Page 3 of 5
Re: Acorn wireless MPG
Posted: Sat Jun 09, 2018 12:14 pm
bilorn wrote: Sat Jun 09, 2018 11:04 am DMM DYN4 x and z are 400w y is a 750w.
Should be no creep down.
I assume you wired them absolutely per the schematic.
Posted: Sat Jun 09, 2018 4:15 pm
by bilorn
It's wired as per schematic.
I'm putting off any more on z axis until I get the new spindle cable.
Any clues as to what might be going on with my MPG, looks as if I'm the only one having problems with it. I don't feel
that special!
Posted: Sun Jun 10, 2018 2:50 pm
by Reedfirst
When I first connected my MPG to my system I had the same exact symptoms you described.
The issues were resolved by re-booting the pc anc cnc12 with the wireless receiver disconnected. Then I re-booted it again with the receiver connected and the MPG on before I turned on the system.
I haven't had a problem since.
Posted: Mon Jun 11, 2018 1:47 pm
by bilorn
Thank you Reed, that did the trick however Windows required a third boot to get the touch screen back!
Hooray, the MPG sure makes setups easier.
Thanks again. :D :D
Posted: Mon Jun 11, 2018 1:53 pm
bilorn wrote: Mon Jun 11, 2018 1:47 pm Thank you Reed, that did the trick however Windows required a third boot to get the touch screen back!
Thanks again. :D :D
Well, something new in the bag of tricks.
Thanks for posting this.
Posted: Mon Jun 11, 2018 5:59 pm
by Reedfirst
Thanks again. :D :D
That's great! I'm glad it worked for you!
Posted: Mon Jun 11, 2018 6:59 pm
Do confirm all is well and we'll mark your topic SOLVED
Posted: Mon Jun 11, 2018 7:52 pm
by bilorn
I'm hopeful and confident that MPG problem is solved, not really sure how though! Windows is like our government!
I made the mistake of stating two problems, MPG and z down drift.
The main thing that made a difference was changing the step polarity. Moving wires has no effect on y axis after change.
I believe down drift is caused by the vfd ( hopefully cable ) and I think the down drift is caused when spindle starts and z axis
makes big move from home position. The drift seems to be proportional to z movement.
I made a servo motor mounting plate from 1/2" micarta and the .3" deep rectangular pocket was cut without z moving.
After I install new spindle cable I'll check again for z drift.
I don't have an ac filter on the vfd yet but servos have individual filters on both power and control sides.
I will be firing up machine shortly and will report back on MPG situation.
Thank you
Posted: Mon Jun 11, 2018 8:26 pm
bilorn wrote: Mon Jun 11, 2018 7:52 pm I'm hopeful and confident that MPG problem is solved, not really sure how though! Windows is like our government!
Thank you
Are you using an external 5VDC power supply or trying to use DYN4's 5VDC power supply?
This issue about DYN4 and Z axis creep has come up before. Seems that if you try and use the DYN4 power supply that creates a problem. Use an external power supply and it works fine.
download/file.php?id=1404&mode=view
Posted: Mon Jun 11, 2018 9:01 pm
by bilorn
I am using a wallwart 5v supply, it uses a 3 terminal regulator, less than 5 mv. ripple, same with 24v supply.
