00000
411 0.00000| 431 0.00000| 451 0.00000| 471 0.00000| 491 0.00000
412 0.00000| 432 0.00000| 452 0.00000| 472 0.00000| 492 0.00000
413 0.00000| 433 0.00000| 453 0.00000| 473 0.00000| 493 0.00000
414 0.00000| 434 0.00000| 454 0.00000| 474 0.00000| 494 0.00000
415 0.00000| 435 0.00000| 455 0.00000| 475 0.00000| 495 0.00000
416 0.00000| 436 0.00000| 456 0.00000| 476 0.00000| 496 0.00000
417 0.00000| 437 0.00000| 457 0.00000| 477 0.00000| 497 0.00000
418 0.00000| 438 0.00000| 458 0.00000| 478 0.00000| 498 0.00000
419 0.00000| 439 0.00000| 459 0.00000| 479 0.00000| 499 0.00000
500 0.00000| 520 0.00000| 540 0.00000| 560 0.00000| 580 0.00000
501 0.00000| 521 0.00000| 541 0.00000| 561 0.00000| 581 0.00000
502 0.00000| 522 0.00000| 542 0.00000| 562 0.00000| 582 0.00000
503 0.00000| 523 0.00000| 543 0.00000| 563 0.00000| 583 0.00000
504 0.00000| 524 0.00000| 544 0.00000| 564 0.00000| 584 0.00000
505 0.00000| 525 0.00000| 545 0.00000| 565 0.00000| 585 0.00000
506 0.00000| 526 0.00000| 546 0.00000| 566 0.00000| 586 0.00000
507 0.00000| 527 0.00000| 547 0.00000| 567 0.00000| 587 0.00000
508 0.00000| 528 0.00000| 548 0.00000| 568 0.00000| 588 0.00000
509 0.00000| 529 0.00000| 549 0.00000| 569 0.00000| 589 0.00000
510 0.00000| 530 0.00000| 550 0.00000| 570 0.00000| 590 0.00000
511 0.00000| 531 0.00000| 551 0.00000| 571 0.00000| 591 0.00000
512 0.00000| 532 0.00000| 552 0.00000| 572 0.00000| 592 0.00000
513 0.00000| 533 0.00000| 553 0.00000| 573 0.00000| 593 0.00000
514 0.00000| 534 0.00000| 554 0.00000| 574 0.00000| 594 0.00000
515 0.00000| 535 0.00000| 555 0.00000| 575 0.00000| 595 0.00000
516 0.00000| 536 0.00000| 556 0.00000| 576 0.00000| 596 0.00000
517 0.00000| 537 0.00000| 557 0.00000| 577 0.00000| 597 0.00000
518 0.00000| 538 0.00000| 558 0.00000| 578 0.00000| 598 0.00000
519 0.00000| 539 0.00000| 559 0.00000| 579 0.00000| 599 0.00000
600 0.00000| 620 0.00000| 640 0.00000| 660 0.00000| 680 0.00000
601 0.00000| 621 0.00000| 641 0.00000| 661 0.00000| 681 0.00000
602 0.00000| 622 0.00000| 642 0.00000| 662 0.00000| 682 0.00000
603 0.00000| 623 0.00000| 643 0.00000| 663 0.00000| 683 0.00000
604 0.00000| 624 0.00000| 644 0.00000| 664 0.00000| 684 0.00000
605 0.00000| 625 0.00000| 645 0.00000| 665 0.00000| 685 0.00000
606 0.00000| 626 0.00000| 646 0.00000| 666 0.00000| 686 0.00000
607 0.00000| 627 0.00000| 647 0.00000| 667 0.00000| 687 0.00000
608 0.00000| 628 0.00000| 648 0.00000| 668 0.00000| 688 0.00000
609 0.00000| 629 0.00000| 649 0.00000| 669 0.00000| 689 0.00000
610 0.00000| 630 0.00000| 650 0.00000| 670 0.00000| 690 0.00000
611 0.00000| 631 0.00000| 651 0.00000| 671 0.00000| 691 0.00000
612 0.00000| 632 0.00000| 652 0.00000| 672 0.00000| 692 0.00000
613 0.00000| 633 0.00000| 653 0.00000| 673 0.00000| 693 0.00000
614 0.00000| 634 0.00000| 654 0.00000| 674 0.00000| 694 0.00000
615 0.00000| 635 0.00000| 655 0.00000| 675 0.00000| 695 0.00000
616 0.00000| 636 0.00000| 656 0.00000| 676 0.00000| 696 0.00000
617 0.00000| 637 0.00000| 657 0.00000| 677 0.00000| 697 0.00000
618 0.00000| 638 0.00000| 658 0.00000| 678 0.00000| 698 0.00000
619 0.00000| 639 0.00000| 659 0.00000| 679 0.00000| 699 0.00000
700 0.00000| 720 0.00000| 740 0.00000| 760 0.00000| 780 0.00000
701 0.00000| 721 0.00000| 741 0.00000| 761 0.00000| 781 0.00000
702 0.00000| 722 0.00000| 742 0.00000| 762 0.00000| 782 0.00000
703 0.00000| 723 0.00000| 743 0.00000| 763 0.00000| 783 0.00000
704 0.00000| 724 0.00000| 744 0.00000| 764 0.00000| 784 0.00000
705 0.00000| 725 0.00000| 745 0.00000| 765 0.00000| 785 0.00000
706 0.00000| 726 0.00000| 746 0.00000| 766 0.00000| 786 0.00000
707 0.00000| 727 0.00000| 747 0.00000| 767 0.00000| 787 0.00000
708 0.00000| 728 0.00000| 748 0.00000| 768 0.00000| 788 0.00000
709 0.00000| 729 0.00000| 749 0.00000| 769 0.00000| 789 0.00000
710 0.00000| 730 0.00000| 750 0.00000| 770 0.00000| 790 0.00000
711 0.00000| 731 0.00000| 751 0.00000| 771 0.00000| 791 0.00000
712 0.00000| 732 0.00000| 752 0.00000| 772 0.00000| 792 0.00000
713 0.00000| 733 0.00000| 753 0.00000| 773 0.00000| 793 0.00000
714 0.00000| 734 0.00000| 754 0.00000| 774 0.00000| 794 0.00000
715 0.00000| 735 0.00000| 755 0.00000| 775 0.00000| 795 0.00000
716 0.00000| 736 0.00000| 756 0.00000| 776 0.00000| 796 0.00000
717 0.00000| 737 0.00000| 757 0.00000| 777 0.00000| 797 0.00000
718 0.00000| 738 0.00000| 758 0.00000| 778 0.00000| 798 0.00000
719 0.00000| 739 0.00000| 759 0.00000| 779 0.00000| 799 0.00000
800 0.00000| 820 0.00000| 840 0.00000| 860 0.00000| 880 0.00000
801 0.00000| 821 0.00000| 841 0.00000| 861 0.00000| 881 0.00000
802 0.00000| 822 0.00000| 842 0.00000| 862 0.00000| 882 0.00000
803 0.00000| 823 0.00000| 843 0.00000| 863 0.00000| 883 0.00000
804 0.00000| 824 0.00000| 844 0.00000| 864 0.00000| 884 0.00000
805 0.00000| 825 0.00000| 845 0.00000| 865 0.00000| 885 0.00000
806 0.00000| 826 0.00000| 846 0.00000| 866 0.00000| 886 0.00000
807 0.00000| 827 0.00000| 847 0.00000| 867 0.00000| 887 0.00000
808 0.00000| 828 0.00000| 848 0.00000| 868 0.00000| 888 0.00000
809 0.00000| 829 0.00000| 849 0.00000| 869 0.00000| 889 0.00000
810 0.00000| 830 0.00000| 850 0.00000| 870 0.00000| 890 0.00000
811 0.00000| 831 0.00000| 851 0.00000| 871 0.00000| 891 0.00000
812 0.00000| 832 0.00000| 852 0.00000| 872 0.00000| 892 0.00000
813 0.00000| 833 0.00000| 853 0.00000| 873 0.00000| 893 0.00000
814 0.00000| 834 0.00000| 854 0.00000| 874 0.00000| 894 0.00000
815 0.00000| 835 0.00000| 855 0.00000| 875 0.00000| 895 0.00000
816 0.00000| 836 0.00000| 856 0.00000| 876 0.00000| 896 0.00000
817 0.00000| 837 0.00000| 857 0.00000| 877 0.00000| 897 0.00000
818 0.00000| 838 0.00000| 858 0.00000| 878 0.00000| 898 0.00000
819 0.00000| 839 0.00000| 859 0.00000| 879 0.00000| 899 0.00000
900 0.00000| 920 0.00000| 940 0.00000| 960 0.00000| 980 0.00000
901 0.00000| 921 0.00000| 941 0.00000| 961 0.00000| 981 0.00000
902 0.00000| 922 0.00000| 942 0.00000| 962 0.00000| 982 0.00000
903 0.00000| 923 0.00000| 943 0.00000| 963 0.00000| 983 0.00000
904 0.00000| 924 0.00000| 944 0.00000| 964 0.00000| 984 0.00000
905 0.00000| 925 0.00000| 945 0.00000| 965 0.00000| 985 0.00000
906 0.00000| 926 0.00000| 946 0.00000| 966 0.00000| 986 0.00000
907 0.00000| 927 0.00000| 947 0.00000| 967 0.00000| 987 0.00000
908 0.00000| 928 0.00000| 948 0.00000| 968 0.00000| 988 0.00000
909 0.00000| 929 0.00000| 949 0.00000| 969 0.00000| 989 0.00000
910 0.00000| 930 0.00000| 950 0.00000| 970 0.00000| 990 0.00000
911 2046.00000| 931 0.00000| 951 0.00000| 971 0.00000| 991 0.00000
912 15.00000| 932 0.00000| 952 0.00000| 972 0.00000| 992 0.00000
913 0.00000| 933 0.00000| 953 0.00000| 973 0.00000| 993 0.00000
914 0.00000| 934 0.00000| 954 0.00000| 974 0.00000| 994 0.00000
915 0.00000| 935 0.00000| 955 0.00000| 975 0.00000| 995 0.00000
916 0.00000| 936 0.00000| 956 0.00000| 976 0.00000| 996 0.00000
917 0.00000| 937 0.00000| 957 0.00000| 977 0.00000| 997 0.00000
918 0.00000| 938 0.00000| 958 0.00000| 978 0.00000| 998 0.00000
919 0.00000| 939 0.00000| 959 0.00000| 979 0.00000| 999 0.00000
Machine Parameters
P0 = -11.00000 - E-Stop PLC Bit Number
P1 = 0.00000 - Y Jog Key Orientation
P2 = 0.00000 - G-Code Interpretation Control
P3 = 0.00000 - Modal Tool and Height Offset Control
P4 = 5.00000 - File Load Options
P5 = 0.00000 - Suppress Machine Home Setup
P6 = 0.00000 - Auto Tool Changer Installed
P7 = 0.00000 - Display Colors
P8 = 2.00000 - Available Coolant System(s)
P9 = 0.00000 - DISPLAY LANGUAGE 0=ENG 1=SPA 2=FRC 3=ROC 4=PRC 5=DEU 6=SWE 7=FIN 8=POR 9=POL 10=ELL
P10 = 0.00000 - Macro M-Function Control. Display M and G codes in M function macros ADD 1. Step through M function macros in Block Mode ADD 2. Decel on M105 and M106 ADD 4. Do NOT Move to Z home on M6 ADD 8.
P11 = 50769.00000 - Touch Probe PLC Input
P12 = 0.00000 - Touch Probe Tool Number
P13 = 0.05000 - Probing Recovery Distance
P14 = 10.00000 - Fast Probing Rate
P15 = 1.00000 - Slow Probing Rate
P16 = 10.00000 - Probing Search Distance
P17 = 0.00000 - Tool Detector Reference Number
P18 = 50771.00000 - PLC Input Spindle Inhibitor
P19 = 2.00000 - MPG Modes: Add 4 Enable Z axis MPG
P20 = 72.00000 - Ambient Temperature
P21 = 0.02000 - X Axis Heating Coefficient
P22 = 0.02000 - Y Axis Heating Coefficient
P23 = 0.02000 - Z Axis Heating Coefficient
P24 = 0.02000 - 4th Axis Heating Coefficient
P25 = 0.68000 - X Axis Cooling Coefficient
P26 = 0.68000 - Y Axis Cooling Coefficient
P27 = 0.68000 - Z Axis Cooling Coefficient
P28 = 0.68000 - 4th Axis Cooling Coefficient
P29 = 150.00000 - Overheat Warning Temperature
P30 = 180.00000 - Job Cancellation Temperature
P31 = 0.00000 - Legacy SPIN232 COM Port
P32 = 25.00000 -
P33 = 1.00000 - Spindle Motor Gear Ratio
P34 = 8000.00000 - Spindle Encoder Counts/Revolution
P35 = 0.00000 - Spindle Axis 1-8, 0 = disabled
P36 = 0.00000 - Rigid Tapping Enable/Disable
P37 = 10.00000 - Spindle Deceleration Time
P38 = 0.00000 - Multi-Axis Maximum Feedrate
P39 = 120.00000 - Feedrate Override Percentage Limit
P40 = 0.00010 - Basic Jog Increment
P41 = 20.00000 - Rotary Axis Jog Increment
P42 = 0.00000 - Configuration Password
P43 = 0.00000 - Auto Tool Measurement: Add 1 to Subtract height of TT-1, Add 2 to use TT1 input for setting Z ref Add 4 to get a warning connect TT-1 cable during batch tool measurement
P44 = 0.00000 - TT1 plc input
P45 = 0.00000 - WCS Lockout
P46 = 0.00000 - Active G-Codes Display 0: Always 1: MDI Only 2: Never
P47 = 0.00000 - Not used
P48 = 0.10000 - 'Rapid to' clearance amount for playback of Grid Digitizing output data
P49 = 0.00000 - Small Arc Feedrate Limiting - Lower Limits
P50 = 0.00000 - Small Arc Feedrate Limiting - Upper Limits
P51 = 0.00000 - Small Arc Feedrate Limiting Mode
P52 = 0.00000 - Reserved: Do Not Modify
P53 = 0.00000 - Reserved: Do Not Modify
P54 = 0.00000 - Not Used
P55 = 0.00000 - Not Used
P56 = 4.00000 - Override Properties: 2=Programmed Feedrate, 4=Meters On, 8=Inverse Time in Seconds
P57 = 0.00000 - Axis Bitmap for Generic Meter
P58 = 0.00000 - Not Used
P59 = 0.00000 - Not Used
P60 = 0.00000 - Not Used
P61 = 0.50000 - High Power Stall Time Limit
P62 = 90.00000 - High Power Stall PID Threshold
P63 = 1.50000 - High Power Idle PID Multiplier
P64 = 0.00000 - 4th/5th Axis Pairing
P65 = 1.00000 - Low Range Spindle Gear Ratio
P66 = 1.00000 - Medium-Low Range Spindle Gear Ratio
P67 = 1.00000 - Medium-High Range Spindle Gear Ratio
P68 = 0.00000 - Minimum Rigid Tapping Spindle Speed
P69 = 1.00000 - Duration for Minimum Spindle Speed
P70 = 0.00100 - Offset Library Inc/Decrement Amount
P71 = 0.00000 - Part Setup Detector Height
P72 = 0.00000 - M120-M123 options: suppress labels=1, insert commas=2, suppress spaces=4
P73 = 0.05000 - G73 Canned Cycle Parameter
P74 = 4.00000 - G74 Canned Cycle Parameter
P75 = 0.00000 - Axis Summing Display Control
P76 = 0.00000 - Manual Input Unrestricted Distance
P77 = 0.00000 - Manual Input Movement Tolerance
P78 = 0.00000 - Display of Spindle Speed: add 1 Override feedrate if spindle boggs down add 2 Wait for spindle at speed add 4 NOTE: All 3 functions require spindle encoder feedback.
P79 = 70.00000 - Paired Axes Resync Delay Time
P80 = 0.00000 - Voltage Brake Message Frequency
P81 = -1.00000 - G81 Canned Cycle Parameter
P82 = 0.00000 - Spindle Drift Adjustment
P83 = 0.05000 - G83 Canned Cycle Parameter
P84 = 3.00000 - G84 Canned Cycle Parameter
P85 = 0.00000 - Door closed interlock
P86 = 0.00000 - Vector Optimization
P87 = 24.00000 - X Axis Autotune Accel Time and Ka
P88 = 24.00000 - Y Axis Autotune Accel Time and Ka
P89 = 24.00000 - Z Axis Autotune Accel Time and Ka
P90 = 24.00000 - 4th Axis Autotune Accel Time and Ka
P91 = 0.00000 - X AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P92 = 0.00000 - Y AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P93 = 0.00000 - Z AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Suppress dir check during tool check ADD 4, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P94 = 0.00000 - 4th AXIS Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, 4th axis responds like Z axis ADD 64, Tilt rotary axis ADD 256 Hide axis display ADD 512
P95 = 2.00000 - X Axis Autotune Move Distance
P96 = 2.00000 - Y Axis Autotune Move Distance
P97 = 2.00000 - Z Axis Autotune Move Distance
P98 = 2.00000 - 4th Axis Autotune Move Distance
P99 = 1.00000 - Lookahead Number of Events
P100 = 0.00000 - Intercon comment generation: 0 = FALSE,1 = TRUE
P101 = 0.10000 - Intercon clearance amount
P102 = 3.00000 - Intercon spindle coolant delay
P103 = 50.00000 - Intercon corner feedrate override
P104 = 0.00000 - Intercon modal line parameters: 0 = FALSE,1 = TRUE
P105 = 0.00000 - Intercon modal arc parameters: 0 = FALSE,1 = TRUE
P106 = 0.00000 - Intercon modal drilling cycle parameters: 0 = FALSE,1 = TRUE
P107 = 0.00000 - Not Used
P108 = 1.00000 - Not Used
P109 = 1.00000 - Not Used
P110 = 0.00000 - Not Used
P111 = 0.00000 - Not Used
P112 = 0.00000 - Not Used
P113 = 0.00000 - Not Used
P114 = 0.00000 - Not Used
P115 = 0.00000 - Intercon help: 0 = OFF, 1 = ON
P116 = 0.00000 - A axis Y coordinate
P117 = 0.00000 - A axis Z coordinate
P118 = 0.00000 - B axis X coordinate
P119 = 0.00000 - B axis Z coordinate
P120 = 0.10000 - Probe stuck clearance amount
P121 = 0.00200 - Grid digitizing prediction minimum Z pullback
P122 = 0.00020 - Grid digitizing deadband move distance
P123 = 0.00000 - Radial digitizing clearance move
P124 = 0.00000 - PLC input for jogging
P125 = 0.00000 - PLC input for jogging
P126 = 0.00000 - PLC input for jogging
P127 = 0.00000 - PLC input for jogging
P128 = 0.00000 - Not Used
P129 = 0.00000 - Not Used
P130 = 0.00000 - Z axis on/off selection
P131 = 0.00000 - Fourth axis on/off selection
P132 = 0.02000 - 5th Axis Heating Coefficient
P133 = 0.02000 - 6th Axis Heating Coefficient
P134 = 0.02000 - 7th Axis Heating Coefficient
P135 = 0.02000 - 8th Axis Heating Coefficient
P136 = 0.00000 - G76 Fine Bore Retract Angle (0-359) 0 = Y+, 90 = X-, 180 = Y-, 270 = X+
P137 = 0.00000 - Load Meter Filter Size
P138 = 0.00000 - DRO Encoder Deadband Count
P139 = 0.00000 - Special Dwell between moves
P140 = 4.00000 - Message log priority level
P141 = 10000.00000 - Maximum message log lines
P142 = 1000.00000 - Message log trim amount
P143 = 11.00000 - DRO properties: 1=load meters, 2=meter outline, 4=5 dig DRO prec, 8=Mini DRO on
P144 = 0.00000 - Comparison Roundoff: 0=none, 1-9=significant digits after decimal.
P145 = 0.00000 - Branching properties: 1=fast branch enabled
P146 = 0.00000 - Feed hold threshold for feedrate override
P147 = 10.00000 - Number of items to keep in Operator Message Window
P148 = 0.00000 - Miscellaneous Jogging Options. Enable Fast Jog before Home Set ADD 1. Prohibit Keyboard Jogging ADD 2.
P149 = 1.00000 - Spindle Speed wait percent (0.5 - 1.0)
P150 = 2.00000 - Run-Time Graphics: Add 1, Show CSR in backplot: Add 2, Disable backplot machine geometry: Add 4, Enable display of Skew Correction in backplot: Add 8, Enable display of PC-based Backlash correction or Screw Comp in backplot: Add 16
P151 = 0.00000 - Probe Repeatability Tolerance
P152 = 0.00000 - Not Used
P153 = 0.00000 - Probe Protection 0: Off 1: On
P154 = 1.00000 - Touch Screen Options
P155 = 0.00000 - Probe Settings : Standard Probe = 0, DSP Probe = 1, DP7 Probe = 2
P156 = 2.00000 - 5th Axis Autotune Move Distance
P157 = 2.00000 - 6th Axis Autotune Move Distance
P158 = 2.00000 - 7th Axis Autotune Move Distance
P159 = 2.00000 - 8th Axis Autotune Move Distance
P160 = 0.00000 - Enhanced ATC: 0 = Off, 1 = Nonrandom, 2 = Random
P161 = 0.00000 - ATC Maximum Tool Bins
P162 = 0.00000 - Intercon M6 Initial M-Code
P163 = 0.00000 - Not Used
P164 = 0.00000 - ATC feature bit
P165 = 0.00000 - Acceleration / Deceleration Options
P166 = 0.00000 - 5th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P167 = 0.00000 - 6th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P168 = 0.00000 - 7th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P169 = 0.00000 - 8th Axis Properties: Rotary axis ADD 1, Rotary display wrap around ADD 2, Supress park function ADD 8, Linear Display of Rotory axis ADD 32, Tilt rotary axis ADD 256, Hide axis display ADD 512
P170 = 5.00000 - PLC Parameter LP0
P171 = 0.00000 - PLC Parameter LP1
P172 = 0.00000 - PLC Parameter LP2
P173 = 0.00000 - PLC Parameter LP3
P174 = 0.00000 - PLC Parameter LP4
P175 = 0.00000 - PLC Parameter LP5
P176 = 0.00000 - PLC Parameter LP6
P177 = 0.00000 - PLC Parameter LP7
P178 = 0.00000 - PLC Parameter LP8
P179 = 3015.00000 - PLC Parameter LP9
P180 = 0.00000 - Serial Comm - COM port (1-4)
P181 = 19.20000 - Serial Comm - Baud rate (Kbps)
P182 = 801.00000 - Serial Comm - Data, Parity, Stop
P183 = 0.00000 - Serial Comm - Flow control
P184 = 10.00000 - Serial Comm - Timeout (in seconds)
P185 = 0.00000 - Serial Comm - Options
P186 = 0.00000 - Probe stuck retry disable
P187 = 16000.00000 - Hard Stop Limit for Homing
P188 = 0.00000 - Aux 1 Key Function
P189 = 0.00000 - Aux 2 Key Function
P190 = 0.00000 - Aux 3 Key Function
P191 = 0.00000 - Aux 4 Key Function
P192 = 0.00000 - Aux 5 Key Function
P193 = 0.00000 - Aux 6 Key Function
P194 = 0.00000 - Aux 7 Key Function
P195 = 0.00000 - Aux 8 Key Function
P196 = 0.00000 - Aux 9 Key Function
P197 = 0.00000 - Aux 10 Key Function
P198 = 0.00000 - Aux 11 Key Function
P199 = 0.00000 - Aux 12 Key Function
P200 = 0.00000 - Axis 1 (X) Tach volts per 1000 rpm
P201 = 0.00000 - Axis 2 (Y) Tach volts per 1000 rpm
P202 = 0.00000 - Axis 3 (Z) Tach volts per 1000 rpm
P203 = 0.00000 - Axis 4 (N) Tach volts per 1000 rpm
P204 = 0.00000 - Axis 5 (N) Tach volts per 1000 rpm
P205 = 0.00000 - Axis 6 (N) Tach volts per 1000 rpm
P206 = 0.00000 - Axis 7 (N) Tach volts per 1000 rpm
P207 = 0.00000 - Axis 8 (N) Tach volts per 1000 rpm
P208 = 0.12500 - Axis 1 (X) Lash/Screw Comp Acceleration Coefficient
P209 = 0.12500 - Axis 2 (Y) Lash/Screw Comp Acceleration Coefficient
P210 = 0.12500 - Axis 3 (Z) Lash/Screw Comp Acceleration Coefficient
P211 = 0.12500 - Axis 4 (N) Lash/Screw Comp Acceleration Coefficient
P212 = 0.12500 - Axis 5 (N) Lash/Screw Comp Acceleration Coefficient
P213 = 0.12500 - Axis 6 (N) Lash/Screw Comp Acceleration Coefficient
P214 = 0.12500 - Axis 7 (N) Lash/Screw Comp Acceleration Coefficient
P215 = 0.12500 - Axis 8 (N) Lash/Screw Comp Acceleration Coefficient
P216 = 0.00000 - PC-based backlash on/off: 1=PC-based, 0=MPU backlash
P217 = 0.00000 - PC-based Screw comp on/off: 1=PC-based, 0=MPU based
P218 = 0.00000 - USB MPG Options. ADD 1 = Axis 1 enabled. ADD 2 = Axis 2 enabled. ADD 4 = Axis 3 enabled. ADD 8 = Axis 4 enabled.
P219 = 1.00000 - Virtual Control Panel Options
P220 = 0.00000 - Smoothing mode on/off 1=on 0=off
P221 = 5.00000 - Smoothing Amount to round corners and smooth geometry (NBpts) Rounded corners can be cut faster, but check tolerances (see next)
P222 = 0.00500 - Smoothing Step size (STEP) Rounding Error is roughly (Parameter 221 * Parameter 222) / 3
P223 = 400.00000 - Smoothing vectors per second -- leave this at 800 (Umax)
P224 = 0.00000 - Smoothing Centripetal options: 0 = All axes and NO checking for excess accel -1 = Linear axes only and NO checking for excess accel -2 = All axes WITH checking for excess accel -3 = Linear axes only WITH checking for excess accel
P225 = 4.00000 - Unused
P226 = 1.00000 - Smoothing Filter half-width for feature detection (W) Increase this value to smooth over small glitches in your gcode programs
P227 = 95.00000 - Smoothing Minimum angle for feature detection (Min_Angle) Machine will round corners that are wider than this angle
P228 = 0.00000 - Smoothing S-Curve Filter Multiplier (S Curve) Set this to 0 to turn off S-Curve, 1 for full S-Curve, Between 0 and 1 for partial
P229 = 0.00000 - Smoothing Movements Drawn in Backplot Set this to 1 to use Smoothing for Backplotting (slows it down considerably)
P230 = 1.00000 - Smoothing Curve Feedrate Multiplier Increase this value to make your machine run faster (but bang more) -- 1 is normal
P231 = 1.00000 - Smoothing Acceleration Multiplier Increase this value to make your machine accelerate faster than normal -- 1 is normal
P232 = 0.00000 - Not Used
P233 = 0.00000 - Not Used
P234 = 0.00000 - Not Used
P235 = 0.00000 - Not Used
P236 = 0.68000 - 5th Axis Cooling Coefficient
P237 = 0.68000 - 6th Axis Cooling Coefficient
P238 = 0.68000 - 7th Axis Cooling Coefficient
P239 = 0.68000 - 8th Axis Cooling Coefficient
P240 = 0.10000 - Accel/Decel distance for Rigid Tapping
P241 = 20.00000 - Accel/Decel rotational step size (in degrees) for Rigid Tapping
P242 = 0.00000 - Not Used
P243 = 0.00000 - Not Used
P244 = 0.00000 - Not Used
P245 = 0.00000 - Not Used
P246 = 0.00000 - Not Used
P247 = 0.00000 - Not Used
P248 = 0.00000 - Not Used
P249 = 0.00000 - Not Used
P250 = 0.00000 - Not Used
P251 = 0.00000 - Not Used
P252 = 24.00000 - 5th Axis Autotune Accel Time and Ka
P253 = 24.00000 - 6th Axis Autotune Accel Time and Ka
P254 = 24.00000 - 7th Axis Autotune Accel Time and Ka
P255 = 24.00000 - 8th Axis Autotune Accel Time and Ka
P256 = 0.00000 - Drive Mode: 0 = Torque (Autotune Enabled) 1 = Velocity (Autotune Disabled) 2 = Precision (Auto Delay Enabled, Enables the Precision Mode Delay Parameters)
P257 = 0.00000 - Tool Touchoff Detect
P258 = 0.00000 - Velocity/Torque Mode override in Precision mode. Setting an axis bit allows that axis to run as if it were in velocity or torque mode, but prone to servo mismatch errors.
P259 = 0.00000 - Manual Axis Bits
P260 = -1.00000 - Accelerated Graphics Backplot... 1 = On, -1 = Off
P261 = 0.00000 - Precision Mode Standoff Tolerance Percentage
P262 = 0.00000 - Precision Mode Standoff Delay Time (seconds)
P263 = 0.00000 - Not Used
P264 = 0.00000 - Not Used
P265 = 0.00000 - Rotary A Axis Scale Encoder Home Position - DO NOT MODIFY EXCEPT TO SET TO ZERO FOR RECALIBRATION
P266 = 0.00000 - Rotary A Axis Scale Encoder Sign Extension - DO NO MODIFY
P267 = 0.00000 - Not Used
P268 = 0.00000 - Not Used
P269 = 0.00000 - Not Used
P270 = 0.00000 - Skew Correction: X Skew offset from Trusted/Intended X
P271 = 0.00000 - Skew Correction: Trusted/Intended Y
P272 = 0.00000 - Not Used
P273 = 0.00000 - Not Used
P274 = 0.00000 - Not Used
P275 = 0.00000 - Not Used
P276 = 0.00000 - Not Used
P277 = 0.00000 - Not Used
P278 = 0.00000 - Spindle Speed Display Precision
P279 = 0.00000 - Not Used
P280 = 0.00000 - Not Used
P281 = 0.00000 - Not Used
P282 = 0.00000 - Not Used
P283 = 0.00000 - Not Used
P284 = 50.00000 - ACDC Drive 1 Brake Resistor Wattage
P285 = 50.00000 - ACDC Drive 2 Brake Resistor Wattage
P286 = 50.00000 - ACDC Drive 3 Brake Resistor Wattage
P287 = 50.00000 - ACDC Drive 4 Brake Resistor Wattage
P288 = 50.00000 - ACDC Drive 5 Brake Resistor Wattage
P289 = 50.00000 - ACDC Drive 6 Brake Resistor Wattage
P290 = 50.00000 - ACDC Drive 7 Brake Resistor Wattage
P291 = 50.00000 - ACDC Drive 8 Brake Resistor Wattage
P292 = 0.00000 - Not Used
P293 = 0.00000 - Not Used
P294 = 0.00000 - Not Used
P295 = 0.00000 - Not Used
P296 = 0.00000 - Not Used
P297 = 0.00000 - Not Used
P298 = 0.00000 - Not Used
Bridgeport V2XT, All In One DC #A900779. Using existing SEM motors 112 Volt. Spindle to be controlled by Lenze AC Tech VFD mod #ESV222N02YXB. Machine is being run on 208 3Phase power.
Beagle Beagle
Rest of report:
P299 = 0.00000 - Not Used
P300 = 1.00000 - Axis 1 (X) Drive Number
P301 = 2.00000 - Axis 2 (Y) Drive Number
P302 = 3.00000 - Axis 3 (Z) Drive Number
P303 = 0.00000 - Axis 4 (N) Drive Number
P304 = 0.00000 - Axis 5 (N) Drive Number
P305 = 0.00000 - Axis 6 (N) Drive Number
P306 = 0.00000 - Axis 7 (N) Drive Number
P307 = 0.00000 - Axis 8 (N) Drive Number
P308 = 1.00000 - Axis 1 (X) Encoder Index
P309 = 2.00000 - Axis 2 (Y) Encoder Index
P310 = 3.00000 - Axis 3 (Z) Encoder Index
P311 = 4.00000 - Axis 4 (N) Encoder Index
P312 = 5.00000 - Axis 5 (N) Encoder Index
P313 = 6.00000 - Axis 6 (N) Encoder Index
P314 = 0.00000 - Axis 7 (N) Encoder Index
P315 = 0.00000 - Axis 8 (N) Encoder Index
P316 = 0.00000 - Absolute Encoder Bits
P317 = 0.00000 - Single Turn Absolute Encoder Bits
P318 = 0.00000 - Five Axis Configuration Straight Rotary B axis Magnescale Scale Drive (1-8)
P319 = 0.00000 - Not Used
P320 = 0.00000 - Not Used
P321 = 0.00000 - Not Used
P322 = 0.00000 - Not Used
P323 = 127.00000 - MPU11 Encoder Filter Speed
P324 = 0.00000 - Axis 1 (X) Boxcar Size
P325 = 0.00000 - Axis 2 (Y) Boxcar Size
P326 = 0.00000 - Axis 3 (Z) Boxcar Size
P327 = 0.00000 - Axis 4 (N) Boxcar Size
P328 = 0.00000 - Axis 5 (N) Boxcar Size
P329 = 0.00000 - Axis 6 (N) Boxcar Size
P330 = 0.00000 - Axis 7 (N) Boxcar Size
P331 = 0.00000 - Axis 8 (N) Boxcar Size
P332 = 0.00000 - Disable differential encoder error faults
P333 = 0.00000 - Disable differential encoder error messages
P334 = 0.00000 - Disable quadrature encoder error faults
P335 = 0.00000 - Disable quadrature encoder error messages
P336 = 0.00000 - Axis meter overall gain
P337 = 0.00000 - Axis meter absolute error gain
P338 = 0.00000 - Axis meter sum error gain
P339 = 0.00000 - Axis meter delta error gain
P340 = 0.00000 - Axis 1 (X) Precision Mode delay (milliseconds)
P341 = 0.00000 - Axis 2 (Y) Precision Mode delay (milliseconds)
P342 = 0.00000 - Axis 3 (Z) Precision Mode delay (milliseconds)
P343 = 0.00000 - Axis 4 (N) Precision Mode delay (milliseconds)
P344 = 0.00000 - Axis 5 (N) Precision Mode delay (milliseconds)
P345 = 0.00000 - Axis 6 (N) Precision Mode delay (milliseconds)
P346 = 0.00000 - Axis 7 (N) Precision Mode delay (milliseconds)
P347 = 0.00000 - Axis 8 (N) Precision Mode delay (milliseconds)
P348 = 0.00000 - MPG 1 Encoder Input
P349 = 100.00000 - MPG 1 Detents per Revolution
P350 = 400.00000 - MPG 1 Encoder Counts per Revolution
P351 = 0.00000 - MPG 2 Encoder Input
P352 = 100.00000 - MPG 2 Detents per Revolution
P353 = 400.00000 - MPG 2 Encoder Counts per Revolution
P354 = 0.00000 - MPG 3 Encoder Input
P355 = 100.00000 - MPG 3 Detents per Revolution
P356 = 400.00000 - MPG 3 Encoder Counts per Revolution
P357 = 0.00000 - Axis 1 (X) Drive Max RPM
P358 = 0.00000 - Axis 2 (Y) Drive Max RPM
P359 = 0.00000 - Axis 3 (Z) Drive Max RPM
P360 = 0.00000 - Axis 4 (N) Drive Max RPM
P361 = 0.00000 - Axis 5 (N) Drive Max RPM
P362 = 0.00000 - Axis 6 (N) Drive Max RPM
P363 = 0.00000 - Axis 7 (N) Drive Max RPM
P364 = 0.00000 - Axis 8 (N) Drive Max RPM
P365 = 0.00000 - Drive Power On Delay (Milliseconds)
P366 = 2.00000 - Probe Deceleration Multiplier
P367 = 2.00000 - TT1 Deceleration Multiplier
P368 = 4.00000 - Autonomous Digitizing Angle Adjustment Default
P369 = 75.00000 - Tool Check Max Absolute Angle
P370 = 0.00000 - PID Filter Constant A1 (Dev Test)
P371 = 0.00000 - PID Filter Constant A2 (Dev Test)
P372 = 0.00000 - PID Filter Constant B0 (Dev Test)
P373 = 0.00000 - PID Filter Constant B1 (Dev Test)
P374 = 0.00000 - ACDC Drive Debug Log Axis Inclusion
P375 = 0.00000 - ACDC Drive Debug Log Size
P376 = 0.00000 - ACDC Drive Debug Log Collection Type
P377 = 0.00000 - ACDC Drive Debug Log Trigger Type
P378 = 0.00000 - ACDC Drive Debug Log Trigger Level
P379 = 0.00000 - ACDC Drive Debug Log Option
P380 = 0.00000 - Engine Block X Reference Position
P381 = 54.00000 - Engine Block Block WCS
P382 = 55.00000 - Engine Block Cam WCS
P383 = 0.00000 - Engine Block A axis Center Y
P384 = 0.00000 - Engine Block A axis Center Z
P385 = 0.00000 - Engine Block Surfacing Cycle B angle
P386 = 0.00000 - Reserved
P387 = 0.00000 - Not Used
P388 = 0.00000 - Not Used
P389 = 0.00000 - Debug Level
P390 = 0.00000 - AD1 CV on/off
P391 = 0.00000 - AD1 CV vectors per second
P392 = 0.00000 - DP7 pullback distance
P393 = 0.10000 - DP7 pullback feedrate
P394 = 0.10000 - DP7 measuring feedrate
P395 = 30.00000 - Probing Setup Traverse Speed
P396 = 30.00000 - Probing Setup Plunge Speed
P397 = 0.25000 - Combustion Chamber Digitizing Clearance Height
P398 = 0.00000 - Current Port Block Mode: 0 - 3 Axis Mode 1 - Engine Block Mode 2 - Tilt Table Mode
P399 = 0.50000 - Arc chord off-path tolerance adjustment factor
P400 = 0.00000 - Allow Cycle Start in Run Menu
P401 = 0.00000 - Forget last job on software start.
P402 = 0.00000 - Not Used
P403 = 0.00000 - Not Used
P404 = 0.00000 - Not Used
P405 = 0.00000 - Not Used
P406 = 0.00000 - Not Used
P407 = 0.00000 - Not Used
P408 = 0.00000 - Not Used
P409 = 0.00000 - Not Used
P410 = 0.00000 - Not Used
P411 = 0.00000 - MPG Type, 0 = CWP-4, 1 = WMPG-4
P412 = 0.00000 - Not Used
P413 = 0.00000 - Not Used
P414 = 0.00000 - Not Used
P415 = 0.00000 - Not Used
P416 = 0.00000 - Not Used
P417 = 0.00000 - Not Used
P418 = 0.00000 - Not Used
P419 = 0.00000 - Not Used
P420 = 0.00000 - Not Used
P421 = 0.00000 - Not Used
P422 = 0.00000 - Not Used
P423 = 0.00000 - Not Used
P424 = 0.00000 - Not Used
P425 = 0.00000 - Not Used
P426 = 0.00000 - Not Used
P427 = 0.00000 - Not Used
P428 = 0.00000 - Not Used
P429 = 0.00000 - Not Used
P430 = 0.00000 - Not Used
P431 = 0.00000 - Not Used
P432 = 0.00000 - Not Used
P433 = 0.00000 - Not Used
P434 = 0.00000 - Not Used
P435 = 0.00000 - Not Used
P436 = 0.00000 - Not Used
P437 = 0.00000 - Not Used
P438 = 0.00000 - Not Used
P439 = 0.00000 - Not Used
P440 = 0.00000 - Not Used
P441 = 0.00000 - Not Used
P442 = 0.00000 - Not Used
P443 = 0.00000 - Not Used
P444 = 0.00000 - Not Used
P445 = 0.00000 - Not Used
P446 = 0.00000 - Not Used
P447 = 0.00000 - Not Used
P448 = 0.00000 - Not Used
P449 = 0.00000 - Not Used
P450 = 0.00000 - Not Used
P451 = 0.00000 - Not Used
P452 = 0.00000 - Not Used
P453 = 0.00000 - Not Used
P454 = 0.00000 - Not Used
P455 = 0.00000 - Not Used
P456 = 0.00000 - Not Used
P457 = 0.00000 - Not Used
P458 = 0.00000 - Not Used
P459 = 0.00000 - Not Used
P460 = 0.00000 - Not Used
P461 = 0.00000 - Not Used
P462 = 0.00000 - Not Used
P463 = 0.00000 - Not Used
P464 = 0.00000 - Not Used
P465 = 0.00000 - Not Used
P466 = 0.00000 - Not Used
P467 = 0.00000 - Not Used
P468 = 0.00000 - Not Used
P469 = 0.00000 - Not Used
P470 = 0.00000 - Not Used
P471 = 0.00000 - Not Used
P472 = 0.00000 - Not Used
P473 = 0.00000 - Not Used
P474 = 0.00000 - Not Used
P475 = 0.00000 - Not Used
P476 = 0.00000 - Not Used
P477 = 0.00000 - Not Used
P478 = 0.00000 - Not Used
P479 = 0.00000 - Not Used
P480 = 0.00000 - Not Used
P481 = 0.00000 - Not Used
P482 = 0.00000 - Not Used
P483 = 0.00000 - Not Used
P484 = 0.00000 - Not Used
P485 = 0.00000 - Not Used
P486 = 0.00000 - Not Used
P487 = 0.00000 - Not Used
P488 = 0.00000 - Not Used
P489 = 0.00000 - Not Used
P490 = 0.00000 - Not Used
P491 = 0.00000 - Not Used
P492 = 0.00000 - Not Used
P493 = 0.00000 - Not Used
P494 = 0.00000 - Not Used
P495 = 0.00000 - Not Used
P496 = 0.00000 - Not Used
P497 = 0.00000 - Not Used
P498 = 0.00000 - Not Used
P499 = 0.00000 - Not Used
P500 = 0.00000 - Not Used
P501 = 0.00000 - Not Used
P502 = 0.00000 - Not Used
P503 = 0.00000 - Not Used
P504 = 0.00000 - Not Used
P505 = 0.00000 - Not Used
P506 = 0.00000 - Not Used
P507 = 0.00000 - Not Used
P508 = 0.00000 - Not Used
P509 = 0.00000 - Not Used
P510 = 0.00000 - Not Used
P511 = 0.00000 - Not Used
P512 = 0.00000 - Not Used
P513 = 0.00000 - Not Used
P514 = 0.00000 - Not Used
P515 = 0.00000 - Not Used
P516 = 0.00000 - Not Used
P517 = 0.00000 - Not Used
P518 = 0.00000 - Not Used
P519 = 0.00000 - Not Used
P520 = 0.00000 - Not Used
P521 = 0.00000 - Not Used
P522 = 0.00000 - Not Used
P523 = 0.00000 - Not Used
P524 = 0.00000 - Not Used
P525 = 0.00000 - Not Used
P526 = 0.00000 - Not Used
P527 = 0.00000 - Not Used
P528 = 0.00000 - Not Used
P529 = 0.00000 - Not Used
P530 = 0.00000 - Not Used
P531 = 0.00000 - Not Used
P532 = 0.00000 - Not Used
P533 = 0.00000 - Not Used
P534 = 0.00000 - Not Used
P535 = 0.00000 - Not Used
P536 = 0.00000 - Not Used
P537 = 0.00000 - Not Used
P538 = 0.00000 - Not Used
P539 = 0.00000 - Not Used
P540 = 0.00000 - Not Used
P541 = 0.00000 - Not Used
P542 = 0.00000 - Not Used
P543 = 0.00000 - Not Used
P544 = 0.00000 - Not Used
P545 = 0.00000 - Not Used
P546 = 0.00000 - Not Used
P547 = 0.00000 - Not Used
P548 = 0.00000 - Not Used
P549 = 0.00000 - Not Used
P550 = 0.00000 - Not Used
P551 = 0.00000 - Not Used
P552 = 0.00000 - Not Used
P553 = 0.00000 - Not Used
P554 = 0.00000 - Not Used
P555 = 0.00000 - Not Used
P556 = 0.00000 - Not Used
P557 = 0.00000 - Not Used
P558 = 0.00000 - Not Used
P559 = 0.00000 - Not Used
P560 = 0.00000 - Not Used
P561 = 0.00000 - Not Used
P562 = 0.00000 - Not Used
P563 = 0.00000 - Not Used
P564 = 0.00000 - Not Used
P565 = 0.00000 - Not Used
P566 = 0.00000 - Not Used
P567 = 0.00000 - Not Used
P568 = 0.00000 - Not Used
P569 = 0.00000 - Not Used
P570 = 0.00000 - Not Used
P571 = 0.00000 - Not Used
P572 = 0.00000 - Not Used
P573 = 0.00000 - Not Used
P574 = 0.00000 - Not Used
P575 = 0.00000 - Not Used
P576 = 0.00000 - Not Used
P577 = 0.00000 - Not Used
P578 = 0.00000 - Not Used
P579 = 0.00000 - Not Used
P580 = 0.00000 - Not Used
P581 = 0.00000 - Not Used
P582 = 0.00000 - Not Used
P583 = 0.00000 - Not Used
P584 = 0.00000 - Not Used
P585 = 0.00000 - Not Used
P586 = 0.00000 - Not Used
P587 = 0.00000 - Not Used
P588 = 0.00000 - Not Used
P589 = 0.00000 - Not Used
P590 = 0.00000 - Not Used
P591 = 0.00000 - Not Used
P592 = 0.00000 - Not Used
P593 = 0.00000 - Not Used
P594 = 0.00000 - Not Used
P595 = 0.00000 - Not Used
P596 = 0.00000 - Not Used
P597 = 0.00000 - Not Used
P598 = 0.00000 - Not Used
P599 = 0.00000 - Not Used
P600 = 0.00000 - Not Used
P601 = 0.00000 - Not Used
P602 = 0.00000 - Not Used
P603 = 0.00000 - Not Used
P604 = 0.00000 - Not Used
P605 = 0.00000 - Not Used
P606 = 0.00000 - Not Used
P607 = 0.00000 - Not Used
P608 = 0.00000 - Not Used
P609 = 0.00000 - Not Used
P610 = 0.00000 - Not Used
P611 = 0.00000 - Not Used
P612 = 0.00000 - Not Used
P613 = 0.00000 - Not Used
P614 = 0.00000 - Not Used
P615 = 0.00000 - Not Used
P616 = 0.00000 - Not Used
P617 = 0.00000 - Not Used
P618 = 0.00000 - Not Used
P619 = 0.00000 - Not Used
P620 = 0.00000 - Not Used
P621 = 0.00000 - Not Used
P622 = 0.00000 - Not Used
P623 = 0.00000 - Not Used
P624 = 0.00000 - Not Used
P625 = 0.00000 - Not Used
P626 = 0.00000 - Not Used
P627 = 0.00000 - Not Used
P628 = 0.00000 - Not Used
P629 = 0.00000 - Not Used
P630 = 0.00000 - Not Used
P631 = 0.00000 - Not Used
P632 = 0.00000 - Not Used
P633 = 0.00000 - Not Used
P634 = 0.00000 - Not Used
P635 = 0.00000 - Not Used
P636 = 0.00000 - Not Used
P637 = 0.00000 - Not Used
P638 = 0.00000 - Not Used
P639 = 0.00000 - Not Used
P640 = 0.00000 - Not Used
P641 = 0.00000 - Not Used
P642 = 0.00000 - Not Used
P643 = 0.00000 - Not Used
P644 = 0.00000 - Not Used
P645 = 0.00000 - Not Used
P646 = 0.00000 - Not Used
P647 = 0.00000 - Not Used
P648 = 0.00000 - Not Used
P649 = 0.00000 - Not Used
P650 = 0.00000 - Not Used
P651 = 0.00000 - Not Used
P652 = 0.00000 - Not Used
P653 = 0.00000 - Not Used
P654 = 0.00000 - Not Used
P655 = 0.00000 - Not Used
P656 = 0.00000 - Not Used
P657 = 0.00000 - Not Used
P658 = 0.00000 - Not Used
P659 = 0.00000 - Not Used
P660 = 0.00000 - Not Used
P661 = 0.00000 - Not Used
P662 = 0.00000 - Not Used
P663 = 0.00000 - Not Used
P664 = 0.00000 - Not Used
P665 = 0.00000 - Not Used
P666 = 0.00000 - Not Used
P667 = 0.00000 - Not Used
P668 = 0.00000 - Not Used
P669 = 0.00000 - Not Used
P670 = 0.00000 - Not Used
P671 = 0.00000 - Not Used
P672 = 0.00000 - Not Used
P673 = 0.00000 - Not Used
P674 = 0.00000 - Not Used
P675 = 0.00000 - Not Used
P676 = 0.00000 - Not Used
P677 = 0.00000 - Not Used
P678 = 0.00000 - Not Used
P679 = 0.00000 - Not Used
P680 = 0.00000 - Not Used
P681 = 0.00000 - Not Used
P682 = 0.00000 - Not Used
P683 = 0.00000 - Not Used
P684 = 0.00000 - Not Used
P685 = 0.00000 - Not Used
P686 = 0.00000 - Not Used
P687 = 0.00000 - Not Used
P688 = 0.00000 - Not Used
P689 = 0.00000 - Not Used
P690 = 0.00000 - Not Used
P691 = 0.00000 - Not Used
P692 = 0.00000 - Not Used
P693 = 0.00000 - Not Used
P694 = 0.00000 - Not Used
P695 = 0.00000 - Not Used
P696 = 0.00000 - Not Used
P697 = 0.00000 - Not Used
P698 = 0.00000 - Not Used
P699 = 0.00000 - Not Used
P700 = 0.00000 - Not Used
P701 = 0.00000 - Not Used
P702 = 0.00000 - Not Used
P703 = 0.00000 - Not Used
P704 = 0.00000 - Not Used
P705 = 0.00000 - Not Used
P706 = 0.00000 - Not Used
P707 = 0.00000 - Not Used
P708 = 0.00000 - Not Used
P709 = 0.00000 - Not Used
P710 = 0.00000 - Not Used
P711 = 0.00000 - Not Used
P712 = 0.00000 - Not Used
P713 = 0.00000 - Not Used
P714 = 0.00000 - Not Used
P715 = 0.00000 - Not Used
P716 = 0.00000 - Not Used
P717 = 0.00000 - Not Used
P718 = 0.00000 - Not Used
P719 = 0.00000 - Not Used
P720 = 0.00000 - Not Used
P721 = 0.00000 - Not Used
P722 = 0.00000 - Not Used
P723 = 0.00000 - Not Used
P724 = 0.00000 - Not Used
P725 = 0.00000 - Not Used
P726 = 0.00000 - Not Used
P727 = 0.00000 - Not Used
P728 = 0.00000 - Not Used
P729 = 0.00000 - Not Used
P730 = 0.00000 - Not Used
P731 = 0.00000 - Not Used
P732 = 0.00000 - Not Used
P733 = 0.00000 - Not Used
P734 = 0.00000 - Not Used
P735 = 0.00000 - Not Used
P736 = 0.00000 - Not Used
P737 = 0.00000 - Not Used
P738 = 0.00000 - Not Used
P739 = 0.00000 - Not Used
P740 = 0.00000 - Not Used
P741 = 0.00000 - Not Used
P742 = 0.00000 - Not Used
P743 = 0.00000 - Not Used
P744 = 0.00000 - Not Used
P745 = 0.00000 - Not Used
P746 = 0.00000 - Not Used
P747 = 0.00000 - Not Used
P748 = 0.00000 - Not Used
P749 = 0.00000 - Not Used
P750 = 0.00000 - Not Used
P751 = 0.00000 - Not Used
P752 = 0.00000 - Not Used
P753 = 0.00000 - Not Used
P754 = 0.00000 - Not Used
P755 = 0.00000 - Not Used
P756 = 0.00000 - Not Used
P757 = 0.00000 - Not Used
P758 = 0.00000 - Not Used
P759 = 0.00000 - Not Used
P760 = 0.00000 - Not Used
P761 = 0.00000 - Not Used
P762 = 0.00000 - Not Used
P763 = 0.00000 - Not Used
P764 = 0.00000 - Not Used
P765 = 0.00000 - Not Used
P766 = 0.00000 - Not Used
P767 = 0.00000 - Not Used
P768 = 0.00000 - Not Used
P769 = 0.00000 - Not Used
P770 = 0.00000 - Not Used
P771 = 0.00000 - Not Used
P772 = 0.00000 - Not Used
P773 = 0.00000 - Not Used
P774 = 0.00000 - Not Used
P775 = 0.00000 - Not Used
P776 = 0.00000 - Not Used
P777 = 0.00000 - Not Used
P778 = 0.00000 - Not Used
P779 = 0.00000 - Not Used
P780 = 0.00000 - Not Used
P781 = 0.00000 - Not Used
P782 = 0.00000 - Not Used
P783 = 0.00000 - Not Used
P784 = 0.00000 - Not Used
P785 = 0.00000 - Not Used
P786 = 0.00000 - Not Used
P787 = 0.00000 - Not Used
P788 = 0.00000 - Not Used
P789 = 0.00000 - Not Used
P790 = 0.00000 - Not Used
P791 = 0.00000 - Not Used
P792 = 0.00000 - Not Used
P793 = 0.00000 - Not Used
P794 = 0.00000 - Not Used
P795 = 0.00000 - Not Used
P796 = 0.00000 - Not Used
P797 = 0.00000 - Not Used
P798 = 0.00000 - Not Used
P799 = 0.00000 - Not Used
P800 = 0.00000 - Not Used
P801 = 0.00000 - Not Used
P802 = 0.00000 - Not Used
P803 = 0.00000 - Not Used
P804 = 0.00000 - Not Used
P805 = 0.00000 - Not Used
P806 = 0.00000 - Not Used
P807 = 0.00000 - Not Used
P808 = 0.00000 - Not Used
P809 = 0.00000 - Not Used
P810 = 0.00000 - Not Used
P811 = 0.00000 - Not Used
P812 = 0.00000 - Not Used
P813 = 0.00000 - Not Used
P814 = 0.00000 - Not Used
P815 = 0.00000 - Not Used
P816 = 0.00000 - Not Used
P817 = 0.00000 - Not Used
P818 = 0.00000 - Not Used
P819 = 0.00000 - Not Used
P820 = 0.00000 - Not Used
P821 = 0.00000 - Not Used
P822 = 0.00000 - Not Used
P823 = 0.00000 - Not Used
P824 = 0.00000 - Not Used
P825 = 0.00000 - Not Used
P826 = 0.00000 - Not Used
P827 = 0.00000 - Not Used
P828 = 0.00000 - Not Used
P829 = 0.00000 - Not Used
P830 = 0.00000 - Not Used
P831 = 0.00000 - Not Used
P832 = 0.00000 - Not Used
P833 = 0.00000 - Not Used
P834 = 0.00000 - Not Used
P835 = 0.00000 - Not Used
P836 = 0.00000 - Not Used
P837 = 0.00000 - Not Used
P838 = 0.00000 - Not Used
P839 = 0.00000 - Not Used
P840 = 0.00000 - Not Used
P841 = 0.00000 - Not Used
P842 = 0.00000 - Not Used
P843 = 0.00000 - Not Used
P844 = 0.00000 - Not Used
P845 = 0.00000 - Not Used
P846 = 0.00000 - Not Used
P847 = 0.00000 - Not Used
P848 = 0.00000 - Not Used
P849 = 0.00000 - Not Used
P850 = 0.00000 - Not Used
P851 = 0.00000 - Not Used
P852 = 0.00000 - Not Used
P853 = 0.00000 - Not Used
P854 = 0.00000 - Not Used
P855 = 0.00000 - Not Used
P856 = 0.00000 - Not Used
P857 = 0.00000 - Not Used
P858 = 0.00000 - Not Used
P859 = 0.00000 - Not Used
P860 = 0.00000 - Not Used
P861 = 0.00000 - Not Used
P862 = 0.00000 - Not Used
P863 = 0.00000 - Not Used
P864 = 0.00000 - Not Used
P865 = 0.00000 - Not Used
P866 = 0.00000 - Not Used
P867 = 0.00000 - Not Used
P868 = 0.00000 - Not Used
P869 = 0.00000 - Not Used
P870 = 0.00000 - Not Used
P871 = 0.00000 - Not Used
P872 = 0.00000 - Not Used
P873 = 0.00000 - Not Used
P874 = 0.00000 - Not Used
P875 = 0.00000 - Not Used
P876 = 0.00000 - Not Used
P877 = 0.00000 - Not Used
P878 = 0.00000 - Not Used
P879 = 0.00000 - Not Used
P880 = 0.00000 - Not Used
P881 = 0.00000 - Not Used
P882 = 0.00000 - Not Used
P883 = 0.00000 - Not Used
P884 = 0.00000 - Not Used
P885 = 0.00000 - Not Used
P886 = 0.00000 - Not Used
P887 = 0.00000 - Not Used
P888 = 0.00000 - Not Used
P889 = 0.00000 - Not Used
P890 = 0.00000 - Not Used
P891 = 0.00000 - Not Used
P892 = 0.00000 - Not Used
P893 = 0.00000 - Not Used
P894 = 0.00000 - Not Used
P895 = 0.00000 - Not Used
P896 = 0.00000 - Not Used
P897 = 0.00000 - Not Used
P898 = 0.00000 - Not Used
P899 = 0.00000 - Not Used
P900 = 0.00000 - Reserved for PLC
P901 = 0.00000 - Reserved for PLC
P902 = 0.00000 - Reserved for PLC
P903 = 0.00000 - Reserved for PLC
P904 = 0.00000 - Reserved for PLC
P905 = 0.00000 - Reserved for PLC
P906 = 0.00000 - Reserved for PLC
P907 = 0.00000 - Reserved for PLC
P908 = 0.00000 - Reserved for PLC
P909 = 0.00000 - Reserved for PLC
P910 = 0.00000 - Reserved for PLC
P911 = 2046.00000 - Reserved for PLC
P912 = 15.00000 - Reserved for PLC
P913 = 0.00000 - Reserved for PLC
P914 = 0.00000 - Reserved for PLC
P915 = 0.00000 - Reserved for PLC
P916 = 0.00000 - Reserved for PLC
P917 = 0.00000 - Reserved for PLC
P918 = 0.00000 - Reserved for PLC
P919 = 0.00000 - Reserved for PLC
P920 = 0.00000 - Reserved for PLC
P921 = 0.00000 - Reserved for PLC
P922 = 0.00000 - Reserved for PLC
P923 = 0.00000 - Reserved for PLC
P924 = 0.00000 - Reserved for PLC
P925 = 0.00000 - Reserved for PLC
P926 = 0.00000 - Reserved for PLC
P927 = 0.00000 - Reserved for PLC
P928 = 0.00000 - Reserved for PLC
P929 = 0.00000 - Reserved for PLC
P930 = 0.00000 - Reserved for PLC
P931 = 0.00000 - Reserved for PLC
P932 = 0.00000 - Reserved for PLC
P933 = 0.00000 - Reserved for PLC
P934 = 0.00000 - Reserved for PLC
P935 = 0.00000 - Reserved for PLC
P936 = 0.00000 - Reserved for PLC
P937 = 0.00000 - Reserved for PLC
P938 = 0.00000 - Reserved for PLC
P939 = 0.00000 - Reserved for PLC
P940 = 0.00000 - Reserved for PLC
P941 = 0.00000 - Reserved for PLC
P942 = 0.00000 - Reserved for PLC
P943 = 0.00000 - Reserved for PLC
P944 = 0.00000 - Reserved for PLC
P945 = 0.00000 - Reserved for PLC
P946 = 0.00000 - Reserved for PLC
P947 = 0.00000 - Reserved for PLC
P948 = 0.00000 - Reserved for PLC
P949 = 0.00000 - Reserved for PLC
P950 = 0.00000 - Reserved for PLC
P951 = 0.00000 - Reserved for PLC
P952 = 0.00000 - Reserved for PLC
P953 = 0.00000 - Reserved for PLC
P954 = 0.00000 - Reserved for PLC
P955 = 0.00000 - Reserved for PLC
P956 = 0.00000 - Reserved for PLC
P957 = 0.00000 - Reserved for PLC
P958 = 0.00000 - Reserved for PLC
P959 = 0.00000 - Reserved for PLC
P960 = 0.00000 - Reserved for PLC
P961 = 0.00000 - Reserved for PLC
P962 = 0.00000 - Reserved for PLC
P963 = 0.00000 - Reserved for PLC
P964 = 0.00000 - Reserved for PLC
P965 = 0.00000 - Reserved for PLC
P966 = 0.00000 - Reserved for PLC
P967 = 0.00000 - Reserved for PLC
P968 = 0.00000 - Reserved for PLC
P969 = 0.00000 - Reserved for PLC
P970 = 0.00000 - Reserved for PLC
P971 = 0.00000 - Reserved for PLC
P972 = 0.00000 - Reserved for PLC
P973 = 0.00000 - Reserved for PLC
P974 = 0.00000 - Reserved for PLC
P975 = 0.00000 - Reserved for PLC
P976 = 0.00000 - Reserved for PLC
P977 = 0.00000 - Reserved for PLC
P978 = 0.00000 - Reserved for PLC
P979 = 0.00000 - Reserved for PLC
P980 = 0.00000 - Reserved for PLC
P981 = 0.00000 - Reserved for PLC
P982 = 0.00000 - Reserved for PLC
P983 = 0.00000 - Reserved for PLC
P984 = 0.00000 - Reserved for PLC
P985 = 0.00000 - Reserved for PLC
P986 = 0.00000 - Reserved for PLC
P987 = 0.00000 - Reserved for PLC
P988 = 0.00000 - Reserved for PLC
P989 = 0.00000 - Reserved for PLC
P990 = 0.00000 - Reserved for PLC
P991 = 0.00000 - Reserved for PLC
P992 = 0.00000 - Reserved for PLC
P993 = 0.00000 - Reserved for PLC
P994 = 0.00000 - Reserved for PLC
P995 = 0.00000 - Reserved for PLC
P996 = 0.00000 - Reserved for PLC
P997 = 0.00000 - Reserved for PLC
P998 = 0.00000 - Reserved for PLC
P999 = 0.00000 - Reserved for PLC
Special Parameters
300 586.5041 | 200 0.0000 | 201 0.0000 | 202 0.0000
203 0.0000 | 204 0.0000 | 205 0.0000 | 206 0.0000
207 0.0000 | 208 0.0000 | 209 0.0000 | 400 0.0000
401 0.0000 | 210 0.0000 | 232 0.0000 | 211 0.0000
224 0.0000 | 225 0.0000 | 226 0.0000 | 510 0.0000
212 0.0000 | 213 0.0000 | 214 0.0000 | 215 0.0000
216 0.0000 | 217 0.0000 | 218 0.0000 | 219 0.0000
220 0.0000 | 221 0.0000 | 297 8730.4571 | 298 6322.3198
296 0.0000 | 295 0.0000 | 222 0.0000 | 223 0.0000
233 0.0000
CNC11 v. 3.16 coordinates file
Axis Minus Plus Return Return Return Return
Limit Limit #1(G28) #2(G30) #3 #4
X 0.0000 0.0000 0.00000 0.00000 0.00000 0.00000
Y 0.0000 0.0000 0.00000 0.00000 0.00000 0.00000
Z 0.0000 0.0000 0.00000 0.00000 0.00000 0.00000
N 0.0000 0.0000 0.00000 0.00000 0.00000 0.00000
Axis Origin Origin Origin Origin Origin Origin
#1(G54) #2(G55) #3(G56) #4(G57) #5(G58) #6(G59)
X 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
Y 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
Z 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
N 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
CSR 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
#7 #8 #9 #10 #11 #12
#13 #14 #15 #16 #17 #18
Work Envelope
Axis - +
X 0.0000 0.0000
Y 0.0000 0.0000
Z 0.0000 0.0000
N 0.0000 0.0000
N 0.0000 0.0000
N 0.0000 0.0000
N 0.0000 0.0000
N 0.0000 0.0000
Scale Settings
Axis Label Input Enabled Scale Counts/Inch Ratio Deadband Velocity
1 X 0 N 0.0000 0.0000 0 0.0000
2 Y 0 N 0.0000 0.0000 0 0.0000
3 Z 0 N 0.0000 0.0000 0 0.0000
4 N 0 N 0.0000 0.0000 0 0.0000
5 N 0 N 0.0000 0.0000 0 0.0000
6 N 0 N 0.0000 0.0000 0 0.0000
7 N 0 N 0.0000 0.0000 0 0.0000
8 N 0 N 0.0000 0.0000 0 0.0000
PWM Parameters
Axis Poles % Angle PWM Kp PWM Ki PWM Kd Inertia Kt MaxRPM
X 0 0 0.000000 0.0000 0.0000 0.0000 0.000000 0.0000 0
Y 0 0 0.000000 0.0000 0.0000 0.0000 0.000000 0.0000 0
Z 0 0 0.000000 0.0000 0.0000 0.0000 0.000000 0.0000 0
N 0 0 0.000000 0.0000 0.0000 0.0000 0.000000 0.0000 0
PID Enocder Menu Snapshot
Motor Pos Type DQOA ErrCnt Scale Pos Type DQOA ErrCnt ErrCorr
X* 0 Std 100- - 0 None 000- - 0
Y* 0 Std 100- - 0 None 000- - 0
Z* 0 Std 100- - 0 None 000- - 0
N* 0 Std 100- - 0 None 000- - 0
N 0 Std 000- - 0 None 000- - 0
Beagle Beagle
The end of report:
CNC12 v. 4.14 tool file
OFFSET LIBRARY TOOL LIBRARY
NUM Height Diameter Height Diamtr Coolnt Spindl Speed Description
001 0.0000 0.0000 H001 D001 OFF OFF 0
002 0.0000 0.0000 H002 D002 OFF OFF 0
003 0.0000 0.0000 H003 D003 OFF OFF 0
004 0.0000 0.0000 H001 D004 OFF OFF 0
005 0.0000 0.0000 H005 D005 OFF OFF 0
006 0.0000 0.0000 H006 D006 OFF OFF 0
007 0.0000 0.0000 H007 D007 OFF OFF 0
008 0.0000 0.0000 H008 D008 OFF OFF 0
009 0.0000 0.0000 H009 D009 OFF OFF 0
010 0.0000 0.0000 H010 D010 OFF OFF 0
011 0.0000 0.0000 H011 D011 OFF OFF 0
012 0.0000 0.0000 H012 D012 OFF OFF 0
013 0.0000 0.0000 H013 D013 OFF OFF 0
014 0.0000 0.0000 H014 D014 OFF OFF 0
015 0.0000 0.0000 H015 D015 OFF OFF 0
016 0.0000 0.0000 H016 D016 OFF OFF 0
017 0.0000 0.0000 H017 D017 OFF OFF 0
018 0.0000 0.0000 H018 D018 OFF OFF 0
019 0.0000 0.0000 H019 D019 OFF OFF 0
020 0.0000 0.0000 H020 D020 OFF OFF 0
021 0.0000 0.0000 H021 D021 OFF OFF 0
022 0.0000 0.0000 H022 D022 OFF OFF 0
023 0.0000 0.0000 H023 D023 OFF OFF 0
024 0.0000 0.0000 H024 D024 OFF OFF 0
025 0.0000 0.0000 H025 D025 OFF OFF 0
026 0.0000 0.0000 H026 D026 OFF OFF 0
027 0.0000 0.0000 H027 D027 OFF OFF 0
028 0.0000 0.0000 H028 D028 OFF OFF 0
029 0.0000 0.0000 H029 D029 OFF OFF 0
030 0.0000 0.0000 H030 D030 OFF OFF 0
031 0.0000 0.0000 H031 D031 OFF OFF 0
032 0.0000 0.0000 H032 D032 OFF OFF 0
033 0.0000 0.0000 H033 D033 OFF OFF 0
034 0.0000 0.0000 H034 D034 OFF OFF 0
035 0.0000 0.0000 H035 D035 OFF OFF 0
036 0.0000 0.0000 H036 D036 OFF OFF 0
037 0.0000 0.0000 H037 D037 OFF OFF 0
038 0.0000 0.0000 H038 D038 OFF OFF 0
039 0.0000 0.0000 H039 D039 OFF OFF 0
040 0.0000 0.0000 H040 D040 OFF OFF 0
041 0.0000 0.0000 H041 D041 OFF OFF 0
042 0.0000 0.0000 H042 D042 OFF OFF 0
043 0.0000 0.0000 H043 D043 OFF OFF 0
044 0.0000 0.0000 H044 D044 OFF OFF 0
045 0.0000 0.0000 H045 D045 OFF OFF 0
046 0.0000 0.0000 H046 D046 OFF OFF 0
047 0.0000 0.0000 H047 D047 OFF OFF 0
048 0.0000 0.0000 H048 D048 OFF OFF 0
049 0.0000 -0.0100 H049 D049 OFF OFF 0
050 0.0000 0.0000 H050 D050 OFF OFF 0
051 0.0000 0.0000 H051 D051 OFF OFF 0
052 0.0000 0.0000 H052 D052 OFF OFF 0
053 0.0000 0.0000 H053 D053 OFF OFF 0
054 0.0000 0.0000 H054 D054 OFF OFF 0
055 0.0000 0.0000 H055 D055 OFF OFF 0
056 0.0000 0.0000 H056 D056 OFF OFF 0
057 0.0000 0.0000 H057 D057 OFF OFF 0
058 0.0000 0.0000 H058 D058 OFF OFF 0
059 0.0000 0.0000 H059 D059 OFF OFF 0
060 0.0000 0.0000 H060 D060 OFF OFF 0
061 0.0000 0.0000 H061 D061 OFF OFF 0
062 0.0000 0.0000 H062 D062 OFF OFF 0
063 0.0000 0.0000 H063 D063 OFF OFF 0
064 0.0000 0.0000 H064 D064 OFF OFF 0
065 0.0000 0.0000 H065 D065 OFF OFF 0
066 0.0000 0.0000 H066 D066 OFF OFF 0
067 0.0000 0.0000 H067 D067 OFF OFF 0
068 0.0000 0.0000 H068 D068 OFF OFF 0
069 0.0000 0.0000 H069 D069 OFF OFF 0
070 0.0000 0.0000 H070 D070 OFF OFF 0
071 0.0000 0.0000 H071 D071 OFF OFF 0
072 0.0000 0.0000 H072 D072 OFF OFF 0
073 0.0000 0.0000 H073 D073 OFF OFF 0
074 0.0000 0.0000 H074 D074 OFF OFF 0
075 0.0000 0.0000 H075 D075 OFF OFF 0
076 0.0000 0.0000 H076 D076 OFF OFF 0
077 0.0000 0.0000 H077 D077 OFF OFF 0
078 0.0000 0.0000 H078 D078 OFF OFF 0
079 0.0000 0.0000 H079 D079 OFF OFF 0
080 0.0000 0.0000 H080 D080 OFF OFF 0
081 0.0000 0.0000 H081 D081 OFF OFF 0
082 0.0000 0.0000 H082 D082 OFF OFF 0
083 0.0000 0.0000 H083 D083 OFF OFF 0
084 0.0000 0.0000 H084 D084 OFF OFF 0
085 0.0000 0.0000 H085 D085 OFF OFF 0
086 0.0000 0.0000 H086 D086 OFF OFF 0
087 0.0000 0.0000 H087 D087 OFF OFF 0
088 0.0000 0.0000 H088 D088 OFF OFF 0
089 0.0000 0.0000 H089 D089 OFF OFF 0
090 0.0000 0.0000 H090 D090 OFF OFF 0
091 0.0000 0.0000 H091 D091 OFF OFF 0
092 0.0000 0.0000 H092 D092 OFF OFF 0
093 0.0000 0.0000 H093 D093 OFF OFF 0
094 0.0000 0.0000 H094 D094 OFF OFF 0
095 0.0000 0.0000 H095 D095 OFF OFF 0
096 0.0000 0.0000 H096 D096 OFF OFF 0
097 0.0000 0.0000 H097 D097 OFF OFF 0
098 0.0000 0.0000 H098 D098 OFF OFF 0
099 0.0000 0.0000 H099 D099 OFF OFF 0
100 0.0000 0.0000 H100 D100 OFF OFF 0
101 0.0000 0.0000 H101 D101 OFF OFF 0
102 0.0000 0.0000 H102 D102 OFF OFF 0
103 0.0000 0.0000 H103 D103 OFF OFF 0
104 0.0000 0.0000 H104 D104 OFF OFF 0
105 0.0000 0.0000 H105 D105 OFF OFF 0
106 0.0000 0.0000 H106 D106 OFF OFF 0
107 0.0000 0.0000 H107 D107 OFF OFF 0
108 0.0000 0.0000 H108 D108 OFF OFF 0
109 0.0000 0.0000 H109 D109 OFF OFF 0
110 0.0000 0.0000 H110 D110 OFF OFF 0
111 0.0000 0.0000 H111 D111 OFF OFF 0
112 0.0000 0.0000 H112 D112 OFF OFF 0
113 0.0000 0.0000 H113 D113 OFF OFF 0
114 0.0000 0.0000 H114 D114 OFF OFF 0
115 0.0000 0.0000 H115 D115 OFF OFF 0
116 0.0000 0.0000 H116 D116 OFF OFF 0
117 0.0000 0.0000 H117 D117 OFF OFF 0
118 0.0000 0.0000 H118 D118 OFF OFF 0
119 0.0000 0.0000 H119 D119 OFF OFF 0
120 0.0000 0.0000 H120 D120 OFF OFF 0
121 0.0000 0.0000 H121 D121 OFF OFF 0
122 0.0000 0.0000 H122 D122 OFF OFF 0
123 0.0000 0.0000 H123 D123 OFF OFF 0
124 0.0000 0.0000 H124 D124 OFF OFF 0
125 0.0000 0.0000 H125 D125 OFF OFF 0
126 0.0000 0.0000 H126 D126 OFF OFF 0
127 0.0000 0.0000 H127 D127 OFF OFF 0
128 0.0000 0.0000 H128 D128 OFF OFF 0
129 0.0000 0.0000 H129 D129 OFF OFF 0
130 0.0000 0.0000 H130 D130 OFF OFF 0
131 0.0000 0.0000 H131 D131 OFF OFF 0
132 0.0000 0.0000 H132 D132 OFF OFF 0
133 0.0000 0.0000 H133 D133 OFF OFF 0
134 0.0000 0.0000 H134 D134 OFF OFF 0
135 0.0000 0.0000 H135 D135 OFF OFF 0
136 0.0000 0.0000 H136 D136 OFF OFF 0
137 0.0000 0.0000 H137 D137 OFF OFF 0
138 0.0000 0.0000 H138 D138 OFF OFF 0
139 0.0000 0.0000 H139 D139 OFF OFF 0
140 0.0000 0.0000 H140 D140 OFF OFF 0
141 0.0000 0.0000 H141 D141 OFF OFF 0
142 0.0000 0.0000 H142 D142 OFF OFF 0
143 0.0000 0.0000 H143 D143 OFF OFF 0
144 0.0000 0.0000 H144 D144 OFF OFF 0
145 0.0000 0.0000 H145 D145 OFF OFF 0
146 0.0000 0.0000 H146 D146 OFF OFF 0
147 0.0000 0.0000 H147 D147 OFF OFF 0
148 0.0000 0.0000 H148 D148 OFF OFF 0
149 0.0000 0.0000 H149 D149 OFF OFF 0
150 0.0000 0.0000 H150 D150 OFF OFF 0
151 0.0000 0.0000 H151 D151 OFF OFF 0
152 0.0000 0.0000 H152 D152 OFF OFF 0
153 0.0000 0.0000 H153 D153 OFF OFF 0
154 0.0000 0.0000 H154 D154 OFF OFF 0
155 0.0000 0.0000 H155 D155 OFF OFF 0
156 0.0000 0.0000 H156 D156 OFF OFF 0
157 0.0000 0.0000 H157 D157 OFF OFF 0
158 0.0000 0.0000 H158 D158 OFF OFF 0
159 0.0000 0.0000 H159 D159 OFF OFF 0
160 0.0000 0.0000 H160 D160 OFF OFF 0
161 0.0000 0.0000 H161 D161 OFF OFF 0
162 0.0000 0.0000 H162 D162 OFF OFF 0
163 0.0000 0.0000 H163 D163 OFF OFF 0
164 0.0000 0.0000 H164 D164 OFF OFF 0
165 0.0000 0.0000 H165 D165 OFF OFF 0
166 0.0000 0.0000 H166 D166 OFF OFF 0
167 0.0000 0.0000 H167 D167 OFF OFF 0
168 0.0000 0.0000 H168 D168 OFF OFF 0
169 0.0000 0.0000 H169 D169 OFF OFF 0
170 0.0000 0.0000 H170 D170 OFF OFF 0
171 0.0000 0.0000 H171 D171 OFF OFF 0
172 0.0000 0.0000 H172 D172 OFF OFF 0
173 0.0000 0.0000 H173 D173 OFF OFF 0
174 0.0000 0.0000 H174 D174 OFF OFF 0
175 0.0000 0.0000 H175 D175 OFF OFF 0
176 0.0000 0.0000 H176 D176 OFF OFF 0
177 0.0000 0.0000 H177 D177 OFF OFF 0
178 0.0000 0.0000 H178 D178 OFF OFF 0
179 0.0000 0.0000 H179 D179 OFF OFF 0
180 0.0000 0.0000 H180 D180 OFF OFF 0
181 0.0000 0.0000 H181 D181 OFF OFF 0
182 0.0000 0.0000 H182 D182 OFF OFF 0
183 0.0000 0.0000 H183 D183 OFF OFF 0
184 0.0000 0.0000 H184 D184 OFF OFF 0
185 0.0000 0.0000 H185 D185 OFF OFF 0
186 0.0000 0.0000 H186 D186 OFF OFF 0
187 0.0000 0.0000 H187 D187 OFF OFF 0
188 0.0000 0.0000 H188 D188 OFF OFF 0
189 0.0000 0.0000 H189 D189 OFF OFF 0
190 0.0000 0.0000 H190 D190 OFF OFF 0
191 0.0000 0.0000 H191 D191 OFF OFF 0
192 0.0000 0.0000 H192 D192 OFF OFF 0
193 0.0000 0.0000 H193 D193 OFF OFF 0
194 0.0000 0.0000 H194 D194 OFF OFF 0
195 0.0000 0.0000 H195 D195 OFF OFF 0
196 0.0000 0.0000 H196 D196 OFF OFF 0
197 0.0000 0.0000 H197 D197 OFF OFF 0
198 0.0000 0.0000 H198 D198 OFF OFF 0
199 0.0000 0.0000 H199 D199 OFF OFF 0
200 0.0000 0.0000 H200 D200 OFF OFF 0
ATC Tool Library Info
Tool Bin Putback
074 -01 -01
075 -01 -01
076 -01 -01
077 -01 -01
078 -01 -01
079 -01 -01
080 -01 -01
081 -01 -01
082 -01 -01
083 -01 -01
084 -01 -01
085 -01 -01
086 -01 -01
087 -01 -01
088 -01 -01
089 -01 -01
090 -01 -01
091 -01 -01
092 -01 -01
093 -01 -01
094 -01 -01
095 -01 -01
096 -01 -01
097 -01 -01
098 -01 -01
099 -01 -01
100 -01 -01
101 -01 -01
102 -01 -01
103 -01 -01
104 -01 -01
105 -01 -01
106 -01 -01
107 -01 -01
108 -01 -01
109 -01 -01
110 -01 -01
111 -01 -01
112 -01 -01
113 -01 -01
114 -01 -01
115 -01 -01
116 -01 -01
117 -01 -01
118 -01 -01
119 -01 -01
120 -01 -01
121 -01 -01
122 -01 -01
123 -01 -01
124 -01 -01
125 -01 -01
126 -01 -01
127 -01 -01
128 -01 -01
129 -01 -01
130 -01 -01
131 -01 -01
132 -01 -01
133 -01 -01
134 -01 -01
135 -01 -01
136 -01 -01
137 -01 -01
138 -01 -01
139 -01 -01
140 -01 -01
141 -01 -01
142 -01 -01
143 -01 -01
144 -01 -01
145 -01 -01
146 -01 -01
147 -01 -01
148 -01 -01
149 -01 -01
150 -01 -01
151 -01 -01
152 -01 -01
153 -01 -01
154 -01 -01
155 -01 -01
156 -01 -01
157 -01 -01
158 -01 -01
159 -01 -01
160 -01 -01
161 -01 -01
162 -01 -01
163 -01 -01
164 -01 -01
165 -01 -01
166 -01 -01
167 -01 -01
168 -01 -01
169 -01 -01
170 -01 -01
171 -01 -01
172 -01 -01
173 -01 -01
174 -01 -01
175 -01 -01
176 -01 -01
177 -01 -01
178 -01 -01
179 -01 -01
180 -01 -01
181 -01 -01
182 -01 -01
183 -01 -01
184 -01 -01
185 -01 -01
186 -01 -01
187 -01 -01
188 -01 -01
189 -01 -01
190 -01 -01
191 -01 -01
192 -01 -01
193 -01 -01
194 -01 -01
195 -01 -01
196 -01 -01
197 -01 -01
198 -01 -01
199 -01 -01
200 -01 -01
PLC Run Time (ms) : Max: 1.107 Min: 0.988 Avg: 1.006
PLC Fast Stage Time (ms) : Max: 0.063 Min: 0.037 Avg: 0.039
File System Info
Directory of C:\cncm\bmps
Fri Mar 1 11:05:50 2019 550,454 cc_4_valve.bmp
Fri Mar 1 11:05:50 2019 2,607 clogo.png
Fri Mar 1 11:05:50 2019 950,238 combustion_chamber.bmp
Fri Mar 1 11:05:50 2019 2,460 c_ajaxlogo.bmp
Fri Mar 1 11:05:50 2019 1,462 c_fe.bmp
Fri Mar 1 11:05:50 2019 81,078 c_filters.bmp
Fri Mar 1 11:05:50 2019 61,758 c_jogpanel.bmp
Fri Mar 1 11:05:50 2019 198 c_manual_m_label.bmp
Fri Mar 1 11:05:50 2019 662 c_mmansym.bmp
Fri Mar 1 11:05:50 2019 662 c_mmanzsym.bmp
Fri Mar 1 11:05:50 2019 1,462 c_re.bmp
Fri Mar 1 11:05:50 2019 658,998 m-i-pd.bmp
Fri Mar 1 11:05:50 2019 658,998 m-i-s-lr.bmp
Fri Mar 1 11:05:50 2019 658,998 m-i-s-rl.bmp
Fri Mar 1 11:05:50 2019 322,614 m-v-pd-b-i.bmp
Fri Mar 1 11:05:50 2019 322,614 m-v-pd-b.bmp
Fri Mar 1 11:05:50 2019 24,240 m-v-pd-b.jpg
Fri Mar 1 11:05:50 2019 322,614 m-v-pd-i.bmp
Fri Mar 1 11:05:50 2019 50,762 m-v-pd-i.jpg
Fri Mar 1 11:05:50 2019 322,614 m-v-pd-l.bmp
Fri Mar 1 11:05:50 2019 51,144 m-v-pd-l.jpg
Fri Mar 1 11:05:50 2019 322,614 m-v-pd-r.bmp
Fri Mar 1 11:05:50 2019 51,112 m-v-pd-r.jpg
Fri Mar 1 11:05:50 2019 658,998 m-v-s-a-lr.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-a-rl.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-b-lr.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-b-rl.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-i-lr.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-i-rl.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-l-lr.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-l-rl.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-r-lr.bmp
Fri Mar 1 11:05:50 2019 658,998 m-v-s-r-rl.bmp
Fri Mar 1 11:05:50 2019 73,018 ma180ccw.bmp
Fri Mar 1 11:05:50 2019 73,018 ma180cw.bmp
Fri Mar 1 11:05:50 2019 499,532 martic6.bmp
Fri Mar 1 11:05:50 2019 389,626 marticcenter1m.bmp
Fri Mar 1 11:05:50 2019 389,628 marticcenter1p.bmp
Fri Mar 1 11:05:50 2019 389,626 marticcenter2m.bmp
Fri Mar 1 11:05:50 2019 389,628 marticcenter2p.bmp
Fri Mar 1 11:05:50 2019 389,626 marticcenter3m.bmp
Fri Mar 1 11:05:50 2019 389,628 marticcenter3p.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor1.bmp
Fri Mar 1 11:05:50 2019 9,718 moutcor1_small.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor2.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor3.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor4.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor5.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor6.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor7.bmp
Fri Mar 1 11:05:50 2019 11,718 moutcor8.bmp
Fri Mar 1 11:05:50 2019 495,376 mstrtneg.bmp
Fri Mar 1 11:05:50 2019 495,376 mstrtpos.bmp
Fri Mar 1 11:05:50 2019 495,376 mstrtzro.bmp
Fri Mar 1 11:05:50 2019 495,376 mstxctr.bmp
Fri Mar 1 11:05:50 2019 16,678 mstxctrp.bmp
Fri Mar 1 11:05:50 2019 495,376 mstxlft.bmp
Fri Mar 1 11:05:50 2019 495,376 mstxrgt.bmp
Fri Mar 1 11:05:50 2019 495,376 mstybck.bmp
Fri Mar 1 11:05:50 2019 495,376 mstyctr.bmp
Fri Mar 1 11:05:50 2019 16,678 mstyctrp.bmp
Fri Mar 1 11:05:50 2019 495,376 mstyfnt.bmp
Fri Mar 1 11:05:50 2019 495,376 mstzpos.bmp
Fri Mar 1 11:05:50 2019 27,478 mtiltABC.bmp
Fri Mar 1 11:05:50 2019 25,318 mtiltcenter4.bmp
Fri Mar 1 11:05:50 2019 25,318 mtiltcenter5.bmp
Fri Mar 1 11:05:50 2019 25,318 mtiltcenter6.bmp
Fri Mar 1 11:05:50 2019 35,062 mtilttable6.bmp
Fri Mar 1 11:05:50 2019 662 mwaterjet.bmp
Fri Mar 1 11:05:50 2019 550,454 m_2v.bmp
Fri Mar 1 11:05:50 2019 550,454 m_2v_tp.bmp
Fri Mar 1 11:05:50 2019 550,454 m_2v_vp1.bmp
Fri Mar 1 11:05:50 2019 550,454 m_2v_vp2.bmp
Fri Mar 1 11:05:50 2019 550,454 m_4v.bmp
Fri Mar 1 11:05:50 2019 550,454 m_4v_tp.bmp
Fri Mar 1 11:05:50 2019 550,454 m_4v_vp1.bmp
Fri Mar 1 11:05:50 2019 550,454 m_4v_vp2.bmp
Fri Mar 1 11:05:50 2019 550,454 m_4v_vp3.bmp
Fri Mar 1 11:05:50 2019 550,454 m_4v_vp4.bmp
Fri Mar 1 11:05:50 2019 73,018 m_arc.bmp
Fri Mar 1 11:05:50 2019 73,018 m_arcccw.bmp
Fri Mar 1 11:05:50 2019 73,018 m_arccw.bmp
Fri Mar 1 11:05:50 2019 499,530 m_artic_b_level.bmp
Fri Mar 1 11:05:50 2019 11,718 m_axis1.bmp
Fri Mar 1 11:05:50 2019 11,718 m_axis2.bmp
Fri Mar 1 11:05:50 2019 11,718 m_axis3.bmp
Fri Mar 1 11:05:50 2019 11,718 m_axis4.bmp
Fri Mar 1 11:05:50 2019 11,718 m_axis5.bmp
Fri Mar 1 11:05:50 2019 9,718 m_axis5_small.bmp
Fri Mar 1 11:05:50 2019 579,100 m_bigjogpanel.bmp
Fri Mar 1 11:05:50 2019 1,144,072 m_bigjogpanel_hi.bmp
Fri Mar 1 11:05:50 2019 11,718 m_bore.bmp
Fri Mar 1 11:05:50 2019 9,718 m_bore_small.bmp
Fri Mar 1 11:05:50 2019 222,838 m_boring_cycle.bmp
Fri Mar 1 11:05:50 2019 11,718 m_bossb.bmp
Fri Mar 1 11:05:50 2019 11,718 m_bossf.bmp
Fri Mar 1 11:05:50 2019 11,718 m_bossl.bmp
Fri Mar 1 11:05:50 2019 9,718 m_bossl_small.bmp
Fri Mar 1 11:05:50 2019 11,718 m_bossr.bmp
Fri Mar 1 11:05:50 2019 222,838 m_chamfer_cycle.bmp
Fri Mar 1 11:05:50 2019 73,018 m_cpock.bmp
Fri Mar 1 11:05:50 2019 73,018 m_cpockn.bmp
Fri Mar 1 11:05:50 2019 11,718 m_csr_b.bmp
Fri Mar 1 11:05:50 2019 11,718 m_csr_f.bmp
Fri Mar 1 11:05:50 2019 11,718 m_csr_l.bmp
Fri Mar 1 11:05:50 2019 11,718 m_csr_r.bmp
Fri Mar 1 11:05:50 2019 73,018 m_cwarc.bmp
Fri Mar 1 11:05:50 2019 72,334 m_digm1.bmp
Fri Mar 1 11:05:50 2019 72,334 m_digm2.bmp
Fri Mar 1 11:05:50 2019 72,334 m_digm3.bmp
Fri Mar 1 11:05:50 2019 46,854 m_digm4.bmp
Fri Mar 1 11:05:50 2019 72,334 m_digm5.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drla.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drlb.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drldh.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drldha.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drldhb.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drlpk.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drlpka.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drlpkb.bmp
Fri Mar 1 11:05:50 2019 73,018 m_drls.bmp
Fri Mar 1 11:05:50 2019 73,018 m_dthrpt.bmp
Fri Mar 1 11:05:50 2019 659,000 m_eb_splayed_cap.bmp
Fri Mar 1 11:05:50 2019 73,018 m_face.bmp
Fri Mar 1 11:05:50 2019 67,254 m_grdeng.bmp
Fri Mar 1 11:05:50 2019 67,254 m_grdfrc.bmp
Fri Mar 1 11:05:50 2019 67,254 m_grdspa.bmp
Fri Mar 1 11:05:50 2019 73,018 m_ic_frm.bmp
Fri Mar 1 11:05:50 2019 11,718 m_incor1.bmp
Fri Mar 1 11:05:50 2019 9,718 m_incor1_small.bmp
Fri Mar 1 11:05:50 2019 11,718 m_incor2.bmp
Fri Mar 1 11:05:50 2019 11,718 m_incor3.bmp
Fri Mar 1 11:05:50 2019 11,718 m_incor4.bmp
Fri Mar 1 11:05:50 2019 73,018 m_ir_frm.bmp
Fri Mar 1 11:05:50 2019 662,362 m_lifter_boring_cycle.bmp
Fri Mar 1 11:05:50 2019 73,018 m_line.bmp
Fri Mar 1 11:05:50 2019 198 m_manual_z_label.bmp
Fri Mar 1 11:05:50 2019 17,506 m_mhset.bmp
Fri Mar 1 11:05:50 2019 73,018 m_mirror.bmp
Fri Mar 1 11:05:50 2019 73,018 m_oc_frm.bmp
Fri Mar 1 11:05:50 2019 73,018 m_or_frm.bmp
Fri Mar 1 11:05:50 2019 222,838 m_o_ring_cycle.bmp
Fri Mar 1 11:05:50 2019 11,718 m_pangle_b.bmp
Fri Mar 1 11:05:50 2019 11,718 m_pangle_f.bmp
Fri Mar 1 11:05:50 2019 11,718 m_pangle_l.bmp
Fri Mar 1 11:05:50 2019 11,718 m_pangle_r.bmp
Fri Mar 1 11:05:50 2019 11,718 m_pangle_t_x.bmp
Fri Mar 1 11:05:50 2019 11,718 m_pangle_t_y.bmp
Fri Mar 1 11:05:50 2019 9,718 m_pangle_t_y_small.bmp
Fri Mar 1 11:05:50 2019 11,718 m_prbsqr.bmp
Fri Mar 1 11:05:50 2019 108,598 m_probe_bores.bmp
Fri Mar 1 11:05:50 2019 36,774 m_probe_x_minus.bmp
Fri Mar 1 11:05:50 2019 36,774 m_probe_x_plus.bmp
Fri Mar 1 11:05:50 2019 36,774 m_probe_y_minus.bmp
Fri Mar 1 11:05:50 2019 36,774 m_probe_y_plus.bmp
Fri Mar 1 11:05:50 2019 67,254 m_radeng.bmp
Fri Mar 1 11:05:50 2019 67,254 m_radfrc.bmp
Fri Mar 1 11:05:50 2019 67,254 m_radspa.bmp
Fri Mar 1 11:05:50 2019 73,018 m_repeat.bmp
Fri Mar 1 11:05:50 2019 17,290 m_rhset.bmp
Fri Mar 1 11:05:50 2019 73,018 m_rotate.bmp
Fri Mar 1 11:05:50 2019 73,018 m_rpock.bmp
Fri Mar 1 11:05:50 2019 11,718 m_rtable.bmp
Fri Mar 1 11:05:50 2019 73,018 m_rtapa.bmp
Fri Mar 1 11:05:50 2019 73,018 m_rtapbh.bmp
Fri Mar 1 11:05:50 2019 73,018 m_rtaps.bmp
Fri Mar 1 11:05:50 2019 73,018 m_tapa.bmp
Fri Mar 1 11:05:50 2019 73,018 m_tapbh.bmp
Fri Mar 1 11:05:50 2019 73,018 m_taps.bmp
Fri Mar 1 11:05:50 2019 960,054 m_tilt_a_level.bmp
Fri Mar 1 11:05:50 2019 871,976 m_tilt_b_level.bmp
Fri Mar 1 11:05:50 2019 5,718 m_toold1.bmp
Fri Mar 1 11:05:50 2019 14,518 m_toolh1.bmp
Fri Mar 1 11:05:50 2019 79,530 m_toolh2.bmp
Fri Mar 1 11:05:50 2019 73,018 m_trde.bmp
Fri Mar 1 11:05:50 2019 73,018 m_trdetb.bmp
Fri Mar 1 11:05:50 2019 73,018 m_trdi.bmp
Fri Mar 1 11:05:50 2019 73,018 m_trdibt.bmp
Fri Mar 1 11:05:50 2019 73,018 m_trditb.bmp
Fri Mar 1 11:05:50 2019 422,454 m_wall_following.bmp
Fri Mar 1 11:05:50 2019 11,718 m_webb.bmp
Fri Mar 1 11:05:50 2019 11,718 m_webf.bmp
Fri Mar 1 11:05:50 2019 11,718 m_webl.bmp
Fri Mar 1 11:05:50 2019 9,718 m_webl_small.bmp
Fri Mar 1 11:05:50 2019 11,718 m_webr.bmp
Fri Mar 1 11:05:50 2019 30,358 m_wk_env.bmp
Fri Mar 1 11:05:50 2019 9,998 m_xmove.bmp
Fri Mar 1 11:05:50 2019 11,718 m_xslot.bmp
Fri Mar 1 11:05:50 2019 9,718 m_xslot_small.bmp
Fri Mar 1 11:05:50 2019 9,998 m_ymove.bmp
Fri Mar 1 11:05:50 2019 11,718 m_yslot.bmp
Fri Mar 1 11:05:50 2019 9,998 m_zmove.bmp
Directory of C:\cncm\CncSkinningDocumentation\html\search
Fri Mar 1 11:10:30 2019 1,256 all_0.html
Fri Mar 1 11:10:30 2019 3,384 all_0.js
Fri Mar 1 11:10:30 2019 1,256 all_1.html
Fri Mar 1 11:10:30 2019 299 all_1.js
Fri Mar 1 11:10:30 2019 1,257 all_10.html
Fri Mar 1 11:10:30 2019 8,210 all_10.js
Fri Mar 1 11:10:30 2019 1,257 all_11.html
Fri Mar 1 11:10:30 2019 964 all_11.js
Fri Mar 1 11:10:30 2019 1,257 all_12.html
Fri Mar 1 11:10:30 2019 1,508 all_12.js
Fri Mar 1 11:10:30 2019 1,257 all_13.html
Fri Mar 1 11:10:30 2019 1,133 all_13.js
Fri Mar 1 11:10:30 2019 1,257 all_14.html
Fri Mar 1 11:10:30 2019 3,841 all_14.js
Fri Mar 1 11:10:30 2019 1,257 all_15.html
Fri Mar 1 11:10:30 2019 548 all_15.js
Fri Mar 1 11:10:30 2019 1,257 all_16.html
Fri Mar 1 11:10:30 2019 548 all_16.js
Fri Mar 1 11:10:30 2019 1,257 all_17.html
Fri Mar 1 11:10:30 2019 192 all_17.js
Fri Mar 1 11:10:30 2019 1,256 all_2.html
Fri Mar 1 11:10:30 2019 2,385 all_2.js
Fri Mar 1 11:10:30 2019 1,256 all_3.html
Fri Mar 1 11:10:30 2019 1,579 all_3.js
Fri Mar 1 11:10:30 2019 1,256 all_4.html
Fri Mar 1 11:10:30 2019 3,791 all_4.js
Fri Mar 1 11:10:30 2019 1,256 all_5.html
Fri Mar 1 11:10:30 2019 1,835 all_5.js
Fri Mar 1 11:10:30 2019 1,256 all_6.html
Fri Mar 1 11:10:30 2019 13,394 all_6.js
Fri Mar 1 11:10:30 2019 1,256 all_7.html
Fri Mar 1 11:10:30 2019 705 all_7.js
Fri Mar 1 11:10:30 2019 1,256 all_8.html
Fri Mar 1 11:10:30 2019 2,382 all_8.js
Fri Mar 1 11:10:30 2019 1,256 all_9.html
Fri Mar 1 11:10:30 2019 524 all_9.js
Fri Mar 1 11:10:30 2019 1,256 all_a.html
Fri Mar 1 11:10:30 2019 338 all_a.js
Fri Mar 1 11:10:30 2019 1,256 all_b.html
Fri Mar 1 11:10:30 2019 1,987 all_b.js
Fri Mar 1 11:10:30 2019 1,256 all_c.html
Fri Mar 1 11:10:30 2019 814 all_c.js
Fri Mar 1 11:10:30 2019 1,256 all_d.html
Fri Mar 1 11:10:30 2019 526 all_d.js
Fri Mar 1 11:10:30 2019 1,256 all_e.html
Fri Mar 1 11:10:30 2019 1,534 all_e.js
Fri Mar 1 11:10:30 2019 1,256 all_f.html
Fri Mar 1 11:10:30 2019 953 all_f.js
Fri Mar 1 11:10:32 2019 1,260 classes_0.html
Fri Mar 1 11:10:30 2019 120 classes_0.js
Fri Mar 1 11:10:32 2019 1,260 classes_1.html
Fri Mar 1 11:10:32 2019 118 classes_1.js
Fri Mar 1 11:10:32 2019 1,260 classes_2.html
Fri Mar 1 11:10:32 2019 117 classes_2.js
Fri Mar 1 11:10:32 2019 1,260 classes_3.html
Fri Mar 1 11:10:32 2019 136 classes_3.js
Fri Mar 1 11:10:32 2019 1,260 classes_4.html
Fri Mar 1 11:10:32 2019 117 classes_4.js
Fri Mar 1 11:10:32 2019 1,260 classes_5.html
Fri Mar 1 11:10:32 2019 148 classes_5.js
Fri Mar 1 11:10:32 2019 1,260 classes_6.html
Fri Mar 1 11:10:32 2019 122 classes_6.js
Fri Mar 1 11:10:32 2019 1,260 classes_7.html
Fri Mar 1 11:10:32 2019 233 classes_7.js
Fri Mar 1 11:10:32 2019 1,260 classes_8.html
Fri Mar 1 11:10:32 2019 416 classes_8.js
Fri Mar 1 11:10:32 2019 1,260 classes_9.html
Fri Mar 1 11:10:32 2019 120 classes_9.js
Fri Mar 1 11:10:32 2019 1,260 classes_a.html
Fri Mar 1 11:10:32 2019 117 classes_a.js
Fri Mar 1 11:10:30 2019 273 close.png
Fri Mar 1 11:10:32 2019 1,258 enums_0.html
Fri Mar 1 11:10:32 2019 145 enums_0.js
Fri Mar 1 11:10:32 2019 1,258 enums_1.html
Fri Mar 1 11:10:32 2019 164 enums_1.js
Fri Mar 1 11:10:32 2019 1,258 enums_2.html
Fri Mar 1 11:10:32 2019 548 enums_2.js
Fri Mar 1 11:10:32 2019 1,258 enums_3.html
Fri Mar 1 11:10:32 2019 328 enums_3.js
Fri Mar 1 11:10:32 2019 1,258 enums_4.html
Fri Mar 1 11:10:32 2019 331 enums_4.js
Fri Mar 1 11:10:32 2019 1,258 enums_5.html
Fri Mar 1 11:10:32 2019 175 enums_5.js
Fri Mar 1 11:10:32 2019 1,258 enums_6.html
Fri Mar 1 11:10:32 2019 322 enums_6.js
Fri Mar 1 11:10:32 2019 1,258 enums_7.html
Fri Mar 1 11:10:32 2019 322 enums_7.js
Fri Mar 1 11:10:34 2019 1,258 enums_8.html
Fri Mar 1 11:10:32 2019 355 enums_8.js
Fri Mar 1 11:10:34 2019 1,258 enums_9.html
Fri Mar 1 11:10:34 2019 297 enums_9.js
Fri Mar 1 11:10:34 2019 1,258 enums_a.html
Fri Mar 1 11:10:34 2019 184 enums_a.js
Fri Mar 1 11:10:34 2019 1,258 enums_b.html
Fri Mar 1 11:10:34 2019 196 enums_b.js
Fri Mar 1 11:10:34 2019 1,258 enums_c.html
Fri Mar 1 11:10:34 2019 183 enums_c.js
Fri Mar 1 11:10:34 2019 1,258 enums_d.html
Fri Mar 1 11:10:34 2019 317 enums_d.js
Fri Mar 1 11:10:34 2019 1,258 enums_e.html
Fri Mar 1 11:10:34 2019 156 enums_e.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_0.html
Fri Mar 1 11:10:34 2019 1,516 enumvalues_0.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_1.html
Fri Mar 1 11:10:34 2019 1,112 enumvalues_1.js
Fri Mar 1 11:10:34 2019 1,264 enumvalues_10.html
Fri Mar 1 11:10:34 2019 1,345 enumvalues_10.js
Fri Mar 1 11:10:34 2019 1,264 enumvalues_11.html
Fri Mar 1 11:10:34 2019 836 enumvalues_11.js
Fri Mar 1 11:10:34 2019 1,264 enumvalues_12.html
Fri Mar 1 11:10:34 2019 3,375 enumvalues_12.js
Fri Mar 1 11:10:34 2019 1,264 enumvalues_13.html
Fri Mar 1 11:10:34 2019 548 enumvalues_13.js
Fri Mar 1 11:10:34 2019 1,264 enumvalues_14.html
Fri Mar 1 11:10:34 2019 548 enumvalues_14.js
Fri Mar 1 11:10:34 2019 1,264 enumvalues_15.html
Fri Mar 1 11:10:34 2019 192 enumvalues_15.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_2.html
Fri Mar 1 11:10:34 2019 595 enumvalues_2.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_3.html
Fri Mar 1 11:10:34 2019 3,578 enumvalues_3.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_4.html
Fri Mar 1 11:10:34 2019 1,524 enumvalues_4.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_5.html
Fri Mar 1 11:10:34 2019 208 enumvalues_5.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_6.html
Fri Mar 1 11:10:34 2019 1,728 enumvalues_6.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_7.html
Fri Mar 1 11:10:34 2019 194 enumvalues_7.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_8.html
Fri Mar 1 11:10:34 2019 200 enumvalues_8.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_9.html
Fri Mar 1 11:10:34 2019 1,245 enumvalues_9.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_a.html
Fri Mar 1 11:10:34 2019 576 enumvalues_a.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_b.html
Fri Mar 1 11:10:34 2019 526 enumvalues_b.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_c.html
Fri Mar 1 11:10:34 2019 193 enumvalues_c.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_d.html
Fri Mar 1 11:10:34 2019 384 enumvalues_d.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_e.html
Fri Mar 1 11:10:34 2019 547 enumvalues_e.js
Fri Mar 1 11:10:34 2019 1,263 enumvalues_f.html
Fri Mar 1 11:10:34 2019 450 enumvalues_f.js
Fri Mar 1 11:10:32 2019 1,262 functions_0.html
Fri Mar 1 11:10:32 2019 1,565 functions_0.js
Fri Mar 1 11:10:32 2019 1,262 functions_1.html
Fri Mar 1 11:10:32 2019 157 functions_1.js
Fri Mar 1 11:10:32 2019 1,262 functions_2.html
Fri Mar 1 11:10:32 2019 156 functions_2.js
Fri Mar 1 11:10:32 2019 1,262 functions_3.html
Fri Mar 1 11:10:32 2019 174 functions_3.js
Fri Mar 1 11:10:32 2019 1,262 functions_4.html
Fri Mar 1 11:10:32 2019 13,186 functions_4.js
Fri Mar 1 11:10:32 2019 1,262 functions_5.html
Fri Mar 1 11:10:32 2019 163 functions_5.js
Fri Mar 1 11:10:32 2019 1,262 functions_6.html
Fri Mar 1 11:10:32 2019 156 functions_6.js
Fri Mar 1 11:10:32 2019 1,262 functions_7.html
Fri Mar 1 11:10:32 2019 158 functions_7.js
Fri Mar 1 11:10:32 2019 1,262 functions_8.html
Fri Mar 1 11:10:32 2019 197 functions_8.js
Fri Mar 1 11:10:32 2019 1,262 functions_9.html
Fri Mar 1 11:10:32 2019 156 functions_9.js
Fri Mar 1 11:10:32 2019 1,262 functions_a.html
Fri Mar 1 11:10:32 2019 613 functions_a.js
Fri Mar 1 11:10:32 2019 1,262 functions_b.html
Fri Mar 1 11:10:32 2019 312 functions_b.js
Fri Mar 1 11:10:32 2019 1,262 functions_c.html
Fri Mar 1 11:10:32 2019 6,457 functions_c.js
Fri Mar 1 11:10:32 2019 1,262 functions_d.html
Fri Mar 1 11:10:32 2019 160 functions_d.js
Fri Mar 1 11:10:32 2019 1,262 functions_e.html
Fri Mar 1 11:10:32 2019 156 functions_e.js
Fri Mar 1 11:10:30 2019 465 mag_sel.png
Fri Mar 1 11:10:32 2019 1,263 namespaces_0.html
Fri Mar 1 11:10:32 2019 95 namespaces_0.js
Fri Mar 1 11:10:34 2019 462 nomatches.html
Fri Mar 1 11:10:34 2019 1,258 pages_0.html
Fri Mar 1 11:10:34 2019 208 pages_0.js
Fri Mar 1 11:10:34 2019 1,258 pages_1.html
Fri Mar 1 11:10:34 2019 79 pages_1.js
Fri Mar 1 11:10:34 2019 1,258 pages_2.html
Fri Mar 1 11:10:34 2019 228 pages_2.js
Fri Mar 1 11:10:34 2019 1,258 pages_3.html
Fri Mar 1 11:10:34 2019 113 pages_3.js
Fri Mar 1 11:10:34 2019 1,263 properties_0.html
Fri Mar 1 11:10:34 2019 155 properties_0.js
Fri Mar 1 11:10:30 2019 4,460 search.css
Fri Mar 1 11:10:34 2019 23,072 search.js
Fri Mar 1 11:10:34 2019 584 searchdata.js
Fri Mar 1 11:10:30 2019 567 search_l.png
Fri Mar 1 11:10:30 2019 158 search_m.png
Fri Mar 1 11:10:30 2019 553 search_r.png
Fri Mar 1 11:10:32 2019 1,262 variables_0.html
Fri Mar 1 11:10:32 2019 145 variables_0.js
Fri Mar 1 11:10:32 2019 1,262 variables_1.html
Fri Mar 1 11:10:32 2019 305 variables_1.js
Fri Mar 1 11:10:32 2019 1,262 variables_2.html
Fri Mar 1 11:10:32 2019 489 variables_2.js
Fri Mar 1 11:10:32 2019 1,262 variables_3.html
Fri Mar 1 11:10:32 2019 362 variables_3.js
Fri Mar 1 11:10:32 2019 1,262 variables_4.html
Fri Mar 1 11:10:32 2019 143 variables_4.js
Fri Mar 1 11:10:32 2019 1,262 variables_5.html
Fri Mar 1 11:10:32 2019 167 variables_5.js
Fri Mar 1 11:10:32 2019 1,262 variables_6.html
Fri Mar 1 11:10:32 2019 278 variables_6.js
Fri Mar 1 11:10:32 2019 1,262 variables_7.html
Fri Mar 1 11:10:32 2019 765 variables_7.js
Fri Mar 1 11:10:32 2019 1,262 variables_8.html
Fri Mar 1 11:10:32 2019 145 variables_8.js
Fri Mar 1 11:10:32 2019 1,262 variables_9.html
Fri Mar 1 11:10:32 2019 143 variables_9.js
Fri Mar 1 11:10:36 2019 9,284 annotated.html
Fri Mar 1 11:10:34 2019 23,873 axisdata.html
Fri Mar 1 11:10:30 2019 676 bc_s.png
Fri Mar 1 11:10:30 2019 147 bdwn.png
Fri Mar 1 11:10:36 2019 9,538 classes.html
Fri Mar 1 11:10:34 2019 3,560 class_cnc_skinning_1_1_namespace_doc.html
Fri Mar 1 11:10:34 2019 8,153 class_cnc_skinning_1_1_skinning-members.html
Fri Mar 1 11:10:34 2019 44,603 class_cnc_skinning_1_1_skinning.html
Fri Mar 1 11:10:34 2019 13,316 class_cnc_skinning_1_1_skinning_1_1_axis-members.html
Fri Mar 1 11:10:34 2019 82,954 class_cnc_skinning_1_1_skinning_1_1_axis.html
Fri Mar 1 11:10:34 2019 4,933 class_cnc_skinning_1_1_skinning_1_1_dro-members.html
Fri Mar 1 11:10:34 2019 13,394 class_cnc_skinning_1_1_skinning_1_1_dro.html
Fri Mar 1 11:10:34 2019 8,967 class_cnc_skinning_1_1_skinning_1_1_job-members.html
Fri Mar 1 11:10:34 2019 39,439 class_cnc_skinning_1_1_skinning_1_1_job.html
Fri Mar 1 11:10:34 2019 4,758 class_cnc_skinning_1_1_skinning_1_1_message_window-members.html
Fri Mar 1 11:10:34 2019 10,140 class_cnc_skinning_1_1_skinning_1_1_message_window.html
Fri Mar 1 11:10:36 2019 12,878 class_cnc_skinning_1_1_skinning_1_1_plc-members.html
Fri Mar 1 11:10:36 2019 72,389 class_cnc_skinning_1_1_skinning_1_1_plc.html
Fri Mar 1 11:10:36 2019 4,614 class_cnc_skinning_1_1_skinning_1_1_screen-members.html
Fri Mar 1 11:10:36 2019 11,463 class_cnc_skinning_1_1_skinning_1_1_screen.html
Fri Mar 1 11:10:36 2019 4,540 class_cnc_skinning_1_1_skinning_1_1_sys-members.html
Fri Mar 1 11:10:36 2019 8,955 class_cnc_skinning_1_1_skinning_1_1_sys.html
Fri Mar 1 11:10:36 2019 11,232 class_cnc_skinning_1_1_skinning_1_1_tool-members.html
Fri Mar 1 11:10:36 2019 54,062 class_cnc_skinning_1_1_skinning_1_1_tool.html
Fri Mar 1 11:10:36 2019 6,741 class_cnc_skinning_1_1_skinning_1_1_wcs-members.html
Fri Mar 1 11:10:36 2019 31,801 class_cnc_skinning_1_1_skinning_1_1_wcs.html
Fri Mar 1 11:10:30 2019 132 closed.png
Fri Mar 1 11:10:34 2019 12,476 cnc12mainscreen.html
Fri Mar 1 11:10:34 2019 27,865 cnc12mainscreen.png
Fri Mar 1 11:10:34 2019 22,331 cnc12mainscreencolored.png
Fri Mar 1 11:10:36 2019 3,287 dir_4df9ea69b3c4006061172aa1fb23cc0a.html
Fri Mar 1 11:10:36 2019 3,379 dir_87b71e891f3c5ab3d3fc0d20c09586ab.html
Fri Mar 1 11:10:36 2019 3,431 dir_f9dfd35b172a0e2036ace76497fb239b.html
Fri Mar 1 11:10:36 2019 746 doc.png
Fri Mar 1 11:10:36 2019 7,563 documentation_logo.png
Fri Mar 1 11:10:30 2019 30,936 doxygen.css
Fri Mar 1 11:10:30 2019 3,779 doxygen.png
Fri Mar 1 11:10:30 2019 4,086 dynsections.js
Fri Mar 1 11:10:34 2019 3,517 examplespage.html
Fri Mar 1 11:10:36 2019 616 folderclosed.png
Fri Mar 1 11:10:36 2019 597 folderopen.png
Fri Mar 1 11:10:34 2019 21,375 GettingSomeAxisData_JogParametersMaxRate.png
Fri Mar 1 11:10:34 2019 21,447 GettingSomeAxisData_JogParametersTravelPlus.png
Fri Mar 1 11:10:34 2019 19,436 GettingSomeAxisData_MainWindow.png
Fri Mar 1 11:10:34 2019 10,408 GettingSomeAxisData_MainWindowDefault.png
Fri Mar 1 11:10:34 2019 10,570 GettingSomeAxisData_MainWindowGet.png
Fri Mar 1 11:10:34 2019 10,760 GettingSomeAxisData_MainWindowGet2.png
Fri Mar 1 11:10:34 2019 10,874 GettingSomeAxisData_MainWindowSet.png
Fri Mar 1 11:10:34 2019 21,933 GettingSomeAxisData_MotorParamters.png
Fri Mar 1 11:10:34 2019 4,983 gettingstarted.html
Fri Mar 1 11:10:36 2019 3,289 index.html
Fri Mar 1 11:10:34 2019 38,902 InitializeSkinning.png
Fri Mar 1 11:10:30 2019 174,033 jquery.js
Fri Mar 1 11:10:30 2019 2,856 menu.js
Fri Mar 1 11:10:36 2019 1,598 menudata.js
Fri Mar 1 11:10:36 2019 31 myStyle.css
Fri Mar 1 11:10:36 2019 3,467 namespaces.html
Fri Mar 1 11:10:34 2019 4,366 namespace_cnc_skinning.html
Fri Mar 1 11:10:30 2019 153 nav_f.png
Fri Mar 1 11:10:30 2019 95 nav_g.png
Fri Mar 1 11:10:30 2019 98 nav_h.png
Fri Mar 1 11:10:30 2019 123 open.png
Fri Mar 1 11:10:36 2019 3,158 pages.html
Fri Mar 1 11:10:36 2019 314 splitbar.png
Fri Mar 1 11:10:34 2019 5,187 struct_cnc_skinning_1_1_skinning_1_1_csr-members.html
Fri Mar 1 11:10:34 2019 14,885 struct_cnc_skinning_1_1_skinning_1_1_csr.html
Fri Mar 1 11:10:36 2019 4,697 struct_cnc_skinning_1_1_skinning_1_1_parameter-members.html
Fri Mar 1 11:10:34 2019 10,480 struct_cnc_skinning_1_1_skinning_1_1_parameter.html
Fri Mar 1 11:10:36 2019 14,885 struct_cnc_skinning_1_1_skinning_1_1_state-members.html
Fri Mar 1 11:10:36 2019 75,860 struct_cnc_skinning_1_1_skinning_1_1_state.html
Fri Mar 1 11:10:36 2019 6,020 struct_cnc_skinning_1_1_skinning_1_1_tool_1_1_info-members.html
Fri Mar 1 11:10:36 2019 14,432 struct_cnc_skinning_1_1_skinning_1_1_tool_1_1_info.html
Fri Mar 1 11:10:30 2019 853 sync_off.png
Fri Mar 1 11:10:30 2019 845 sync_on.png
Fri Mar 1 11:10:30 2019 9,191 tabs.css
Fri Mar 1 11:10:30 2019 142 tab_a.png
Fri Mar 1 11:10:30 2019 169 tab_b.png
Fri Mar 1 11:10:30 2019 177 tab_h.png
Fri Mar 1 11:10:30 2019 184 tab_s.png
Fri Mar 1 11:10:34 2019 18,348 UserControlAddReference.png
Fri Mar 1 11:10:34 2019 26,217 UserControlAddToolbox.png
Fri Mar 1 11:10:34 2019 33,899 UserControlBrowseToolbox.png
Fri Mar 1 11:10:34 2019 5,417 usercontrols.html
Fri Mar 1 11:10:34 2019 4,229 UserControlToolbox.png
Fri Mar 1 11:10:34 2019 10,556 UsingCncSkinning.png
Fri Mar 1 11:10:34 2019 48,232 VisualStudioAddReference.png
Fri Mar 1 11:10:34 2019 15,679 VisualStudioBrowseReference.png
Fri Mar 1 11:10:34 2019 26,575 VisualStudioMainScreen.png
Fri Mar 1 11:10:34 2019 56,102 VisualStudioWpfAppSelect.png
Sat Mar 14 17:59:55 2020 815 Documentation.lnk
Directory of C:\cncm\manual
Fri Mar 1 11:09:28 2019 9,457,060 MillManual.pdf
Directory of C:\cncm\ncfiles\mm
Fri Mar 1 11:06:04 2019 8,546 barrel nut final.cnc
Fri Mar 1 11:06:04 2019 5,248 dual mpg bport style.cnc
Fri Mar 1 11:06:04 2019 7,231 dual mpg bport styledrilling.cnc
Fri Mar 1 11:06:04 2019 10,973 siemens cover spacer plate big.cnc
Fri Mar 1 11:06:04 2019 3,644 siemens cover spacer plate.cnc
Fri Mar 1 11:06:04 2019 2,303 siemens encdr hole mount.cnc
Fri Mar 1 11:06:04 2019 9,638 siemens encoder spacer 2.cnc
Fri Mar 1 11:06:04 2019 1,136 siemens encoder spacer face.cnc
Fri Mar 1 11:06:04 2019 433,372 20r.dig
Fri Mar 1 11:06:04 2019 13,299 atlanta.cnc
Fri Mar 1 11:06:04 2019 30,244 bikersblvd.nc
Fri Mar 1 11:06:04 2019 26,406 Boss control panel.nc
Fri Mar 1 11:06:04 2019 7,309 cam.cnc
Fri Mar 1 11:06:04 2019 39,701 camcw.cam
Fri Mar 1 11:06:04 2019 1,434 Circler pocket.cnc
Fri Mar 1 11:06:04 2019 1,419 circular Frame.cnc
Fri Mar 1 11:06:04 2019 4,089 cleanout.cnc
Fri Mar 1 11:06:04 2019 6,177 c_rod.cnc
Fri Mar 1 11:06:04 2019 2,592 elbow.cnc
Fri Mar 1 11:06:04 2019 15,392 f2.cnc
Fri Mar 1 11:06:04 2019 5,202 flange.cnc
Fri Mar 1 11:06:04 2019 1,416 helix.cnc
Fri Mar 1 11:06:04 2019 3,071 irr.cnc
Fri Mar 1 11:06:04 2019 5,029 irreg.cnc
Fri Mar 1 11:06:04 2019 12,107 jkm_rod_jaw.cnc
Fri Mar 1 11:06:04 2019 2,636 Lathe tool block.cnc
Fri Mar 1 11:06:04 2019 18,529 pistolgrip2.cnc
Fri Mar 1 11:06:04 2019 2,206 recycle.cnc
Fri Mar 1 11:06:04 2019 3,183 recycle2.cnc
Fri Mar 1 11:06:04 2019 6,531 SEM_coverplat 2.cnc
Fri Mar 1 11:06:04 2019 4,438 SEM_coverplat.cnc
Thu Apr 2 13:49:44 2020 4,471 spindlebenchtest.cnc
Fri Mar 1 11:06:04 2019 2,604 thread.cnc
Fri Mar 1 11:06:04 2019 3,317 threadmillin.cnc
Fri Mar 1 11:06:04 2019 16,015 TRIPLE FLANGE.cnc
Fri Mar 1 11:06:04 2019 646,804 vcarvetest2.cnc
Directory of C:\cncm\reportbackup
Sat Mar 14 18:06:50 2020 191,726 report_0925192286_2020-03-14_18-06-49.zip
Fri Mar 27 16:19:38 2020 194,655 report_0925192286_2020-03-27_16-19-32.zip
Fri Apr 3 07:58:08 2020 206,931 report_0925192286_2020-04-03_07-58-02.zip
Directory of C:\cncm\resources\homing\PairedAxesAutoSquaring
Fri Jan 17 10:44:42 2020 2,388 cncm.hom
Fri Jan 17 10:44:42 2020 2,539 Header.txt
Fri Jan 17 10:44:42 2020 276 HomeAllHeader.txt
Directory of C:\cncm\resources\wizard\default\drives
Fri Jan 17 10:44:42 2020 8,818 AutomationDirectKL-5080H.xml
Fri Jan 17 10:44:42 2020 8,196 BenchTest'DB25'.xml
Fri Jan 17 10:44:42 2020 8,220 BenchTest'ScrewTerminal'.xml
Fri Jan 17 10:44:42 2020 7,609 CentroidCNC4Micro1.xml
Fri Jan 17 10:44:42 2020 8,193 ChineseRouter.xml
Fri Jan 17 10:44:42 2020 7,617 ClearpathSDSK&SDHP.xml
Fri Jan 17 10:44:42 2020 8,744 DeltaASDA.xml
Fri Jan 17 10:44:42 2020 8,783 DMMDYN2.xml
Fri Jan 17 10:44:42 2020 8,118 DMMDYN4.xml
Fri Jan 17 10:44:42 2020 8,748 EstunPronet.xml
Fri Jan 17 10:44:42 2020 7,620 GeckoG201,G214,andothers.xml
Fri Jan 17 10:44:42 2020 8,743 GeckoG540'DriveOnly'.xml
Fri Jan 17 10:44:42 2020 7,875 GeckoG540'Legacy'.xml
Fri Jan 17 10:44:42 2020 8,812 LeadShineCS-D1008.xml
Fri Jan 17 10:44:42 2020 8,202 LeadshineDMSeries.xml
Fri Jan 17 10:44:42 2020 8,739 TECOTSTA.xml
Fri Jan 17 10:44:42 2020 8,750 YaskawaSigma.xml
Directory of C:\cncm\resources\wizard\default\plc
Fri Jan 17 10:44:40 2020 220,786 acorn_universal_template.src
Fri Jan 17 10:44:40 2020 45,675 functions.xml
Fri Jan 17 10:44:40 2020 2,634 plcmsg.txt
Directory of C:\cncm\system
Fri Mar 1 11:06:04 2019 802 5axis.cnc
Fri Mar 1 11:05:48 2019 37,266 artic_wall_follow.cnc
Fri Mar 1 11:05:48 2019 918 atan2.cnc
Fri Mar 1 11:06:04 2019 219 bbxy100.cnc
Fri Mar 1 11:06:04 2019 219 bbxy150.cnc
Fri Mar 1 11:06:04 2019 219 bbxy300.cnc
Fri Mar 1 11:06:04 2019 315 bbxz100.cnc
Fri Mar 1 11:06:04 2019 315 bbxz150.cnc
Fri Mar 1 11:06:04 2019 315 bbxz300.cnc
Fri Mar 1 11:06:04 2019 315 bbyz100.cnc
Fri Mar 1 11:06:04 2019 315 bbyz150.cnc
Fri Mar 1 11:06:04 2019 315 bbyz300.cnc
Fri Mar 1 11:05:48 2019 7,502 bound_dig_pass.cnc
Fri Mar 1 11:06:04 2019 3,534 condtest.cnc
Fri Mar 1 11:05:48 2019 1,454 correct_position.cnc
Fri Mar 1 11:05:48 2019 1,176 correct_position_a.cnc
Fri Mar 1 11:05:48 2019 1,263 correct_position_b.cnc
Fri Mar 1 11:06:04 2019 6,568 create-artic-head-lookup-tables.cnc
Fri Mar 1 11:06:04 2019 7,676 create-lookup-and-tri-rotary-tables.cnc
Fri Mar 1 11:05:48 2019 5,469 create-straight-rotary-artic-head-lookup-tables.cnc
Fri Mar 1 11:05:48 2019 5,833 grid_digitize.cnc
Fri Mar 1 11:05:48 2019 922 move_primitive.cnc
Fri Mar 1 11:05:48 2019 3,240 probe_angle.cnc
Fri Mar 1 11:05:48 2019 596 probe_bore.cnc
Fri Mar 1 11:05:48 2019 2,295 probe_boss.cnc
Fri Mar 1 11:05:48 2019 1,250 probe_center_inside.cnc
Fri Mar 1 11:05:48 2019 2,594 probe_center_outside.cnc
Fri Mar 1 11:05:48 2019 1,543 probe_clearance_traverse.cnc
Fri Mar 1 11:05:48 2019 3,364 probe_clearance_traverse_across_and_down.cnc
Fri Mar 1 11:05:48 2019 1,414 probe_comp_two_points_on_a_line.cnc
Fri Mar 1 11:05:48 2019 9,769 probe_cycles_select.cnc
Fri Mar 1 11:05:48 2019 1,478 probe_get_constants.cnc
Fri Mar 1 11:05:48 2019 1,280 probe_get_modals.cnc
Fri Mar 1 11:05:48 2019 2,586 probe_inside_corner.cnc
Fri Mar 1 11:05:48 2019 1,493 probe_limit_position.cnc
Fri Mar 1 11:05:48 2019 8,998 probe_move.cnc
Fri Mar 1 11:05:48 2019 1,932 probe_move_to_intersection.cnc
Fri Mar 1 11:05:48 2019 1,383 probe_move_to_surface.cnc
Fri Mar 1 11:05:48 2019 5,408 probe_outside_corner.cnc
Fri Mar 1 11:05:48 2019 2,090 probe_protected_move.cnc
Fri Mar 1 11:05:48 2019 2,713 probe_pull_back.cnc
Fri Mar 1 11:05:48 2019 1,688 probe_step_over.cnc
Fri Mar 1 11:05:48 2019 1,946 probe_tt1_move.cnc
Fri Mar 1 11:05:48 2019 2,486 probe_two_points_on_wall.cnc
Fri Mar 1 11:05:48 2019 6,318 probe_user_vars.txt
Fri Mar 1 11:05:48 2019 788 probe_write_point_to_file.cnc
Fri Mar 1 11:05:48 2019 1,427 rotate_b_position.cnc
Fri Mar 1 11:05:48 2019 1,038 rotate_vector.cnc
Fri Mar 1 11:05:48 2019 1,143 rotate_vector_b.cnc
Fri Mar 1 11:05:48 2019 1,281 scale_vector.cnc
Fri Mar 1 11:06:04 2019 2,915 setup_probe_artic_head.cnc
Fri Mar 1 11:06:04 2019 791 tchkdemo.cnc
Fri Mar 1 11:06:04 2019 15,919 test3b.cnc
Fri Mar 1 11:06:04 2019 6,922 test3c.cnc
Fri Mar 1 11:06:04 2019 52,943 test3e.cnc
Fri Mar 1 11:06:04 2019 8,129 test4b.cnc
Fri Mar 1 11:06:04 2019 56,436 test4e.cnc
Fri Mar 1 11:06:04 2019 1,678 toolcht1.cnc
Fri Mar 1 11:06:04 2019 964 tt1loc.cnc
Fri Mar 1 11:05:48 2019 3,099 vertical_wall_follow.cnc
Fri Mar 1 11:05:48 2019 18,677 wall_following.cnc
Bridgeport V2XT, All In One DC #A900779. Using existing SEM motors 112 Volt. Spindle to be controlled by Lenze AC Tech VFD mod #ESV222N02YXB. Machine is being run on 208 3Phase power.
Re: Spindlebenchtest
Please post this file: C:\cncm\reportbackup\report_0925192286_2020-04-03_07-58-02.zip
Beagle Beagle
CNC Control System Serial Number: A900779
Post by Beagle Beagle »
Now I'm really lost. Isn't that the file that's listed? Ok, where do I find that one?
No. You pasted into your message the content of a report*.txt file (perhaps report_0925192286_2020-04-03_07-58-02.txt). There is much information in the ZIP file that is not in the TXT file.
If I recall correctly, much earlier in this thread we went over how to show file extensions in Windows, so that you can readily tell the difference between somefile.txt and somefile.zip.
Use the "Post Reply" button, or the "Full Editor & Preview" button, to get to a screen where you can choose to attach files (rather than paste them in). Look for the "Attachments" tab below the window you are composing your message in, then browse to where you have stored your report, then look for a ZIP file. Windows typically displays ZIP files using an icon that looks like a file folder with a zipper on it, or a C-clamp around it. This is different from the page-of-text icon that Windows typically uses for TXT files.
Beagle Beagle
Here ya go.
report_0925192286_2020-04-04_16-37-05.zip
(193.02 KiB) Downloaded 113 times
In your error message log you have:
(1)   04-04-2020 16:36:26 199 CNC Started
(4)   04-04-2020 16:36:28 9033 Reset Initiated, Press Reset to Clear
(1)   04-04-2020 16:36:28 412 X axis(1) encoder differential error
(1)   04-04-2020 16:36:28 412 Y axis(2) encoder differential error
(1)   04-04-2020 16:36:28 412 Z axis(3) encoder differential error
(1)   04-04-2020 16:36:28 407 X+ limit (#50002) tripped
(1)   04-04-2020 16:36:28 407 Y- limit (#50003) tripped
(1)   04-04-2020 16:36:29 407 Y+ limit (#50004) tripped
(1)   04-04-2020 16:36:29 407 Z- limit (#50005) tripped
(1)   04-04-2020 16:36:29 407 Z+ limit (#50006) tripped
(1)   04-04-2020 16:36:30 CNC12-D Mill v4.14
First, the differential errors are probably because you do not have your encoders connected.
If you want to run with no encoders connected, you will need to defeat the encoder differential error check. You can do that by setting Machine Parameters 332 and 333 both to a value of 7.
Second, the tripped-limit errors are probably because you have toggled the limit switch defeaters down (on), but you have also used Ctrl-Alt-i to invert five of the six limit switch inputs. Assuming you do not have limit switches actually connected, you need to defeat limits either by inverting the inputs with Ctrl-Alt-i, or by toggling the DIP switches down, but not both.
Beagle Beagle
Now were getting so where. You are right. My encoders are all ready installed on the machine. So I will change those pars. So let me understand this. If I have the limit switches on the allin1 board flipped down to defeat the limit switches by enabling the pars for them I 'm over riding the dip switches on the board? If this is the case? Could you provide me with the par numbers I have to have red as I don't have a list of what number does what. Thanks, Bob
Just to clarify things: Parameters have numerical values and not colors. They are modified by F1 Setup/F3 Config/F3 Params then selecting the parameter to be changed and then entering a new numerical value. These parameters and values are listed in Chapter 14 of the CNC12 Operator's Manual.
Inputs and Outputs, which are color coded on the I/O diagnostic screen (Alt-I on the main screen to activate), can be "forced" or "inverted" to change their default actions. See this document which will tell you what each color and overscore and underscore lines signify.
