Page 3 of 9
Re: 325 Limit Error?
Posted: Fri Dec 17, 2021 1:33 pm
by RGSparber
RGSparber wrote: Fri Jan 12, 2018 6:46 pm I'm going to be away from my CNC for a little while so will pick up this mystery ASAP.
Thanks for all of your help,
Rick
Damn! It has been a LONG while. I'm back on my mill now and seeing a 327 fault. Besides having totally forgotten about this thread, I've had a major Windows upgrade plus upgraded CNC12 from 4.12 to 4.64. This fault occurs at different points in my code.
Any idea what is going on here?
Thanks in advance,
Rick
Posted: Fri Dec 17, 2021 1:58 pm
what's the issue?
report shows limit trips and probe trips
(1) 12-17-2021 5:42:59 930 Log Level Configuration file not found... Creating new configuration.
(1) 12-17-2021 5:42:59 933 Log file initialized
(1) 12-17-2021 5:42:59 199 CNC Started
(1) 12-17-2021 5:43:03 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 12-17-2021 5:43:04 335 Emergency stop released
(4) 12-17-2021 5:43:05 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 12-17-2021 5:43:16 PLC Program change detected.
(1) 12-17-2021 5:43:18 204 Exiting CNC...Normal Exit (66)
(1) 12-17-2021 5:44:25 199 CNC Started
(1) 12-17-2021 5:44:31 CNC12 Acorn Mill v4.64
(1) 12-17-2021 5:44:32 9033 Reset Initiated, Press Reset to Clear
(1) 12-17-2021 5:44:46 Created Weekly Report
(1) 12-17-2021 5:45:19 Report installed from D:\backup files for update to CNC4.65\report_38D269533454-0111180523_2021-12-17_04-45-34.zip
(1) 12-17-2021 5:45:32 Exiting CNC and shutting down machine (68)
(1) 12-17-2021 5:47:35 199 CNC Started
(1) 12-17-2021 5:47:41 CNC12 Acorn Mill v4.64
(1) 12-17-2021 5:52:03 204 Exiting CNC...Normal Exit (66)
(1) 12-17-2021 5:52:11 199 CNC Started
(4) 12-17-2021 5:52:15 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 12-17-2021 5:52:17 CNC12 Acorn Mill v4.64
(4) 12-17-2021 5:52:17 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 12-17-2021 5:54:21 407 Y+ limit (#50002) tripped
(1) 12-17-2021 5:54:21 407 Z+ limit (#50003) tripped
(1) 12-17-2021 5:54:21 340 Y+ limit (#50002) cleared
(1) 12-17-2021 5:54:29 204 Exiting CNC...Normal Exit (66)
(1) 12-17-2021 5:54:32 199 CNC Started
(4) 12-17-2021 5:54:36 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 12-17-2021 5:54:38 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 12-17-2021 5:54:46 PLC Program change detected.
(1) 12-17-2021 5:54:48 204 Exiting CNC...Normal Exit (66)
(1) 12-17-2021 5:55:53 199 CNC Started
(1) 12-17-2021 5:56:00 CNC12 Acorn Mill v4.64
(4) 12-17-2021 5:56:00 9033 Reset Initiated, Press Reset to Clear
(1) 12-17-2021 5:56:08 8040 WARNING: PROBE TRIPPED
(1) 12-17-2021 5:56:12 302 Moving...
(1) 12-17-2021 5:56:18 407 Z+ limit (#50003) tripped
(1) 12-17-2021 5:56:19 313 Waiting for dwell time (M26)
(1) 12-17-2021 5:56:22 407 Y+ limit (#50002) tripped
(1) 12-17-2021 5:56:25 407 X- limit (#50001) tripped
(1) 12-17-2021 5:56:27 306 Job finished
(1) 12-17-2021 6:00:13 913 Could not open file CNC bottom drawing 4.nc
(1) 12-17-2021 6:00:13 338 Job cancelled
(1) 12-17-2021 6:00:32 407 Z+ limit (#50003) tripped
(1) 12-17-2021 6:00:36 407 Y+ limit (#50002) tripped
(1) 12-17-2021 6:00:39 407 X- limit (#50001) tripped
(1) 12-17-2021 6:02:04 907 Y axis travel exceeded
(1) 12-17-2021 6:04:57 304 MDI...
(1) 12-17-2021 6:05:13 916 Unexpected probe contact
(1) 12-17-2021 6:05:46 204 Exiting CNC...Normal Exit (66)
(1) 12-17-2021 6:05:50 199 CNC Started
(4) 12-17-2021 6:05:54 8040 WARNING: PROBE TRIPPED
(1) 12-17-2021 6:05:56 CNC12 Acorn Mill v4.64
(4) 12-17-2021 6:05:56 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 12-17-2021 6:05:56 9033 Reset Initiated, Press Reset to Clear
(1) 12-17-2021 6:08:55 407 Y+ limit (#50002) tripped
(1) 12-17-2021 6:08:55 407 Z+ limit (#50003) tripped
(1) 12-17-2021 6:12:12 407 Y+ limit (#50002) tripped
(1) 12-17-2021 6:12:12 407 Z+ limit (#50003) tripped
(1) 12-17-2021 6:12:52 204 Exiting CNC...Normal Exit (66)
(1) 12-17-2021 6:12:56 199 CNC Started
(4) 12-17-2021 6:12:59 9033 Reset Initiated, Press Reset to Clear
(1) 12-17-2021 6:13:02 CNC12 Acorn Mill v4.64
(4) 12-17-2021 6:13:02 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 12-17-2021 6:13:02 9033 Reset Initiated, Press Reset to Clear
(4) 12-17-2021 6:13:06 8040 WARNING: PROBE TRIPPED
(1) 12-17-2021 6:13:06 4032 Reset Cleared
(1) 12-17-2021 6:13:15 407 Z+ limit (#50003) tripped
(1) 12-17-2021 6:13:20 407 Y+ limit (#50002) tripped
(1) 12-17-2021 6:13:45 407 X- limit (#50001) tripped
(1) 12-17-2021 6:13:52 FAST_JOG_SELECTED
(4) 12-17-2021 6:15:29 8040 WARNING: PROBE TRIPPED
(1) 12-17-2021 6:15:29 341 Probing Cycle finished
(1) 12-17-2021 6:15:31 9042 Probe Cleared
(1) 12-17-2021 6:15:45 FAST_JOG_SELECTED
(4) 12-17-2021 6:16:23 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:16:28 9042 Probe Cleared
(1) 12-17-2021 6:16:31 FAST_JOG_SELECTED
(1) 12-17-2021 6:17:01 307 Operator abort: job cancelled
(4) 12-17-2021 6:17:03 907 Z axis travel exceeded
(4) 12-17-2021 6:20:08 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:20:11 9042 Probe Cleared
(4) 12-17-2021 6:20:14 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:20:36 9042 Probe Cleared
(4) 12-17-2021 6:20:36 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:20:39 9042 Probe Cleared
(4) 12-17-2021 6:20:40 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:20:43 9042 Probe Cleared
(1) 12-17-2021 6:21:52 FAST_JOG_SELECTED
(4) 12-17-2021 6:22:04 9042 Probe Cleared
(1) 12-17-2021 6:22:06 FAST_JOG_SELECTED
(4) 12-17-2021 6:22:33 9042 Probe Cleared
(1) 12-17-2021 6:22:37 FAST_JOG_SELECTED
(4) 12-17-2021 6:23:13 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:23:17 9042 Probe Cleared
(4) 12-17-2021 6:24:24 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:24:57 9042 Probe Cleared
(4) 12-17-2021 6:25:41 8040 WARNING: PROBE TRIPPED
(4) 12-17-2021 6:27:29 9042 Probe Cleared
(4) 12-17-2021 6:27:29 8040 WARNING: PROBE TRIPPED
(1) 12-17-2021 6:27:35 FAST_JOG_SELECTED
(1) 12-17-2021 9:53:03 Tool change: T1 1/4" end mill
(1) 12-17-2021 9:54:08 327 Fault: job cancelled
(4) 12-17-2021 9:57:33 9033 Reset Initiated, Press Reset to Clear
(4) 12-17-2021 9:57:34 4032 Reset Cleared
(1) 12-17-2021 9:59:27 Tool change: T1 1/4" end mill
(1) 12-17-2021 10:01:03 SLOW_JOG_SELECTED
(1) 12-17-2021 10:01:41 FAST_JOG_SELECTED
(4) 12-17-2021 10:06:23 907 Z axis travel exceeded, line 20
(1) 12-17-2021 10:06:23 325 Limit: job cancelled
(4) 12-17-2021 10:12:42 907 Z axis travel exceeded
(1) 12-17-2021 10:19:48 Tool change: T1 1/4" end mill
(4) 12-17-2021 10:25:13 9033 Reset Initiated, Press Reset to Clear
(4) 12-17-2021 10:25:14 4032 Reset Cleared
(1) 12-17-2021 10:27:04 Creating report...
Posted: Fri Dec 17, 2021 2:25 pm
by RGSparber
Keith,
Your comment is very helpful. I don't have my probe connected and I'm far from any limit switches. There may be noise getting into these lines. Time to pull out my 'scope.
Thanks!
Rick
Posted: Fri Dec 17, 2021 3:42 pm
Rick, were you using or testing the probe since you installed 4.64?
Is the machine homing OK?
What kind of switches do you have for homing?
Also, are you setting your part zero positions correctly? Do you press F8 to Graph the part prior to running the part to see if you getting any axis exceeded errors?
Posted: Fri Dec 17, 2021 6:57 pm
by RGSparber
Marty,
I have tested the probe since installing 4.65. I had previously set Part 0 and then power cycled. Then I measured the location of part 0 wrt Home and it was off by 4 thou on the X axis, 8 thou on the Y axis and 5 thou on the Z axis. My home switches are magnetic proximity switches.
Murphy is certainly watching over me. I wanted to gather information on the failure so ran the program again. This time it ran for almost 20 minutes before I got the 327 fault. Previous runs were under 10 minutes. No other information on the screen. I was unable to move the tool via the control panel until I did a Reset. Maybe that is one piece of the puzzle.
I am confused by what, exactly, 327 means. I'd also like to know what file in the report zip file contains all of those faults with time stamps.
I'm fairly sure I'm dealing with a noise problem here since the run time before the 327 varies. Knowing what conditions caused this fault would help me focus my attention in the right area.
I wasn't aware of F8 for graphing the part but will certainly do that next time. I do run my gcode through ncviewer.com to review the paths. It said all was right but the part is coming out shifted by more than 0.1" both in the X and Y directions. Yet, when I check Part 0, it is reasonably close to right.
Thanks!
Rick
Posted: Fri Dec 17, 2021 7:40 pm
First, you mean Centroid CNC 12 version 4.64. There is no version 4.65.
Is it a 327 Error or a 325 Error?
Centroid Alarm 327 Fault: job cancelled
Cause & Effect
job was cancelled because of a fault
Centroid Alarm 325 Limit: job cancelled
Cause & Effect
job was cancelled because of a limit error
Suggest you change inputs 1,2&3 from axis 1,2,3 HomeLimitOk
to axis 1,2,3 HomeOk and retest.
Posted: Fri Dec 17, 2021 8:01 pm
If you get the fault again after changing your inputs to HomeOk
Please take a screenshot using the Windows SNIPping tool and post it here along with a fresh report.
Posted: Sat Dec 18, 2021 3:01 pm
Likely cause is unexpected input triggering due to faulty switches or noise.
Marty has a good suggestion because if you define the input as home it doesn't look at that input while it's running a job only while homing.
Posted: Sat Dec 18, 2021 3:45 pm
cnckeith wrote: Sat Dec 18, 2021 3:01 pm Likely cause is unexpected input triggering due to faulty switches or noise.
Yes, and the control will rely on the soft limits assuming they are set correctly
327 Fault (not 325)
Posted: Sat Dec 18, 2021 6:11 pm
by RGSparber
With the spindle motor off, I did not have any problems for about 150 lines of code. With the motor running and under load, I got the 327 fault again. I have attached a screen shot plus the latest Report. I then made the change that Marty suggested and it failed at line 43 with the same 327 fault. I know the point of failure changes each time I run.
I'm still confused by what 327 means. If it is just a pointer into the Report for more information, what does it say?
Rick
