Something is still wrong with that last row of buttons on the VCP (13-15). I haven't been able to figure it out yet, so going back to V5.02 for now. One observation, the default router layout has Laser Check X0Y0 at button 15, it runs mfunc47.mac, which would normally be the macro used with goto machine XY0 (a button that seems to be troublesome to use in any location). I'll come back to it when I have some time again, but something just doesn't seem right with that row.20.) Updated Aux 13 and 14 skin events in the button xml file to match the updated numbers. These updates were inadvertently omitted.
Centroid CNC12 v5.04 has been released. UPDATE v5.06 has been released.
Re: Centroid CNC12 v5.04 has been released. Click here to download.
Scott
Stephan, thanks for you input. we have found a way to make things work in regards to windows settings in other languages better.
have you tried cnc12 on a different monitor? i'm not sure why you cna't read the font , i think it has to do with your monitor.
Thanks for optimizing the language.
The green color is too light it is like neon color the color is lighter like the writing.
I have no idea why
but it is only one script.
When I activate jog.
You can try a darker color. Maybe that will work.
Can you do the site like Uwe
The dogs maybe not but actually is perfect.
nice and clear
Would it be possible to make a button where you can easily set the G28 point?
In most programs I have G28 as the first line.
I somehow always do it that way and the postprocessor does it too.
Would it be possible?
The machine doesn't always have to move back and forth if I build the same workpiece 50 times.
Set G28 would be the name for the button....
Can Centroid SSV?
I can only say it again and again and I am happy about it every day.
G70 to G84 works perfectly.
Your since Indstry for little money.
Greetings Stephan
I have no idea why
nice and clear
Can Centroid SSV?
Greetings Stephan
i'm not sure which color you are having issues with. have you tried to change it in the color picker? (F7 Utility, ----> F5 Color Picker)
what are you trying to accomplish by changing the G28 position?
explain the necessity of this request please.
maybe there is another way to accomplish the same goal without using G28?
if you post is putting out G28 commands where you do not want them, change the post.
I assume he wants a convenient way to set the G28 position for the upcoming job (i.e. Z just clear of the end of the stock).
That seems like a reasonable request. More people would probably change their G28 returns to suit the job at hand, if they knew it was possible.
G53 is ready to go to command to move to any machine coordinate system location.
G28 is used for tool check, changing and then forgetting that you changed it could be catastrophic.
I agree with Keith, I wouldn't use G28 for anything other than what it's intended for. If you need a custom move then create your own macro for this of edit your PP to make the move for you when you need it. If it's the same move every time just create a button for the VCP and write a custom macro for it.
- CNC Control System Serial Number: acorn 6810
I have just installed v5.04
In setup/feed/abs or inc there appears to be no way to enter or change values. Is this a corrupt installation or or are these items broken?
Tim
Tim
Timothy Clement wrote: ↑Tue Jul 25, 2023 7:53 pm I have just installed v5.04
Tim
report_80F5B5AA31FD-0127236810_2023-07-25_16-43-28.zip
where are you at in 'setup' ? in the wizard? or cnc12? or intercon? etc..
