Awesome!!dovrosenberg wrote: ↑Fri May 09, 2025 8:29 am I resolved the issues I was having. I moved the wiring from the 24V screw terminals to the DB25 5V and removed the ENA+ and ENA- from my CL86T and CL57T stepper drives. I had to switch the drives from 24V (factory default setting) to 5V using the S3 switch next to the DIP switches. Even though the I had the latest version of the drivers that the docs say fully support 24V, 1 of the 3 CL86T drivers actually worked at 24v properly as expected. 1 seemed to have gotten fried. When I switched to 5v, the one driver that wasnt working started. The CL57T driver was totally non functional at 24V even with the switch set to 24v from the factory. I changed it over to 5V and now it is working. Someone on another Facebook group, said he was using CL86Y and CL57Y drivers at 24V with no problem
Drive Fault on all drives (Resolved)
- Plasma CNC Controller: Yes
Re: Drive Fault on all drives - RESOLVED
Re: Drive Fault on all drives (Resolved)
This flash code should also be stated in the driver manual.
skysmotor.co.uk sells the following products online: ac servo motor, BLDC motor, stepper motor drivers, planetary gearbox and can be purchased online if required.
These drivers are ok on the headers If you run them slow and 100kHz max.
To get max performance up to Acorns 400 kHz use the latest 4.1 Driver version on 5V
