Updated probe with ALLIN1DC
centroid467
Re: Updated probe with ALLIN1DC
Post by centroid467 »
P155 should be 0 for that type of probe.
I am a little confused by the message persisting when P153 is set to 0 though.
Is that wiring description giving the pin numbers where it connects to the ALLIN1DC or CPC bulkhead connector?
lavrgs
Post by lavrgs »
Sorry here is the connector I was talking about I will set 153 to 0 and try again
I will set 155 to zero. With the detect jumper does 153 matter?
EDIT I still get the message that no touch tool is detected
On page 10 of the Alt-i display (press Alt-i, then press F12 nine times):
What color are INP769 and INP772 when the tool probe is disconnected?
What color are INP769 and INP772 when the tool probe is connected but not tripped?
What color are INP769 and INP772 when the tool probe is connected and tripped?
lavrgs
Probe Config
Post by lavrgs »
cncsnw wrote: Tue May 27, 2025 9:35 pm
UPDATE i CHANGED p257 TO 50771 AND SEE ACTION... Now I need to relearn how to Measure tools..
The changes did not affect the conditions below
772 does not come on - I changed P18 from 50771 to 50772 - no change
Note that if I unplug the cable at the bulkhead all leds are off
Cable bulkhead Plugged 771 is on
Probe Connected 771 is on
Probe tripped 769 and 771 are on
