Page 3 of 3
Re: CNC12 for Allin1 DC, still scheduled for release this summer? <released>
Posted: Fri Sep 21, 2018 8:25 pm
by Fueler1
Thank you. That's a good start.
#2. When you write "build a new cncpc", to what are you referring? I don't have a new blank pc. Just updating the original console.
Posted: Mon Sep 24, 2018 10:14 am
Fueler1 wrote: Fri Sep 21, 2018 8:25 pm Thank you. That's a good start.
i call the PC that is running the CNC control a CNCPC:-)
Posted: Tue Sep 25, 2018 1:48 pm
by tblough
I thought I read previously that CNC12 would require PLC program changes when upgrading from CNC11. If that is correct, could you provide a little more detail on what changes will be required?
Posted: Tue Nov 13, 2018 1:06 pm
by CRM
converterking wrote: Wed Sep 19, 2018 6:45 am If you have a wired control panel and mpg, is there any advantage in updating to cnc12 software?
+1
Inquiring minds want to know... ;)
Posted: Tue Nov 13, 2018 1:30 pm
by Centroid_Liviu
CRM wrote: Tue Nov 13, 2018 1:06 pm
+1
Are you running a Basic PLC program or did you customize it? We have CNC12 versions of the Basic PLC programs.
Posted: Tue Nov 13, 2018 1:57 pm
by CRM
I have the generic PLC program...BUT, I'm running windows 7 on a NUC. I have integrated the handheld pendant 4:3 aspect ratio touch screen and wired MPG into a nice console. Not sure it is worth the expense to upgrade to Win10 at this point.
Posted: Mon Nov 19, 2018 3:30 pm
by tblough
When upgrading from CNC11 to CNC12 on an Oak controller are PLC changes only necessary if we want to use VCP and USB MPG? I do not have either of those, but I do have some customization to my PLC program. I was wondering if I could just keep the same PLC program when upgrading?
Posted: Mon Nov 19, 2018 3:53 pm
by eng199
tblough wrote: Tue Sep 25, 2018 1:48 pm I thought I read previously that CNC12 would require PLC program changes when upgrading from CNC11. If that is correct, could you provide a little more detail on what changes will be required?
CNC12 doesn't require any PLC changes. If you change hardware (MPU12/REDOAK) or add virtual control panel, USB MPG, etc., that can require changes.
