Help needed on the best way to control a 8 position lathe turret
jumps4
CNC Control System Serial Number: 38d2697ca033-0611180974 mpu12
Re: Help needed on the best way to control a 8 position lathe turret
Post by jumps4 »
I had a problem with Acorn not allowing me to restore from a report to upgrade from v4.18 to v4.64. It would give an error about writing the wizard file.
I worked out an easy method of updating from v4.18 with all of my custom settings and files to v4.64.
I made a report from the v4.18 program to the desktop and renamed it "report v4.18"
I renamed the C:\cnct directory to cnctv4.18
I did a fresh install of version 4.64 and opened it so it communicated with acorn board then shut it down.
I copied the file I named "report v4.18 into the new cnct directory and unzipped overwriting all the files.
I then started Acorn
acorn called for repower of the acorn board and when completed all my settings were in the new software and working as normal.
I then opened the wizard and It asked if I wanted to use my custom setting and I did. I didn't change anything in the wizard. I then wrote the setting to acorn and closed the wizard.
I now had my v4.18 original virtual operating panel skin with the ability to modify it.
I changed the image file in the aux11 button to the Turret index image and I was done.
Everything I had working before on my machine and turret work perfect in the new version.
Steve
report_38D2697CA033-0611180974_2021-03-28_20-12-20.zip
(839.11 KiB) Downloaded 87 times
No Brains, No Headaches...
