No motor movement
Gary Campbell
Re: No motor movement
Post by Gary Campbell »
Leadshine drives are enabled with no connection, unless reprogrammed.
Kutton
Post by Kutton »
I need to start over.
(1) best schematic to use for my setup
(2) I do not have shutoff wired as directed.
(3) the way it is presently sometimes reset dose not work. Have to exit control software and restart.
I did not get green light ground to enable.
https://youtu.be/Abvw7OaSKq4
Please give your suggestions.
Gary Campbell
Please show a wizard screenshot showing the DB25 pin assignments
Kutton
Post by Kutton »
Did not know I neede to set that.
Still getting probe detected while jogging. No axes movement.
Please....follow this post:
viewtopic.php?f=60&t=1043
We can't help you without more information. You have WAY too many inputs turned on. Why?
Please go to the post above and follow it.
Then we can help you better
Gary Campbell
After following Marty's instruction let us know which one of the DB25 pages is the one you are using. You show 3, one is different than the other 2.
Kutton
Post by Kutton »
Do not understand too many inputs turned on.
You understand what we are asking you to do in this post?:
Input Output map. Set all inputs to UNUSED except input Number 8 and for test purposes set it to NO to see if you get motor movement.
There isn't much on your motor driver, this is what I found:
This sort of information is helpful to be provided so we know what you are using.
http://s3.amazonaws.com/s3.image.smart/ ... 045-A1.pdf
It appears that by default if there is no connection to ENA, the drive should enable the motor. So leave it disconnected for now.
When you power up the drive with the motor connected, can you turn the motor shaft with your fingers or is it locked on position?
(Do not use Acorn to turn the motor shaft. Simply turn on the power to the ST-4045 with the stepper motor connected to it and see if the motor shaft is locked)
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
The reason your motor is not moving is you assigned the pins incorrectly.
Look at your screen shot of the DB25 connector. You started assigning motor connections with Pin-1, You need to start with Pin-2, X-step
You have step and direction on the wrong pins for each motor. As soon as you correct these connections it will work.
You might want to start with one motor, say X. Pin2 = Xstep Pin3-Xdir
Russ
