Please provide a fresh report for us.
On a fresh install of CNC12 v5.30 for Hickory I see the outputs in the list:
Build Thread for Bridgeport Torq-Cut 30
- Tech Support
Re: Build Thread for Bridgeport Torq-Cut 30
- Hickory CNC Controller: Yes
That is interesting. I even tried installing a fresh copy of v5.30 right off the Centroid website yesterday. I thought maybe I didn't have the license installed but that was not the case. Attached is the report and two screen shots showing all the available output options.
- Tech Support
You'll need to scroll down, the entire wizard screen is not being displayed.
Use the scroll bar on the far right so you can see the outputs at the bottom of the list:
Yup, that was it. What a big dummy I am. I was just using the center scroll bar to scroll down. Too many late nights with this thing.CentroidFrog wrote: ↑Fri Sep 05, 2025 3:15 pm You'll need to scroll down, the entire wizard screen is not being displayed.
The Wizard doesn't fit all that well in those little 4:3 screens.
Thank you.
i run a 1920x1080 monitor when setting up with the Wizard even if i plan on using a 4:3 console setup for final configuration.juspk wrote: ↑Fri Sep 05, 2025 4:34 pmYup, that was it. What a big dummy I am. I was just using the center scroll bar to scroll down. Too many late nights with this thing.CentroidFrog wrote: ↑Fri Sep 05, 2025 3:15 pm You'll need to scroll down, the entire wizard screen is not being displayed.
Thank you.
Hello all,
Is there a way to run the Wizard without being connected to the Hickory board? (on another computer) I tried running the .exe out of the cncm folder but it does't work, it wants cnc12 running. The reason I ask is because I'm starting to learn Centroid PCL programming and if I could make changes in the Wizard, and then compare the .src before and after files, it would give me a better understanding.
