24v input issue <resolved, short to ground by foil>
Sword
Re: 24v input issue
Post by Sword »
Looks like the green LED on the power supply goes off too. Short to ground somewhere. Does it do the same when connecting to the other 24v in? What is on the other side where you have the mounting screws going through? A stand off body or a washer that is shorting something to ground on the back side?
Scott
Re: 24v input issue
Sword wrote: Wed Mar 06, 2024 11:20 pm Looks like the green LED on the power supply goes off too. Short to ground somewhere. Does it do the same when connecting to the other 24v in? What is on the other side where you have the mounting screws going through? A stand off body or a washer that is shorting something to ground on the back side?
i agree, power off and take these off the board.
nods221
Re: 24v input issue
Post by nods221 »
Thank you for your help guys! I found a tiny piece of what looks wire shielding foil jammed under the input terminal block and touch the ground under the mounting screws. Lights are all on now, I’ll finish testing the inputs this evening.
Re: 24v input issue
nods221 wrote: Thu Mar 07, 2024 6:47 am Thank you for your help guys! I found a tiny piece of what looks wire shielding foil jammed under the input terminal block and touch the ground under the mounting screws. Lights are all on now, I’ll finish testing the inputs this evening.
thanks for reporting back.
glbreil
Re: 24v input issue <resolved, short to ground by foil>
Post by glbreil »
I must say that is a pretty good power supply to still be working!
Gary
