Vfd connections
Re: Vfd connections
Nope, that parameter will do a reset from the keypad. You need an “external” reset signal input which is what X3 is for and needs to be set to 8 according to the manual you linked to. Can you set X3 to either 3 or 4 and get it to run forward or reverse? Can you set X1 or X2 to 8?
chris1976
Re: Vfd connections
Post by chris1976 »
ShawnM wrote: Tue Jun 13, 2023 7:25 am Nope, that parameter will do a reset from the keypad. You need an “external” reset signal input which is what X3 is for and needs to be set to 8 according to the manual you linked to. Can you set X3 to either 3 or 4 and get it to run forward or reverse? Can you set X1 or X2 to 8?
Going to try those after work today
chris1976
Re: Vfd connections
Post by chris1976 »
tried changing X1 and X2 to 8 but still get the "err" awaiting the sellar to come back to me again now.
chris1976
Re: Vfd connections
Post by chris1976 »
Just had a message saying I can use the X5 connection
