Centroid CNC12 v5.04 has been released. UPDATE v5.06 has been released.
- CNC Control System Serial Number: acorn 6810
Re: Centroid CNC12 v5.04 has been released. Click here to download.
Thanks for looking at this. I am in CNC12 setup(F1) feed(F4) abs(F1) or inc(F2). There is no highlighted box to enter a value as there is in v4.82
Tim
Tim
I'd better show it quick
Okie dokie. I'll check it out. Thanks for the infoTimothy Clement wrote: ↑Wed Jul 26, 2023 2:18 pm Thanks for looking at this. I am in CNC12 setup(F1) feed(F4) abs(F1) or inc(F2). There is no highlighted box to enter a value as there is in v4.82
Tim
In the meantime just use MDI. And type in the g code that you want to do the move and press cycle start
That old feed menu really isn't used that often anymore.
Thanks for the video. We'll look into the keyboard jogging indicator problem
For the lathe g28
Why not change the post processor to go to the position that you want?
You could actually program it to look at a variable in CNC12
and then you could create a macro, assign it to a VCP button to set the new retract position and that would be part of job setup. Jog the carriage to the position you want , Push the button on the VCP that writes the machine coordinate information to a parameter. And the g-code program would simply have a g53 and look at the value in the variable that you decided to use, the contains the position information
Also we install a limit switch that rides along with the tail stock so that the lathe carriage won't crash into it accidentally as a safety.
- PLC Expert
The M55 Button is available on the VCP on Lathe by default to allow some easy access to custom Macros.
We can Modify the mfunc55.mac file found under C:\cnct and add the following line.
Then in your G-Code or can put this in another M-Code and call that M-Code in your Job, you would have the following code that will move the Z back to this saved position.
This would let you press the M55 VCP button to save the Z machine position to P700,then you can call that position later. You can add the X Axis if you wish as well by using the #5021 system variable and could save its value to P701 for example.
Reference our Centroid introduction to macro programming manual which covers some of the basics such as the G10 command and explains system variables.
G10 P1700 R#5022 ;Save Current Z Machine Position to P700
G53 Z#9700 ;Move Z to P700 Machine Position
Centroid PLC Tutorial Videos
thanks chris!Allin1Chris wrote: ↑Thu Jul 27, 2023 2:35 pm The M55 Button is available on the VCP on Lathe by default to allow some easy access to custom Macros.
Then in your G-Code or can put this in another M-Code and call that M-Code in your Job, you would have the following code that will move the Z back to this saved position.Code: Select all
This would let you press the M55 VCP button to save the Z machine position to P700,then you can call that position later. You can add the X Axis if you wish as well by using the #5021 system variable and could save its value to P701 for example.Code: Select all
Stephan,
hello.
on the keyboard jogging Active indicator color of green.
we can not reproduce the issue you are having.
we can all see the green and read it.
do you have same issue on another monitor?
hello.
i changed mine from green
to Red using the color picker.
now it looks like this.
Thanks for showing me how to change the color. If I change the color then it's easy to read. If I leave the green I have to get very close and then I can read it too.
Do you both understand?
Imagine you are a beginner.
A beginner does not change color first.
A beginner wants to understand everything first, not change colors.
With the color of V4.8 I can easily read what is happening.
And could just start
The G28 for easy changing was an idea I know from Mach3.
Of course you can change that with macro..... and line....
I think this function is very helpful. But how to do it that works then I have no idea.
You can include this function or not. As you want.
I think it would be great to have a button like that, but like I said, it's a suggestion
Then I showed them the SSV.
This is also just a suggestion.Also that would be a good tool for Centroid.
Can it be that Haas has the right to copy it?
Best regards Stephan
mach has done a bunch of non standard/industrial stuff over the years, so just because mach does it doesn't mean its a good idea.
