10-22-24 UPDATE! CNC12 v5.20 has been released Mill, Lathe, Router, Plasma is now available for public testing.
mgeyer
Re: 10-22-24 UPDATE! CNC12 v5.20 has been released Mill, Lathe, Router, Plasma is now available for public testing.
Post by mgeyer »
LSGreen wrote: Sun Nov 03, 2024 9:10 pm So far, and I'm not very far into v5.2 but when I turn on the wireless MPG the speakers on my computer start rapidly clicking. Haven't had this happen in prior versions. :?
Are you using wireless speakers? This sounds like you're experiencing some sort of interference between two wireless devices operating at the same frequency.
LSGreen
CNC Control System Serial Number: None
Post by LSGreen »
Nope, my speakers are wired. Thanks for the response.
grossmsj
Post by grossmsj »
FWIW, since I installed 5.18 my MPG will occasionally have very jumpy movements. If I spin the wheel the machine will sort of lurch along, and I see the DRO numbers on the MPG increment very slowly. When I restart the computer the problem disappears. It sort of looks like there is a very slow polling.
Have not gone through installation of 5.2
grossmsj wrote: Wed Nov 06, 2024 7:01 pm FWIW, since I installed 5.18 my MPG will occasionally have very jumpy movements. If I spin the wheel the machine will sort of lurch along, and I see the DRO numbers on the MPG increment very slowly. When I restart the computer the problem disappears. It sort of looks like there is a very slow polling.
maybe mpg is going bad? v5.18 and v5.20 is running hundreds of wmpg's with no complaints so i dont' think its a CNC12 thing you are experiencing. :D
hmm well that is odd. there has been no changes on the wireless mpg that i can think of that would cause that.
LSGreen
Post by LSGreen »
cnckeith wrote: Thu Nov 07, 2024 8:44 pm
Yea, I don't know. My MPG is new, only a few operations with it. Like I said, I Haven't experienced the noise with any lower versions. Maybe I will reinstall v5.20. Just For fun, see what happens. :P
biobrett
CNC Control System Serial Number: Not Shown
Post by biobrett »
I don't know if this is the correct place to post this, but I have an issue with the "Job Run Options" -> "Search" function since updating to 5.22. The first time I use search (since starting CNC12), it works fine. The second time I happen to use it, it causes the application to crash (CNC12 exits). I'm wondering if anyone else has this issue and whether there is a fix?
Small update, I tried this in the "offline" version and experienced the same behavior.
bb
ASPeters
Post by ASPeters »
biobrett wrote: Tue Jan 14, 2025 1:04 pm I don't know if this is the correct place to post this, but I have an issue with the "Job Run Options" -> "Search" function since updating to 5.22. The first time I use search (since starting CNC12), it works fine. The second time I happen to use it, it causes the application to crash (CNC12 exits). I'm wondering if anyone else has this issue and whether there is a fix?
bb
Please see this post: https://centroidcncforum.com/viewtopic. ... 703#p94703
If you are experiencing similar behavior, it is fixed and will be part of the next beta/release.
