routeur cnc acorn auto construction
Filardo
Re: routeur cnc acorn auto construction
Post by Filardo »
martyscncgarage wrote: Tue Jun 14, 2022 10:28 am Mistake, DIVIDE the pitch by the reduction
Hello everyone
Well here is problem solved it was about my position of the Switch cl86t microphones which is the same as the others but which leave from sw1 while the cl86y leave from sw3
Stupid human error
Bonjour tout le monde
Bon voila problème résolu il s'agissait de ma position des micros Switch cl86t qui est la même que les autres mais qui partent à partir de sw1 alors que les cl86y partent à partir de sw3
Erreur humaine toute bête
Filardo
Post by Filardo »
Could you tell me if my settings are good for the axes
If it is not better that I take other position of micro Switch
Pourriez vous me dire si mes réglages sont bon pour les axes
Si il ne vaut mieux pas que je prenne d'autres position de micro Switch
Filardo wrote: Tue Jun 14, 2022 11:31 pm Could you tell me if my settings are good for the axes
Don't understand what you are asking.
Filardo
Post by Filardo »
martyscncgarage wrote: Wed Jun 15, 2022 2:15 am
I wanted to know if I stay on 4000 on the encoder or if I have to take another setting on the micro switch because the y axis motor picks up at 4200 in advance
Je voulais savoir si je reste sur 4000 sur le codeur ou si il faut que je prenne un autre réglages sur les micro Switch par ce que le moteur de axe y décroche a 4200 en avance
Stay on the 4000 if that is what is working for you. Do not understand what you mean, Y axis motor picks up at 4200
It is important to follow the drive manual and set the encoder counts per the manual.
Filardo
Post by Filardo »
Well ok it does not matter thank you anyway for the time you devote to me
Bon ok ce n'est pas grave merci quand même pour le temps que vous me consacrez
Filardo
Post by Filardo »
[/quote
Since I have a ratio of 1/2 or 2/1 I don't know.
my advances are not good in machining they are necessarily divided by 2 can you adjust this report
I looked in the manual and I can't find how to calibrate my feeds in real time
Vu que j'ai un rapport de 1/2 ou 2/1 je n'en sais rien
mes avance ne sont pas bonnes en usinage elle sont forcément divisé par 2 peut t'on régler ce rapport
J'ai regardé dans le manuel et je ne trouve pas comment étalonner mes avances en temps réel
Filardo
Post by Filardo »
Bon fameux teste du rond 1centieme de différence en x et y
set steps per rev to match the drive. then and only then adjust the overal turns ratio. see this post.
https://centroidcncforum.com/viewtopic.php?f=63&t=1801
Filardo
Post by Filardo »
cnckeith wrote: Fri Jun 17, 2022 3:09 pm set steps per rev to match the drive. then and only then adjust the overal turns ratio. see this post.
[/quote
OK thanks a lot
I had another question for electrical cabinet
I would like to dismantle my pc tower to integrate everything inside, is it possible?
PC-Tower is too small to make an easy to configure cabinet.
Better to get one from Rittal at least 600x600x250mm
