slodat wrote: ↑Fri Feb 01, 2019 4:32 pm
Making sure I’m following.. this differential driver is needed(?) for noise issues in the step/direction signals between Acorn and DYN4 drive?
Slodat,
The differential driver is not explicitly required. There has been some chatter on the forums of how electrical noise in control panels is affecting the step signal into the DYN4. The DYN 4 does seem work fine with the recommended Centroid wiring diagram, if you are careful to follow shielding recommendations and layout your panel to separate the Acorn step wiring from high voltage and current. I chose to make a board to allow for custom cable connection for a couple of reasons. They are:
1. The DYN4 does accept a differential input, which is less susceptible to noise. I figured I would just go this extra step to avoid potential issues. To be clear, it sounds like most people don't have issues using the step/direction wiring as indicated in the Acorn to DMM wiring schematic.
2. I'm really OCD when it comes to wire routing and panel neatness. I figured this custom board would allow me to have a nice clean installation.
3. I wanted to try and have a custom circuit board made as a learning experience.
It will be cheaper and easier for you to order the CNC4PC boards and you gain all the differential signal benefits with a lot less work. Follow this thread for how to do that.
viewtopic.php?f=60&t=2610
Once I get my prototype boards. I'll solder one together and bench test. I'll have a couple extra boards. DM me and we can arrange for you to have one, if you wish. I may also just share the Gerber file so people can order the boards themselves. It might be cheaper to order more boards than it would be for me to mail from Canada.
Scott
