UMC10 from Flashcut to Acorn?
Re: UMC10 from Flashcut to Acorn?
I actually meant where in the drive directories would the macros be?
1st Acorn project. G0704/BDTools/Hoss Conversion De"maching"
Leadshine MX 3660
Repurposed above Acorn (#194) and an Ethernet 1616 to a UMC-10 with an 8 position tool changer.
CNC12 Pro/Digitizing ver 4.64 (1/31/2022)
Leadshine MX 3660
What are the model numbers in ALL 5 drives?
I thought there were 3 axis of servo drives and two steppers or no?
Remember there is an LDCN utility to configure the drives as well
You can open the macros from within the FC configuration utility
Where is this set up file? I went page by page thru all of the settings saving each. Yes I could open them but couldnt copy or save them. All of the drives are the ones mentioned above. LS182SE-1210's
Leadshine MX 3660
Leadshine MX 3660
when in FC, you can click on file, save setup to save a copy of it. You may also see the default location.
Just look at the C: drive with Windows File manager
It is on the C: drive and I believe in a DATA folder
It saves it in an .stp file?
Leadshine MX 3660
Leadshine MX 3660
I believe so, make a copy of it and open with a text editor like Notepad++
I was able to open the file with notepad as you stated. There is info similar to my xml file when using Mach.
However it appears much larger.
I also copied each macro and saved on a thumb drive.
Looking thru the tool change file/macro (and not understanding it) I dont see the physical location of the tool change.
I couldnt find these files anywhere within the C drive. Only when I actually selected the macros 1 by 1 on the FC screen.
Leadshine MX 3660
Leadshine MX 3660
Its been quite awhile since I worked with Flashcut.
This is what I was able to copy just for the turret it appears.
Not sure why it says "not downloaded" from my view though I can open them from the link just fine.
Leadshine MX 3660
Leadshine MX 3660
