Retrofit My Build Looking at Switching from Mach4 to Centroid System
Re: Retrofit My Build Looking at Switching from Mach4 to Centroid System
Sword wrote: Thu Jan 16, 2025 4:35 pm Use the GRBL output and then "Save to G-code", along with the custom start/end code option in machine settings. Then if you need some further editing of the saved G-code, open it in Notepad++ and make a macro to do any of that. My macro starts at the first line and automatically makes all the needed changes and then saves the file.
Further info...https://centroidcncforum.com/viewtopic. ... 920#p72920
Uwe and Scott, thanks for the reminder about this post, great info.
i copied that original thread into the knowledge base forum and retitled it so it shows up better in the search.
https://centroidcncforum.com/viewtopic. ... 858#p95858
Onawa220
CNC Control System Serial Number: 0008DC111213-0116240167
Post by Onawa220 »
Awesome! Thank you guys. Too bad they, Lightburn, didn't make it a little easier to do but that makes it a lot easier.
That is super easy...
Post from Lightburn in the \ncfiles folder
load job
edit gcode
run macro
hit cycle start
:D
Onawa220
Post by Onawa220 »
suntravel wrote: Thu Jan 16, 2025 5:00 pm That is super easy...
load job
edit gcode
run macro
hit cycle start
:D
With this information it's easy now. Without it though...... :)
Onawa220
Post by Onawa220 »
ok and other quick question. What gcode would I add to the end of my post processor in Vetric to make the spindle return to my work zero? I did a quick search and I probably just missed it.
Sword
Post by Sword »
There are a few ways to do it, but here's a snip of my end of program. I prefer the Z axis to be at the top when finished (Machine Z home), before going anywhere else.
M25 ; Move to Z home
M5 ; Spindle Off
M9 ; Dust Collection Off
G0 X0.000000 Y0.000000
Scott
Onawa220
Post by Onawa220 »
Sword wrote: Thu Jan 16, 2025 5:35 pm There are a few ways to do it, but here's a snip of my end of program. I prefer the Z axis to be at the top when finished (Machine Z home), before going anywhere else.
M5 ; Spindle Off
That's kind of what I was picturing but I've caused issues in Mach4 thinking I knew what I was doing on that one :) Thank you.
are you using the Teknic RAS feature in there setup software for the axis motors?
Onawa220
Post by Onawa220 »
cnckeith wrote: Thu Jan 16, 2025 9:06 pm are you using the Teknic RAS feature in there setup software for the axis motors?
Sorry I didn't see this post.
Yes the engineer that logged into my servos remotely set RAS up.
RAS introduces a lag that shows itself with Laser applications (XYZ)
when using a diode laser you can compensate for the lag introduced by RAS
with this added feature in version 5.24+ PWM Laser Delay Fine Tuning Parameter 424 added. Useful for compensating
for millisecond delays introduced when using RAS with Clearpath servos.
page 14
https://www.centroidcnc.com/dealersuppo ... ds/326.pdf
