Torch Touch off issue
All things related to the Centroid Acorn Plasma system.
Moderators: cnckeith, Joey
Joey
Re: Torch Touch off issue
Post by Joey »
Good work. This is the third time I've seen a faulty float switch. Each time I've gone down the rabbit hole and didn't think to ask about the float switch. Must be a more common issue than I thought. Especially when the switch is intermittent and seems to be working. Glad you squashed that one.
So you cut a slope? The THC must be working? Can you post a fresh report?
Your not able to Cut the 100mm line job? Can you post the Job file that's giving you trouble?
