routeur cnc acorn auto construction
Re: routeur cnc acorn auto construction
Here are the workouts
https://m.facebook.com/groups/entraide. ... 201871669/
Just need help setting up the axes
Thank you beforehand
Juste besoin d'aide pour configurer les axes
En vous remerciant d'avance
So you got you axis moving. Good
Make SURE you have the steps per motor revolution correct. Then:
Translate and read the Acorn Installation Manual:
Specifically starting on page 78
Have you looked at the report?martyscncgarage wrote: ↑Tue Jun 14, 2022 9:23 am So you got you axis moving. Good
Avez vous regarder le rapport ?
Axis Label Motor Encoder Lash Comp. Limit Home Dir ScrewFilardo wrote: ↑Tue Jun 14, 2022 9:34 amHave you looked at the report?martyscncgarage wrote: ↑Tue Jun 14, 2022 9:23 am So you got you axis moving. Good
mm/rev counts/rev. (mm) - + - + Rev Comp
1 X 5.0000 4000 0.0150 0 0 0 0 N N
2 Y 3.9500 4000 0.0150 0 0 0 0 N N
3 Z 5.0000 2000 0.0000 0 0 0 0 N N
Why is your Z axis show only 2000 encoder counts? Same drive ax X/Y? Should be same encoder count.
Also, if you have belt reduction on your axis, say you have 20/40 teeth or 2:1 reduction then you multiply the ballscrew pitch by that much.
So for X if you have 2:1 belt reduction, 2*5mm you would enter 10 (instead of 5)
Follow the installation manual.
Ok mercimartyscncgarage wrote: ↑Tue Jun 14, 2022 10:03 amAxis Label Motor Encoder Lash Comp. Limit Home Dir ScrewFilardo wrote: ↑Tue Jun 14, 2022 9:34 amHave you looked at the report?martyscncgarage wrote: ↑Tue Jun 14, 2022 9:23 am So you got you axis moving. Good
Mistake, DIVIDE the pitch by the reduction
I believe that my step problem on the y axis comes from the computer which is not the same
This is the cl86t
While the other x and z axes are cl86y
Je crois que mon problème de pas sur l'axe y viens du calculateur qui est pas le même
Il s'agit du cl86t
Alors que les autres axe x et z sont des cl86y
CL86T is with 5V logic. Use DB25 for DIR and PUL
Always best to use the same 3 motors and drives. I would replace that odd ball set to match the other two.
