Filardo
Post
by Filardo »
suntravel wrote: ↑Sun Apr 03, 2022 1:37 am
What is the weight oft the gantry?
You can still double the torque with a 2:1 beltdrive on the steppers and have 10000mm/min rapids.
what do you recommend as a pinion level transmission size
que me conseillez vous comme taille de transmission niveau pignon
Post
by suntravel »
I would use HTD 5M 15mm beltdrive for this weight.
Calculation can be done here easy:
https://www.maedler.de/Static/Tools
Filardo
Post
by Filardo »
Ok merci pour votre réponse
Filardo
Post
by Filardo »
Here is what I found
Voici ce que j'ai trouvé
Filardo
Filardo
Post
by suntravel »
Very nice, but put the smaller pulley on the drive and the bigger one on the ball screw...
Filardo
Post
by Filardo »
suntravel wrote: ↑Tue Apr 26, 2022 3:52 am
I thought it was to gain speed in rapid
Je croyais que c'était pour gagner de la vitesse en rapide
Post
by suntravel »
No to gain torque to move the heavy gantry fast without stalling the drives.
Filardo
Post
by Filardo »
So I will have to make spacers with the right diameter
Du coup je vais être obligé de fabriqué des entretoises au bon diamètre
