Re: Repair / Retrofit of Milling/Machining Center TRUMP B8AC
Posted: Wed Aug 21, 2024 6:52 pm
With vacation and a nice summer, it's been some time... anyway:
See the report in the folder called report backup on the OneDrive:
https://1drv.ms/f/s!AuCfg0ciIehngitGMw0 ... 0?e=5TnfO8
I was able to verify others outputs using the ALT+i screen with the command stated. Everything seems to work correctly (lube pump On/Off, coolant pump On/Off, carousel In/Out, cone-air In/Out)
I tried something else with the spindle by screwing the Inverter RUN on the input 12 Zero Speed instead of Inverter FU (frequency detection) but the spindle still soing the same thing (sometimes turning a little bit (1 rotation or so) and stops. It looks like it's doing an orient sequence on it.)
I am still getting the encoder MPG1 encoder error as stated prior. Wired MPG still lights up green but not working by moving any axis, the interface work for jogging them
Thanks again for any support ✌
