Fryer et-18 easy turn Lathe: AcornSix, USBBOB, plcext1616 does not work <resolved switch to advanced i/o>
centroid467
Re: plcext1616 does not work <switch to advanced i/o>
Post by centroid467 »
How are those handwheels working for you? I noticed that they look to have a differential output but USBBOB expects single ended. Very nice build by the way, excellent cabinet layout.
Angelo DiCenso
CNC Control System Serial Number: cnc12 Mill Pro E0623483321F-0412225912,CNC Router Pro E0623479658B-1022203857
Post by Angelo DiCenso »
They work great centroid467, do you have an issue with them? I can send you my wiring
centroid467
Angelo DiCenso wrote: Fri Jan 17, 2025 12:27 pm They work great centroid467, do you have an issue with them? I can send you my wiring
I don't have any issues with them but I am definitely curious about the wiring.
Angelo DiCenso
Angelo DiCenso wrote: Fri Jan 17, 2025 7:20 am
thanks! this helps so much to see what you are working on! 8-)
Angelo DiCenso
Re: Fryer et-18 easy turn Lathe: AcornSix, USBBOB, plcext1616 does not work <resolved switch to advanced i/o>
cnckeith, suntravel and others
mfunc4.mac
(5.21 KiB) Downloaded 4 times
mfunc3.mac
(5.27 KiB) Downloaded 4 times
This is the auto gear selection High and low M3 and M4 that I have done so far. I am very confused on the part :
where can I obtain the assigned g code speed (Sxxxx value) so that I can use it as reference to ( if sxxxx >=350RPM High Gear otherwise Low Gear)
CNC system variable #4119 holds the last (RPM-mode) 'S' command.
See section 8.2.16 in the Lathe operator's manual.
Angelo DiCenso
cncsnw; thanks for the reply.
What I have done in the two M3 and M4 will then work?
Angelo DiCenso
For everyone:
After fixing some small errors these M3 and M4 files work.
Now my lathe will switch gears depending on the spindle speed programmed in the G code
Thank you for the help
mfunc3.mac
(5.29 KiB) Downloaded 7 times
mfunc4.mac
(5.23 KiB) Downloaded 4 times
Thanks for sharing.
