Page 2 of 3
Re: Losing steps?
Posted: Tue Jul 11, 2023 11:16 pm
by ShawnM
Your old report from 4.64 shows communication errors which is a noise issue. Did you do any hardware changes or rewire anything before the issue started? Post a report from 5.02. Are you using a laptop?
Re: Losing steps?
Posted: Wed Jul 12, 2023 8:34 am
by CNCMaryland
Curious on the computer used as well. Need to make sure its running via an ethernet port, not a USB Ethernet adapter.
Re: Losing steps?
Posted: Wed Jul 12, 2023 9:05 am
post a report from v5.X+
Re: Losing steps?
Posted: Wed Jul 12, 2023 9:07 am
programs are short vector are you using smoothing? is smoothing turned on? the v4.64 report shows that it is off.
Re: Losing steps?
Posted: Wed Jul 12, 2023 11:51 am
by mikeman20
CNCMaryland wrote: ↑Wed Jul 12, 2023 8:34 am
Just Ethernet, not an adapter.
It's running on an older gaming laptop (Asus ROG) that I only use for this now.
These toolpaths were made in aspire, I'll have to see what kind of smoothing it uses.
I'll post an updated report when I get home from work today.
Re: Losing steps?
Posted: Wed Jul 12, 2023 12:31 pm
by CNCMaryland
Good. I have had similar documented issues using an USB Ethernet Adapter.
Re: Losing steps?
Posted: Wed Jul 12, 2023 2:19 pm
by Ken Rychlik
Laptop is a complete no-no
Re: Losing steps?
Posted: Wed Jul 12, 2023 2:25 pm
by Tealfixie
Could you elaborate on this? I'm sure many people are using laptops here and would be fine as long as you have set up the windows per the guide. The only thing I can think of is that the battery doesn't like to be plugged in full time.
Ken Rychlik wrote: ↑Wed Jul 12, 2023 2:19 pm
Re: Losing steps?
Posted: Wed Jul 12, 2023 3:05 pm
by tblough
Laptops turn off things like USB and Ethernet ports at random times to conserve battery life.
Re: Losing steps?
Posted: Wed Jul 12, 2023 5:12 pm
by ShawnM
This is why Centroid states on the PC requirements page to NOT use a laptop for CNC12. If you called for support they would not help you because they specifically tell you not to use a laptop yet many do with mixed results. Simply use the proper PC.
