Page 3 of 7
Re: UMC10 from Flashcut to Acorn?
Posted: Tue Jan 25, 2022 8:10 pm
by Fastest1
I actually meant where in the drive directories would the macros be?
Posted: Tue Jan 25, 2022 8:14 pm
What are the model numbers in ALL 5 drives?
I thought there were 3 axis of servo drives and two steppers or no?
Remember there is an LDCN utility to configure the drives as well
Posted: Tue Jan 25, 2022 8:15 pm
You can open the macros from within the FC configuration utility
Posted: Tue Jan 25, 2022 8:16 pm
by Fastest1
Where is this set up file? I went page by page thru all of the settings saving each. Yes I could open them but couldnt copy or save them. All of the drives are the ones mentioned above. LS182SE-1210's
Posted: Tue Jan 25, 2022 8:29 pm
Fastest1 wrote: ↑Tue Jan 25, 2022 8:16 pm
when in FC, you can click on file, save setup to save a copy of it. You may also see the default location.
Just look at the C: drive with Windows File manager
It is on the C: drive and I believe in a DATA folder
Posted: Tue Jan 25, 2022 11:16 pm
by Fastest1
It saves it in an .stp file?
Posted: Wed Jan 26, 2022 12:19 am
Fastest1 wrote: ↑Tue Jan 25, 2022 11:16 pm
I believe so, make a copy of it and open with a text editor like Notepad++
Posted: Wed Jan 26, 2022 4:38 pm
by Fastest1
I was able to open the file with notepad as you stated. There is info similar to my xml file when using Mach.
However it appears much larger.
I also copied each macro and saved on a thumb drive.
Looking thru the tool change file/macro (and not understanding it) I dont see the physical location of the tool change.
I couldnt find these files anywhere within the C drive. Only when I actually selected the macros 1 by 1 on the FC screen.
Posted: Wed Jan 26, 2022 4:41 pm
Its been quite awhile since I worked with Flashcut.
Posted: Wed Jan 26, 2022 4:42 pm
by Fastest1
This is what I was able to copy just for the turret it appears.
Not sure why it says "not downloaded" from my view though I can open them from the link just fine.
