Tree Journeyman 425 mill retrofit
Re: Tree Journeyman 425 mill retrofit
Well said, Marty. I agree on all points. I'm happy with the machine. I'm not aware of another manufacturer that offers NEMA standard mounting and ZRI output. I have two machines running on the DMM DYN4 motors and drives, and they run great now!
Acorn powered CNC router
JMC is also available in 110mm (Nema42) and with ZRI homing. Decent manual and till now I did not need service, wire up and they run without problems. I use them for axis and spindle drive. If needed service is from german dealer or from JMC directly.
Kollmorgen also makes NEMA pattern, but they are very expensive.
My production machines have Mitsubishi 1.5 kw servos on the axis drives up to 1500 ipm and they last >20 years 24/5 , but also expensive.
