Screwcutting
Re: Screwcutting
If it will do only 800rpm, you have max. 1200mm/min feed for the Z axis set up.
Here is how ist looks with 3000 rpm:
Philtrueman
Re: Screwcutting
Post by Philtrueman »
Muzzer wrote: Sun Apr 24, 2022 11:42 am These boys in Glasgow are pretty good on pricing and fast delivery. I ended up buying 2 each of the metric sizes between 1.0mm and 2.0mm in each of aluminium (AK10) and steel (T250).
https://www.shop-apt.co.uk/threading-inserts.html
I've been using 250rpm and 500rpm for my threading. That's still pretty fast.
Why did you show me that link to the APT shop? Now i have just loaded up my credit card to the MAX with tools :D
Philtrueman
Re: Screwcutting
suntravel wrote: Sun Apr 24, 2022 12:28 pm If it will do only 800rpm, you have max. 1200mm/min feed for the Z axis set up.
Here ist how ist looks with 3000 rpm:
Super fast What are your max feeds for the axis?. What are your steppers set to steps per rev on the drivers?
Re: Screwcutting
Max feed for Z with stepper was 5000mm/min with 20x5mm ball screw and Stepper belted 2:1 4000 puls/rev
Now with servo also 4000 puls/rev, Acorn set to 400 khz and out comes 15000mm/min, but I use only 10000mm/min , because this reaches the critical rpm for the long ballscrew.
Philtrueman
Re: Screwcutting
suntravel wrote: Sun Apr 24, 2022 3:46 pm Max feed for Z with stepper was 5000mm/min with 20x5mm ball screw and Stepper belted 2:1 4000 puls/rev
I managed to leave the steps per rev at 1600 and increase the feedrate to 2200mm/min any more increase and it didn't like it.
I used coolant on all the turning and it works well.
The turret is reliable now i find that i have to do M18 after the posting of the code and then it doesn't miss a tool change.
https://www.youtube.com/shorts/jBmfTGupH40
Maybe it needed 2 more spring passes on the thread.
Re: Screwcutting
Now that is a big improvement compared to the first video :)
You can also try to make the first cut deeper, because this is the easy cut.
