Page 2 of 4
Re: JMC 220V Servos with Acorn
Posted: Fri Nov 18, 2022 9:28 pm
by bubblevisor
I'm also scratching my head on how to e stop the spindle. Is it just a case of cutting the mains power supply with the e stop contactor??
Posted: Sat Nov 19, 2022 2:44 am
by suntravel
Yes, e-stop cuts power to the servo.
Posted: Sat Nov 19, 2022 8:50 am
by tblough
Ideally, e-stop would cut motor power to the servos while leaving the servo control still powered up. Same for the spindle - remove the motor power, but leave the VFD control power on.
This lets you retrieve any error or fault codes from the devices.
Posted: Tue Nov 22, 2022 6:57 am
by suntravel
If a Servo goes on error, the machine stops anyway, so i can read the error code.
But when I hit E-Stop I want to cut off all high voltage going to the machine for safety reasons.
Posted: Wed Dec 14, 2022 4:46 pm
by bubblevisor
Black Forest wrote: Wed Aug 31, 2022 11:09 am What connector is on the drive to connect it to the Acorn? DB44 or DB25? Or something else? I have more money invested in crimping and wiring tools that I have in the Acorn with pro license! All these Knipex tools start to add up!
Its a SCSI 50 pin connector.
aliexpress item here:
https://www.aliexpress.com/item/1005003 ... TmAJc8bFaE
Posted: Wed Dec 14, 2022 10:06 pm
by bubblevisor
Uwe, I am comparing your wiring diagram for the JASD 15002 spindle servo with the one in the JASD manual. Excuse me if I am wrong but I think there was a typo on the pin17 connection should read pin 7. Here's the diagram from the manual.
Posted: Wed Dec 14, 2022 10:43 pm
by suntravel
Pin 7 is for external 24V, Pin 17 to Pin11 for internal 24V.
Posted: Mon Jan 08, 2024 5:58 pm
by RJS100
Hello Uwe, I am bench testing now and have one question. Above you wrote:
"In the Zip is the schematic as PDF and DWG , all JMC manuals / selection guides and the XML file for the drive types to use with Acorn."
What is the XML file used for?
Thanks... Richard
Posted: Tue Jan 09, 2024 1:19 am
by suntravel
This is a Drivetype file for the wizard.
Posted: Tue Jan 09, 2024 2:47 am
by RJS100
Got it. So you don't need it for a spindle application.
Thank you.
