Filardo
Posts: 253 Joined: Wed Jul 28, 2021 3:54 am
Post
by Filardo » Sun Jun 12, 2022 11:58 am
martyscncgarage wrote: ↑ Sun Jun 12, 2022 11:35 am
Need pictures and link to your stepper drive manual, and how you have them connected to Acorn.
driver documentation
la documentation du driver
Y-serie-closed-loop-drivers.pdf
(3.18 MiB) Downloaded 27 times
Posts: 3657 Joined: Thu Sep 23, 2021 3:49 pm
Post
by suntravel » Sun Jun 12, 2022 12:05 pm
Maybe you need to reverse enable....
Filardo
Post
by Filardo » Sun Jun 12, 2022 12:29 pm
suntravel wrote: ↑ Sun Jun 12, 2022 12:05 pm
already done thank you I have the impression that the axis of the motor remains stuck but which requires that it turn and my driver indicates a default which comes and goes
déjà fait merci
Jai impression que l'axe du moteur reste collé mais qui demande qua tourner
et mon driver indique un default qui va et revient
Posts: 9953 Joined: Tue Mar 28, 2017 12:01 pm
Post
by martyscncgarage » Sun Jun 12, 2022 5:13 pm
Fresh Report please
F7 Utility
F7 Create Report
In Wizard DB25 mapping what is selected? DB25 or terminal?
Filardo
Post
by Filardo » Sun Jun 12, 2022 11:35 pm
martyscncgarage wrote: ↑ Sun Jun 12, 2022 5:13 pm
Fresh Report please
F7 Utility
F7 Create Report
[/quo
I'm doing this tonight at work around 5:00 p.m.
Je fais ça ce soir au travail vers 17h00
Filardo
Post
by Filardo » Mon Jun 13, 2022 8:18 am
Fresh Report please
F7 Utility
F7 Create Report
well i think i found it
not seen behind motor plug
The colors are actually in the same place.
Bon je crois que j'ai trouvé
pas vu derrière la fiche du moteur
Effectivement les couleurs sont aux mêmes emplacement
Posts: 8958 Joined: Wed Mar 03, 2010 4:23 pm
Post
by cnckeith » Mon Jun 13, 2022 4:34 pm
VIDEO
Post
VIDEO
Post
by martyscncgarage » Mon Jun 13, 2022 4:46 pm
Make SURE you are using the Encoder Extension cable as well
You still have NOT posted a Fresh Report from CNC12
F7 Utility, F7 Create Report
Filardo
Post
by Filardo » Tue Jun 14, 2022 12:38 am
martyscncgarage wrote: ↑ Mon Jun 13, 2022 4:46 pm
sorry for the report i just posted
can you help me to adjust the axes
x and y 10mm pitch with 1/2 ratio larger pulley on ballscrew
live z axis with 5mm step
désolé pour le rapport je vient de poster
pouvez vous Maider a régler les axes
x et y pas de 10 mm avec un rapport de 1/2 plus grande poulie sur la vis a bille
axe z en direct avec un pas de 5 mm
report_0035FF9709E3-0629214878_2022-06-14_06-29-56.zip
(801.79 KiB) Downloaded 23 times
