Millport VMC1660 Centroid Upgrade (Leadshine EL7)
All things ecat Hickory CNC controller
KreiderMachine
CNC Control System Serial Number: A901521, A901583
Re: Millport VMC1660 Centroid Upgrade (Leadshine EL7)
Post by KreiderMachine »
The other issue I'm trying to resolve this morning is the following:
Every time I open the hickory wizard it gives the following error message:
CNC Control Configuration Wizard: Error!
The following errors were reported:
An error has occurred while loading Drives from:
.\resources\wizard\saved\plcPresets\.
There is an error in XML document (2, 2).
The contents of that folder are attached.
The wizard is set to not overwrite a custom PLC.
There is an empty 'drives' folder at the same level as 'plcPresets.' I think the error initially appeared after I had attempted to backup my wizard settings.
plcPresets.zip
(9.52 KiB) Not downloaded yet
