laser VC correction takes an afternoon to do. yes you need a $50k laser to do it. there are some guys online that built there own.
.. paired axis with different screw comp tables is on the list. but imho its a way over the top for a hobby machine. these kinds of features are found on controls that charge big bucks for them.
What are you plans for the machine accuracy and repeatability goals?
its on our list but, what is more important to the Acorn majority of the user base?
We can take a survey. Here is my list off the top of my head.
v5.08 release
Rotary Table setup page in Wizard
C axis setup page in Wizard
Exclusion zones setup menu with teach in
step and direction output for spindle motors
G64 for a lathe
Improved g code backplot graphical features
VC released, off beta with setup menu
Fiber laser UI, Oxy flame UI
Improved TT/Tool lenght setup menu
build new CNC12 installer
build new versions of Mill and Lather intercon with long list of requested features such as big improvements to dxf in.
rebuild digitizing menus and add export to dxf
CNC12 screen set builder
add the Wizard to Hickory
Port backup along g code from Plasma to Mill, Router and Lathe
Wizard "import report" for easy updates.
Relay Auto squaring in Wizard.
and about 100 little items to numerous to list here.
see feature request threads on the forum.
when all that gets done, then i'll work on different screw compensation tables for different gantry axis screws.
